Restore-A-Deck Solid Stain Samples
Test the RAD Semi-Transparent colors before purchase!
- New color! Classic Black Solid Color Stain.
- Restore-A-Deck Solid Color Wood Stain is a water-based, synthetic-resin formula that protects exterior wood from water, fungi, and UV damage.
- The stain can be applied the same day as prep, once standing water dries, typically 2 to 4 hours at 70°F and under 50% humidity.
- It works on a wide range of surfaces including decks, fences, siding, log homes, and outdoor furniture, both horizontal and vertical.
- Coverage ranges from 200 to 350 square feet per gallon, depending on the porosity of the wood being stained.
- The formula is low VOC, eco-safe, compliant in all US states and Canada, and resists mold and mildew growth.
- Six colors are available including Espresso, Coastal Gray, Classic White, and Desert Taupe; colors may vary in full sun versus shade.
Each sample is roughly 1-2 oz. This is enough to test a small area.
Restore-A-Deck Solid Color Wood Stain is an extremely durable synthetic-resin, opaque wood finish that helps protect against the damaging effects of water, fungi, and UV radiation on exterior wood surfaces. This V.O.C. compliant water-based product provides exceptional protection for nearly all exterior wood surfaces in a beautiful matte finish.
Restore-A-Deck Wood Stain can be applied the same day as the prep. Make sure that all standing and visible water has dried off the surface after prep. Typically 2-4 hours at 70º F and less than 50% humidity.
Note: We would suggest downloading and printing the color chart by clicking the picture to the left. There is also a full version of the color chart picture below and in the product pictures above.
*Colors will vary based on full sun or shade.
WHERE TO USE
Restore-A-Deck Solid Color Wood Stain can be used on interior or exterior horizontal and vertical wood surfaces including: wood siding, log homes, decks, fences, outdoor wood furniture, pressure-treated and all other natural wood surfaces.
ADVANTAGES
- Both a solid stain and sealer for your wood
- Protects wood from damaging UV rays
- Available in pre-mixed solid color (opaque) finishes
- For use on all softwood types
- Dries to a flat finish
- Water-based, easy cleanup
- Low VOC content (
- For use on all exterior wood types and surfaces, not just decks
- Eco-Safe
- Easy to reapply as needed
- Does not promote mold/mildew growth
- Low VOC content, compliant with all US states and Canada
Restore-A-Deck Solid stain can be applied the same day as the prep. Make sure that all standing water has dried off the surface after prep. Typically 2-4 hours at 70º F and less than 50% humidity.
Note: Restore-A-Deck Solid Stain can be applied to dry or damp wood.
Coverage:
RAD Wood and Deck Solid Stain applies at about 200-350 feet per gallon. Actual coverage varies depending on wood porosity.
📌 For detailed guides:
- Aplying RAD Stain Wet-on-Wet
- How to Apply RAD Stain to Damp Wood
- RAD Stain & New Wood Prep
- Two-Tone Deck Application Tips
Color Chart Below is the RAD Solid Stain on Wood Samples
Available Colors: Espresso, Brown Oak, Classic White, Classic Black, Cypress, Desert Taupe, Coastal Gray
