Varnish vs. Deck Stain: Which Should You Use Outdoors? 5/5 (1)
Varnish vs. Deck Stain: Which Should You Use?
Hi, I’m Scott Paul, a licensed exterior restoration contractor with over 30 years of experience and 10,000+ deck restorations. This comparison of varnish vs. deck stain is based on my own hands-on field experience, not manufacturer claims. See my full credentials and testing stats here.
Should I use wood stain or varnish to maintain my deck? I don’t recommend using varnish or polyurethane on outdoor decks because they will quickly peel and often fail to prevent sun damage. In many cases, homeowners seeking a shiny, glossy surface try using varnish outdoors, which becomes a frustrating, ongoing maintenance project.
Varnish vs. Deck Stain — Quick Answer
  • Never use Varnish on a deck, it will peel, blister, and create a nightmare to fix.
  • Deck stain is the right choice for outdoor decks; varnish is not — it will peel, blister, and fail to block UV damage outdoors
  • Deck stain penetrates the wood; varnish sits on top as a film, which is why it fails faster outside
  • Quality deck stain lasts 2–3 years on horizontal surfaces (4+ on vertical); varnish needs frequent reapplication once exposed to weather
  • Top deck stain brands (Restore-A-Deck, TWP, Armstrong Clark) run $45–$79/gallon — never use varnish as a substitute outdoors
Table of Contents
Key Takeaways
  • Varnish is best suited for protecting and enhancing wood that is located indoors.
  • Unlike deck stain, which penetrates the wood, varnish protects wood by creating a top coat.
  • The harsh outdoor elements, including moisture and ultraviolet rays, will cause varnish to peel and blister and allow mildew development.
Understanding Varnish: More Than Just a Glossy Finish
Varnish is a liquid coating containing oil, resin, and solvent that forms a transparent finish to protect and enhance the appearance of wood surfaces. People often (mistakenly) use the term “varnish” very generally to describe coatings such as lacquer, shellac, or polyurethane. Varnish is designed to prevent water penetration, limit impact damage, and provide some protection from UV rays.
Deck Stain Demystified: A Natural Look with Solid Protection
Peeling Varnish on Deck
Peeling Varnish on Deck!
Wood deck stains can prevent damage caused by UV rays, moisture, mold, and mildew. Deck stains may be clear, transparent, semi-transparent, semi-solid, or solid, and have either a water or oil base.
Choose a high-quality deck stain that’s correctly formulated to meet your specific needs based on the condition of the deck and climate. Transparent stains are great for protecting and enhancing the appearance of wood that’s in good condition. Semi-solid or solid stains offer coverage that minimizes imperfections found on older decks.
Varnish vs. Deck Stain: Key Differences
When comparing wood stain vs. varnish, it’s important to understand the primary differences.
Feature Deck Stain Varnish
How it protects Penetrates into the wood Forms a top-layer coating
Finish Available in various opacities Typically transparent, glossy (some satin/matte formulas exist)
Outdoor UV protection Formulated for outdoor UV exposure Inadequate for exterior use; flakes and peels
Best use case Exterior decks, fences, siding Indoor wood surfaces only
Reapplication frequency (outdoors) 2–3 years (horizontal), 4+ years (vertical) Frequent — peels quickly outdoors
When to Choose Varnish for Your Deck
I discourage using varnish, polyurethane, or urethane coatings on exterior wood decks. Although these options generally work well indoors, they will likely blister or peel when exposed to outdoor elements, including extreme moisture and UV rays.
When to Choose Deck Stain for Your Deck
I recommend applying transparent stains annually and semi-transparent, semi-solid, and solid stains every two to three years. The surface preparation process, which may include cleaning, stripping, brightening, and drying, is critical before staining. Always allow the stain time to penetrate the wood and remove any remaining excess.
When choosing a stain, select one that’s appropriate for the deck’s condition and the local climate. Check out my post on when to initially stain new wood decks.
Cost Considerations: Varnish vs. Deck Stain
What’s the difference between stain and varnish from a cost perspective? Most of my favorite wood deck stain brands, including Restore-A-Deck, TWP, and Armstrong Clark, sell for between $45 and $79 a gallon. I don’t suggest using varnish or a shiny-type coating as an alternative to wood deck stain — the frequent reapplication it requires outdoors ends up costing more in time and money than a quality stain.
Take the Next Step: Find the Perfect Finish for Your Deck
Finding the best deck stain for your specific needs is critical. Consider these tips:
  • Transparent stains are ideal for newer decks to enhance the wood’s natural appearance.
  • With more “paint-like” properties, semi-solid or solid stains provide the coverage needed to conceal flaws and imperfections on older decks.
  • Choose stains with powerful UV protection for decks exposed to direct sunlight, and those containing mildewcides and algaecides to stop mold and mildew in damp, humid climates.
  • Semi-transparent stains offer a good balance of benefits.
  • Water-based stains are generally more eco-friendly and easier to clean up compared to oil-based options.
  • Oil-based stains typically offer better penetration and protection, but usually come in fewer colors, are more expensive, and have restricted availability based on your state’s VOC regulations.
Choosing the Best Deck Stain — Video
What Happens When Choosing the Wrong Stain – Deck Stain Failure Photos
FAQ: Varnish vs. Deck Stain
Can I mix varnish and deck stain on the same deck?
No. I don’t recommend mixing varnish and stain, as it will negatively alter the stain’s performance and void the manufacturer’s warranty. The two products have fundamentally different chemistries — one penetrates, one sits on top — and combining them can lead to poor adhesion and premature failure.
Is there a clear winner between varnish and deck stain for durability?
Broadly comparing the durability of varnish vs. stain is somewhat indeterminate, since there are many formulations of each. On exterior wood decks, however, varnish typically struggles to withstand the elements and is more susceptible to fading, peeling, and blistering than stain. For maintaining your deck, I recommend choosing a deeply penetrating deck stain instead.
How do I know if my deck needs to be stripped before applying a new finish?
Always completely remove any remnants of the existing stain before staining your deck. Deck stain strippers soften existing coatings for easier removal and clear the surface of mold, mildew, or dirt. Strippers are most effective at removing clear, transparent, or semi-transparent stains — not paints, solid stains, or varnish, which require different removal methods like sanding.
Does varnish make wood waterproof?
No. While varnish creates a protective coating that resists water on the surface, it doesn’t fully waterproof the wood. Once the coating develops even small cracks or peeling, which happens quickly outdoors, moisture gets underneath the film and can cause more damage than if the wood had no coating at all, since trapped moisture has nowhere to escape.
Does varnish protect wood from rotting?
Not effectively outdoors. Wood decay, commonly called “wood rot,” is a process of decomposition caused by fungal growth that needs moisture to thrive. Varnish doesn’t form a reliable barrier that prevents moisture intrusion once it starts to peel or blister, which means it can’t consistently stop fungal development on an exterior deck the way a properly maintained penetrating stain can.
How often do I need to reapply deck stain compared to varnish?
A good-quality semi-transparent, semi-solid, or solid deck stain should last two to three years on horizontal surfaces and at least four years on vertical surfaces. Clear or transparent deck stains are less durable and often need reapplication every year. Varnishes, by comparison, begin to peel quickly when exposed to outdoor elements and require far more frequent reapplication than any deck stain.
0 Comments
