- The Restore-A-Deck Stain Stripper Booster is an additive only and will not work as a standalone stripping product.
- It boosts the stripping power of Restore-A-Deck Stain Stripper by up to 300% on stubborn coatings.
- Works on acrylic-based, oil-based, clear, transparent, semi-transparent, and semi-solid deck stains and sealers.
- Safe for use on decks, fences, log homes, siding, and outdoor furniture made of exterior wood.
- For vertical surfaces, combine with Restore-A-Deck Stain Stripper Thickening Gel for better cling and longer dwell times.
- Always follow up with Restore-A-Deck Wood Brightener after stripping to restore proper wood pH balance.
✔ Clear Wood & Deck Sealers
Stain Types Removed
