Restore-A-Deck Solid Stain – Prep and Stain on the Same Day!
Restore-A-Deck Solid Color Wood Stain – Durable, Opaque Protection
High-Performance Solid Stain & Sealer in One
Restore-A-Deck Solid Color Wood Stain is an extremely durable, synthetic-resin, opaque wood finish that provides maximum protection against water, fungi, and UV damage. This VOC-compliant, water-based stain is designed for all exterior wood surfaces, delivering a matte finish that resists peeling, cracking, and fading.
- New color! Classic Black Solid Color Stain.
- Restore A Deck Solid Stain 1 Gallon covers about 200 to 350 sq ft per gallon per coat, and two coats are recommended.
- Restore A Deck Solid Stain 1 Gallon dries in about 2 to 4 hours between coats, allow 24 to 48 hours before heavy foot traffic.
- Restore A Deck Solid Stain 1 Gallon is applied with brush and rollers. Apply two coats and back brush for even application.
- Restore A Deck Solid Stain 1 Gallon suits decks fences siding outdoor furniture and playsets, ideal for older weathered wood needing full coverage.
✔ Applies to Dry or Damp Wood – Stain the same day as prep
✔ Full UV Protection – Prevents graying and wood damage
✔ Seals & Protects in One Step – Waterproofs while adding color
🔹 Why Choose Restore-A-Deck Solid Color Stain?
✅ Apply the Same Day as Cleaning – No waiting for wood to dry
✅ 100% Opaque Coverage – Hides imperfections and provides a uniform color
✅ Advanced Water-Based Technology – Durable protection without peeling
✅ Low VOC – Compliant in all 50 states & Canada
✅ Ideal for All Exterior Wood – Decks, fences, siding, outdoor furniture & log homes
✅ Flat, Matte Finish – Clean, modern look with solid color protection
📌 New Wood Note: New wood must weather and be prepped before staining to ensure proper adhesion and performance.
🔹 Where to Use Restore-A-Deck Solid Color Stain
✔ Decks, Railings & Stairs
✔ Fences & Pergolas
✔ Wood Siding & Log Homes
✔ Gazebos, Outdoor Furniture & Playsets
📌 Perfect for older or weathered wood that needs full coverage.
🔹 Coverage & Application
📏 Coverage: 200–350 sq. ft. per gallon per coat (varies by wood porosity). Two coats are required for proper coverage.
🕒 Dry Time: 2–4 hours at 70°F and under 50% humidity.
🌞 Can be applied in sun or shade.
How to Apply Restore-A-Deck Solid Color Stain
- Prep the Wood: Use Restore-A-Deck Cleaner or Stain Stripper, followed by Restore-A-Deck Brightener.
- Ensure the Surface Is Ready: Dry off all standing water (typically 2–4 hours after prep).
- Apply with Brush, Roller, or Pump Sprayer: Work wet-on-wet for even absorption.
- Back-Brush or Use a Stain Pad: Ensures even penetration and a smooth finish.
- Let Dry Completely: Allow 24–48 hours before heavy foot traffic.
📌 Detailed guides:
- How to Apply RAD Stain to Damp Wood
- Restore-A-Deck Stain & New Wood Prep
- Two-Tone Deck Application Tips
🔹 Available Colors
🎨 Pre-mixed solid colors for full coverage:
✔ Classic White
✔ Classic Black
✔ Espresso
✔ Brown Oak
✔ Cypress
✔ Desert Taupe
✔ Coastal Gray
Order Solid Stain Samples: RAD Solid Stain Samples
Note: We suggest downloading and printing the color chart below. It is also included in the product photos above. Colors will vary based on full sun or shade.
Color Chart – RAD Solid Stain on Wood Samples
✔ Get Full-Coverage, Long-Lasting Protection
✔ Stain and protect your wood the same day as prep
✔ 100% opaque coverage for maximum UV and moisture protection
✔ Water-based formula for easy cleanup and maintenance
WARNING: This product can expose you to Ethylene oxide, which is known to the State of California to cause birth defects or other reproductive harm, and Cumene, which is known to the State of California to cause cancer. For more information, go to www.P65Warnings.ca.gov.
Any advice of whether the old owners used paint or stain here? Occasionally pieces flake or peel off. I believe deck is over 20 years old. Would you adjust any of your steps based on the age of the wood? Thanks
It looks like a solid color stain.
I’m kinda stuck at this point with Acrylic which really is not good. Just looking for something acrylic that is better then cabot. Maybe restore a deck. The deck is pretty big and wish i never used the acrylic.
Did you have a question(s)?
My deck is currently stained with brown cabot acrylic and it only lasts a couple of years before peeling. I’m wondering if this is a better solution and if I can get sample colors?
The RAD Solid stain is much better than any other solid stain brand, but the key is prep. Any failing coatings should be removed first.
Samples: https://www.deckstainhelp.com/product/restore-a-deck-solid-stain-sample/
What if the current condition of the deck is pealing in some places. What prep do you recommend
Add some pics in the comments of your deck for prep advice.
Used the restore-a-deck solid stain on my fence and couldn’t be more pleased. Smooth application, great coverage, and a great life span.
