TWP Semi-Solid Pro-Series Stain & Restore-A-Deck Stripper/Brightener Combo Pack
Complete Wood Restoration & Protection in One Kit!
The TWP Semi-Solid Pro-Series Stain & Restore-A-Deck Stripper/Brightener Combo Pack is the ultimate solution for removing old coatings, brightening wood, and applying a long-lasting, high-performance stain. This oil-based semi-solid stain offers maximum UV protection, deep penetration, and enhanced durability, ensuring your deck, fence, or siding remains beautiful and well-protected for years.
- The TWP Semi-Solid Pro-Series Stain is an oil-based formula offering deep penetration, fade resistance, and strong UV protection for exterior wood.
- The kit includes Restore-A-Deck Stain Stripper and Restore-A-Deck Wood Brightener, covering up to 1,000 sq. ft. each per container.
- TWP Semi-Solid Pro-Series is not VOC-compliant in all 50 states; check availability or consider the Low-VOC Semi-Solid version for broader use.
- Wood must dry 24 to 48 hours after cleaning before applying stain; apply between 50°F and 90°F for best results.
✔ (1) TWP Semi-Solid Pro-Series 5-Gallon Pail – Deep Penetrating, Fade-Resistant Stain
✔ (1) Restore-A-Deck Stain Stripper – Removes Previous Coatings & Prepares Wood
✔ (1) Restore-A-Deck Wood Brightener – Restores Wood’s Natural Beauty & pH Balance
🏆 #1 Rated Semi-Solid Stain for Durability & Fade Resistance
🛡 Water-Repellent, Mold-Resistant, & Easy to Apply
📌 TWP Semi-Solid Pro-Series is not VOC-compliant in all 50 states. Look the TWP Low-VOC Semi-Solid Version for all 50 States and Canada,
🔹 Why Choose the TWP Semi-Solid Stain & Restore-A-Deck Stripper/Brightener Kit?
✅ Strips Old Stains & Prepares Wood for New Stain Application
✅ Restores Wood’s Natural Beauty by Removing Rust, Tannins & Weathering
✅ Deep-Penetrating, Oil-Based Semi-Solid Stain for Maximum Protection
✅ Works on All Exterior Wood Surfaces – Decks, Fences, Siding, & More
✅ Easy to Apply & Maintain with Superior Weather Resistance
📌 TWP Semi-Solid Pro-Series is VOC-compliant in all 50 states.
🔹 What’s Included in the TWP Semi-Solid Stain & Restore-A-Deck Stripper/Brightener Kit?
(5 Gallons) TWP Semi-Solid Pro-Series Stain – Maximum UV Protection & Water Resistance
✔ Premium oil-based stain & sealer with deep penetration
✔ Semi-solid finish for superior longevity & fade resistance
✔ Repels water & resists mildew and mold growth
✔ Prevents cracking, splitting, & freeze damage in colder climates
✔ Enhances wood grain while providing rich, long-lasting color
Technical Specifications – TWP Semi-Solid Wood Stain
Stain Type: Semi-Solid, Oil-Based
Coverage: 100–200 sq. ft. per gallon
Recommended Coats: 1-2 Coats (Wet-on-Wet Application)
Dry Time: 4 to 24 Hours
Available in 30 Stunning Custom Colors:
🎨 From deep browns to vibrant wood tones – choose your perfect shade!
🎨 Semi-solid opacity enhances wood grain while providing superior protection.
📌 Note: TWP Pro-Series Semi-Solid colors are custom orders and may require 1-3 days for processing before shipping.
Step 1: Restore-A-Deck Stain Stripper – Removes Previous Coatings & Prepares Wood
✔ Removes worn stains, dirt, mildew, and mold
✔ Prepares wood for even stain absorption
✔ Biodegradable & safe for plants when used as directed
✔ Powdered concentrate – makes 5 gallons of solution
📏 Coverage: 500-1,000 sq. ft. per container.
🚫 Not designed to remove solid color stains or thick coatings.
✔ For those coatings, use the Restore-A-Deck Paint & Solid Stain Stripper.
Step 2: Restore-A-Deck Wood Brightener – Restores Wood’s Natural Color & pH Balance
✔ Neutralizes stain stripper & enhances wood’s natural color
✔ Removes rust stains, tannins, and weathering effects
✔ Improves stain adhesion & enhances stain longevity
✔ Eco-safe & easy to apply
📏 Coverage: 750-1,000 sq. ft. per container.
🔹 Where to Use the TWP Semi-Solid Stain & Restore-A-Deck Kit?
✔ Wood Decks & Railings
✔ Fences & Pergolas
✔ Siding & Log Homes
✔ Outdoor Furniture & Playsets
📌 Perfect for any exterior wood that needs high UV resistance and rich, semi-solid color.
🔹 How to Use the TWP Semi-Solid Stain & Prep Combo Kit
Step 1: Strip Old Coatings with Restore-A-Deck Stain Stripper
1️⃣ Mix the Stripper: Each container makes 5 gallons.
2️⃣ Apply Using a Pump Sprayer or Brush: Fully saturate the wood surface.
3️⃣ Let Sit for 15-20 Minutes: Stripper will break down previous coatings.
4️⃣ Scrub or Pressure Wash Off: Rinse thoroughly with a garden hose or pressure washer.
Step 2: Brighten & Neutralize with Restore-A-Deck Wood Brightener
5️⃣ Mix the Brightener: Each container makes 5 gallons.
6️⃣ Apply Using a Pump Sprayer or Brush: Fully saturate the surface.
7️⃣ Let Sit for 10-15 Minutes: Neutralizes the stripper and restores wood pH balance.
Step 3: Apply TWP Semi-Solid Pro-Series Stain
9️⃣ Ensure Surface is Ready: Wood must be completely dry before staining (24-48 hours after cleaning).
🔟 Apply Stain Using Brush, Roller, or Pump Sprayer: Work wet-on-wet for even absorption.
1️⃣1️⃣ Back-Brush or Use a Stain Pad: Ensures even penetration & smooth finish.
1️⃣2️⃣ Let Dry Completely: Allow 24-48 hours before heavy foot traffic.
📌 For best results, apply TWP stain when temperatures are between 50°F-90°F.
✔ Get Professional-Quality Results with the TWP Semi-Solid Stain & Prep Kit!
✔ Deep penetrating oil-based stain with high UV protection
✔ Cleans, brightens, and stains wood for long-lasting beauty & durability
✔ Eco-friendly, easy to use, and works on multiple wood surfaces
🔹 Order the TWP Semi-Solid Pro-Series Stain & Restore-A-Deck Stripper/Brightener Kit today and protect your exterior wood for years to come!
TWP Semi-Solid Pro-Series 5 Gallon Deck Stain
