Save Money with the Armstrong Clark Stain & Restore-A-Deck Stain Stripper/Brightener Kit Combo!
Complete Wood Stripping, Brightening & Staining Kit for a Perfect Finish
Restore and refinish your deck with the Armstrong Clark Stain & Restore-A-Deck (RAD) Stain Stripper/Brightener Kit Combo. This all-in-one solution includes 5 gallons of premium Armstrong Clark Stain, a Restore-A-Deck Stain Stripper, and a Restore-A-Deck Wood Brightener to help you remove old coatings, restore wood, and prepare for long-lasting stain adhesion.
- The Armstrong Clark Stain and Restore-A-Deck Combo bundles a Stain Stripper, Wood Brightener, and 5 gallons of stain in one kit.
- The Restore-A-Deck Stain Stripper removes most oil-based and water-based coatings, covering 500 to 1,000 sq. ft. per 5 gallons mixed.
- Armstrong Clark Stain uses an oil-based formula that penetrates deep, offering UV and moisture protection and covering 150 to 200 sq. ft. per gallon.
- The stain is VOC-compliant at 50 VOCs, works in temperatures from 50 to 110 degrees F, and is approved in all US states and Canada.
🔹 What’s Included in the Combo Pack?
✅ 1 Restore-A-Deck Stain Stripper – Removes previous coatings, dirt, and weathered stains.
✅ 1 Restore-A-Deck Wood Brightener – Neutralizes and restores the wood’s natural color, ensuring better stain penetration.
✅ 5 Gallon Pail of Armstrong Clark Stain – A high-quality, oil-based stain designed to nourish and protect wood.
🔹 Step 1: Restore-A-Deck Stain Stripper & Brightener System
✔ Powerful, Eco-Friendly Wood Stripper – Removes most transparent and semi-transparent oil-based & water-based stains.
✔ Covers 500-1,000 sq. ft. per 5 gallons when mixed.
✔ Neutralizing Brightener Included – Restores wood to a natural pH balance, enhancing stain absorption and longevity.
✔ Brightener Coverage: 750-1,000 sq. ft. per 5 gallons when mixed.
📌 Note: May not fully remove solid stains, paints, varnishes, or acrylic coatings. For these, use RAD Paint & Solid Stain Stripper.
🔹 Step 2: Armstrong Clark 5-Gallon Wood Stain
✔ Innovative Oil-Based Formula – Conditioning oils penetrate deep into the wood to restore and protect.
✔ Long-Lasting UV & Moisture Protection – Pigments and water repellents help lock out moisture and sun damage.
✔ Easy to Apply in Direct Sunlight – Can be applied in hot weather without performance issues.
✔ Flexible Application – Apply with a brush, roller, or airless sprayer.
✔ Fast Absorption for Second Coat Option – If the first coat penetrates within 30 minutes, a second coat may be applied for extra protection.
✔ Covers 150-200 sq. ft. per gallon, depending on wood porosity.
🔹 Available Colors
🌲 Transparent Colors: Cedar Tone, Natural Tone, Redwood Tone, Amber, Mahogany
🌲 Semi-Transparent Colors: Black Walnut, Cedar, Chestnut, Driftwood Gray, Natural Oak, Rustic Brown, Sierra Redwood
🌲 Semi-Solid Colors: Espresso, Mountain Cedar, Oxford Brown, Sequoia, Woodland Brown
📌 Note: Stain colors may vary depending on wood type, age, prep, and application method. Small samples are available for testing.
🔹 Why Choose the Armstrong Clark Stain & Restore-A-Deck Stripper/Brightener Combo?
✅ All-in-One Prep & Staining Solution – Strip, brighten, and stain in one cost-effective package.
✅ Deep Penetration for Maximum Protection – Armstrong Clark stain revives old wood and protects new wood.
✅ Stronger & More Effective Prep – Stain stripper removes old coatings, while brightener restores wood grain & enhances stain absorption.
✅ Eco-Friendly & VOC-Compliant – Safe, low-odor formula meets all environmental standards.
✔ Restore & Protect Your Deck with the Best Refinishing Kit!
✔ Remove old coatings, brighten wood, and stain with premium protection!
✔ Save money by getting all the products you need in one bundle!
✔ Achieve professional-quality results with minimal effort!
🔹 Order the Armstrong Clark Stain & Restore-A-Deck Stripper/Brightener Kit Combo Pack today and bring your deck back to life!
Technical Info Armstrong Clark Stains
Gallon Sizes:
1’s & 5’s
Coverage Per Gallon:
150-200 sq feet (Softwoods) 300+ (Hardwoods)
Coats Required:
1-2 Coats
Temperature:
50-110+ F
Application Tools:
Pad, Airless Sprayer, Brush
Dry Time:
8-24 Hours
Cleanup:
Mineral Spirits
VOC Limits:
50 VOCs. Compliant in all States and Canada
Product Data Sheets
Semi-Trans Hardwood Product Data
Safety Data Sheets
