TWP Natural Effect 1-Gallon Stain – Step 1
TWP® is proud to introduce Natural Effect, an innovative water-based exterior wood finishing system utilizing advanced European waterborne technology. Designed to revolutionize exterior wood maintenance, this system provides superior performance, enhanced durability, and a stunning natural finish.
- TWP Natural Effect is a two-part system: Step 1 is the impregnating stain, and Step 2 is the required top coat for complete protection.
- Rated the #1 exotic hardwood and IPE stain, it also works on decks, fences, log homes, siding, and other exterior wood surfaces.
- Features iron oxide pigments and UV absorbers that block solar radiation, preventing color fade, warping, cracking, and wood rot.
- This water-based formula is low VOC at 250 and compliant in all 50 states and Canada, making it an eco-friendly option.
- Maintenance is simple: rinse with a garden hose every 18 months, and reapply stain and top coat every 3 to 4 years as needed.
Why Choose TWP Natural Effect?
✔ #1 Rated Exotic Hardwood and IPE Stain – Also suitable for all exterior wood types.
✔ Water-Based Exterior Wood System – Eco-friendly and low VOC (250 VOC), compliant in all 50 states & Canada.
✔ Deep-Penetrating Technology – Prevents wood degradation, UV damage, mold, and mildew.
✔ Iron Oxide Pigments & UV Absorbers – Blocks solar radiation for longer-lasting color & protection.
✔ Must Be Used as a Two-Part System – Step 1: Natural Effect Impregnating Stain; Step 2: Natural Effect Top Coat for ultimate protection.
✔ Super Easy to Apply – Goes on milky and clears as it dries, ensuring an even, professional-looking finish.
🔹 Ideal for Use On:
✔ IPE & Exotic Hardwoods
✔ Decks, Fences, & Outdoor Furniture
✔ Log Homes & Siding
✔ Shingles & Other Exterior Wood Surfaces
🔹 Application & Performance
✔ Application Methods: Brush, roller, pump sprayer, or traditional spray equipment.
✔ Dries Evenly: No matter how inconsistently applied, the stain will self-level for a perfect finish.
✔ Resists Solar Radiation & Moisture: Prevents color changes, warping, cracking, and wood rot.
✔ Maintenance: Wash with a garden hose every 18 months or when water no longer beads on the surface.
✔ Reapplication: At 3-4 years, color may begin to lighten; simply wash and reapply stain and top coat as needed.
🔹 Important Notes:
✔ TWP Natural Effect is Step 1 – Must be used with TWP Natural Effect Top Coat (Step 2) for complete protection.
✔ Small Samples Available: Colors may vary based on wood type, age, prep, and application.
✔ Not removable from window frames, masonry, etc. – Take special caution during application.
🔹 Preserve your wood’s natural beauty with TWP Natural Effect! Order today for superior protection, easy maintenance, and long-lasting results.
