Note: Each sample is roughly 1-2 oz of liquid stain. This is enough to test a small area.
Product Summary
- TWP Natural Effect is rated the #1 exotic hardwood and IPE stain, though it works on all exterior wood types.
- The formula uses state-of-the-art European waterborne technology designed to improve performance over traditional exterior wood stains.
- TWP Natural Effect is a water-based exterior wood finishing system, making it a modern alternative to solvent-based products.
- The stain is engineered to reduce long-term maintenance, so homeowners spend more time enjoying their deck and less time upkeep.
- TWP Natural Effect Impregnating Stain is Step 1 of a two-part system and must be used with the matching Top Coat Step 2.
- Skipping the Top Coat Step 2 is not recommended, as the impregnating stain alone does not provide ultimate exterior protection.
TWP Natural Effect STAIN SAMPLES
Sorry But No Samples Credits for TWP Natural Effect
TWP® Natural Effect utilizes state-of-the-art European waterborne technology and is designed to revolutionize exterior wood maintenance… …while at the same time significantly enhancing performance!
Spend more time enjoying your investment and less time maintaining it with TWP Natural Effect.
Natural Effect is the superior way to beautify and protect your exterior wood investment!
- The #1 Rated Exotic Hardwood and IPE Stain (It can be used on all exterior wood types)…
- A Water-Based Exterior Wood Finishing System…
- Utilizing European Waterborne Technology…
- Designed to Revolutionize Exterior Wood Maintenance, While Significantly Enhancing Performance…
IMPORTANT NOTE
- TWP Natural Effect Impregnating Stain is part one of a two-part exterior system. Must be top-coated with TWP Natural Effect Top Coat Step 2 for ultimate protection in an exterior environment.
