TWP Natural Effect 1-Gallon Top Coat – Step 2
TWP® Natural Effect Step 2 is a waterborne topcoat designed to protect and enhance exterior wood surfaces, including exotic hardwoods like IPE, while maintaining a natural, long-lasting finish. This high-performance, low-VOC formula prevents flaking, cracking, or chalking, making maintenance and touch-ups effortless.
- TWP Natural Effect Top Coat is a waterborne, low-VOC formula compliant in all 50 states and Canada, making it eco-friendly and widely accessible.
- Controlled Erosion Technology prevents peeling, cracking, and chipping, keeping maintenance and touch-ups simple for homeowners.
- Apply two coats using a brush, roller, or sprayer, with just 1 hour of dry time at 74°F between coats.
- Works on both softwoods and hardwoods, including IPE, cedar, redwood, and pressure-treated lumber, making it highly versatile.
- Must be used as Step 2 over TWP Natural Effect Impregnating Stain for optimal protection and longevity.
Why Choose TWP Natural Effect Top Coat?
✔ #1 Rated Exotic Hardwood & IPE Coating – Suitable for all exterior wood types.
✔ Advanced Water-Based System – Eco-friendly, low-VOC, and compliant in all 50 states & Canada.
✔ Controlled Erosion Technology – Prevents peeling, cracking, and chipping for easy maintenance.
✔ Enhanced UV Protection – Shields against harmful UV rays, reducing fading and weathering.
✔ Walkable Surface Safe – Durable non-slip protection for decks, patios, and walkways.
🔹 How to Apply
✔ Apply Over TWP Natural Effect Impregnating Stain (Step 1) – This two-part system ensures optimal protection and longevity.
✔ Use a Brush, Roller, or Sprayer – Adjust sprayer settings to avoid sags or runs.
✔ Two Coats Recommended – Allow 1 hour of dry time at 74°F between coats.
✔ Customizable UV Protection – Mix up to 6 oz. of TWP Impregnating Stain per gallon for added sun resistance.
✔ Temperature Guidelines – Do not apply below 60°F for best results.
🔹 Key Features & Benefits
✔ Dries Clear – Preserves the natural beauty and grain of wood.
✔ Water-Repellent – Blocks moisture, reducing the risk of warping, cracking, and splitting.
✔ No Chipping, Peeling, or Flaking – Ensures long-lasting protection.
✔ Fast Drying – Ready for recoat in just 1 hour.
✔ Recoat Anytime – Simple, hassle-free maintenance.
✔ Works on Softwoods & Hardwoods – Perfect for IPE, cedar, redwood, and pressure-treated lumber.
🔹 Important Notes
✔ Must be used as Step 2 – Designed specifically for use over TWP Natural Effect Impregnating Stain.
✔ Small Samples Available – Colors may vary based on wood type, age, and prep method.
🔹 Protect your wood investment with TWP Natural Effect! Order now for superior durability, easy maintenance, and unbeatable UV & moisture protection.
