Hi, I am Scott Paul, a leading exterior restoration contractor and business owner with over 30 years of experience in exterior wood cleaning. My R-A-D™ PaintStrip review is based on my history as a wood restoration contractor and actual hands-on testing, all designed to present you with the top deck stain choices. See here for more info about me.
RAD PaintStrip Paint & Solid Stain Stripping Gel
If you have any questions about the effectiveness of your deck or wood stripping project, please ask below in the comments with the name of the stain brand and the removed type. Please add a couple of pictures as well.
RAD™ PaintStrip Stripping Gel Product Info
R-A-D™ PaintStrip is the right choice for almost any paint or sealer stripping project. R-A-D™ PaintStrip is eco-friendly, works fast (starts working within 5 minutes), removes up to 5 layers of most paints in 30-45 minutes, and up to 15 layers in 24 hours.
R-A-D™ PaintStrip stays wet for 24+ hours, allowing you to strip larger areas without having to reapply.
When & Where to use RAD™ PaintStrip
R-A-D™ PaintStrip does not contain any hazardous methylene chloride or NMP. R-A-D™ PaintStrip is non-flammable, non-combustible, and practically odor-free. R-A-D™ PaintStrip can be used on interior and exterior surfaces, including wood, brick, concrete, plaster, stone, metal, fiberglass, and more. Additionally, R-A-D™ PaintStrip clings well to vertical surfaces.
R-A-D™ PaintStrip Removes from Wood
- Solid Color Wood Stains, Paints, Varnishes
- Excessively Over-Applied Semi-Transparent and Semi-Solid Coatings
- Filming Acrylic Wood Stain Coatings such as Behr Wood Stains, Thompsons, Olympic, SuperDeck, Benjamin Moore ArborCoat, Valspar, PPG/Pittsburgh, and any other exterior wood and deck stains
How I Rated R-A-D™ PaintStrip
My R-A-D™ PaintStrip review contains a 5-step process and the final average score. Each step is on a scale of 1-10.
- Removal of Graying and Dirt
- Removal of Old Stain
- Ease of Application
- R-A-D™ PaintStrip Final Score
5-Step Review of R-A-D™ PaintStrip
1. Removal of Graying, Dirt, Grime: 10
The RAD PaintStrip will easily remove all oxidized graying, dirt, mildew, mold, and algae when also using it to remove a solid stain or paint
2. Cost Per Square Foot: 8
RAD PaintStrip covers 100 sq. feet for $70 per gallon. While this may seem expensive, it is much cheaper than replacing your wood and much more manageable than power sanding your wood or deck. Overall, it is a very fair price for an extremely effective product.
3. Removal of Old Solid Stain: 10
The RAD PaintStrip was tested on a deck that had a dark gray Olympic Solid Stain on the outside vertical skirting. We applied the stripper over the solid stain and let the coating sit overnight. When we returned the next day, we pressure-washed it off the wood. It removed almost all of the solid stain that was on there. Where it did not remove all was where we missed the initial application of the RAD PaintStrip. A spot repeat application removed the rest of the solid stain.
Note: Only the outside vertical skirting of the deck had a solid stain, so we used the RAD PaintStrip. The rest of the deck was cleaned and brightened with Restore-A-Deck Cleaner and Brightener Kits.
4. Ease of Application: 8
The RAD PaintStrip Gel was applied with a roller and brush. We saturated all wood that had the solid stain with the stripper. Using an airless prayer would have been easier, but we did not have one.
5. Final Appearance of Stripping: 10
The RAD PaintStrip was very effective at removing the gray Olympic Solid Stain.
Note: You do not need to use a wood brightener to neutralize after the RAD PaintStrip.
Overall Score RAD PaintStrip Paint & Solid Stain Stripping Gel: 9.2
For years, I have tested many different strippers on solid (opaque) colored deck stains with little or no success. Finally, there is a decent option to remove these coating types when they peel off your exterior wood or deck.
Manufacturer: Restore-A-Deck
Product Type: Solid Stain and Paint Stripper
Available Sizes: 1-Gallon and 5-Gallons
Coverage Per Container: 100 sq. ft per Gallon or 500 sq. ft per 5-Gallon
Application Tools: Brush, Roller, Airless Sprayer.
Deck Wood Type: Treated Pine
Deck Square Footage: 400 sq feet
The Condition of Deck: Solid Olympic Wood Stain.
If you have any questions as to the effectiveness of your deck or wood stripping project, please ask below with the name of the stain brand and type being removed. Please add a couple of pictures as well.
Will this damage a stone patio underneath the deck
No, it should not.
How many square feet of deck could I strip with a 5gal. Pail of stripper
It varies based on what you are stripping and how thick it is. 50-100 sq feet per gallon.
https://www.deckstainhelp.com/product/rad-paint-solid-stain-stripper-5-gallon/
I have a rough cut cedar deck with some weathered Defy Semi-Transparent stain. Thinking about using a solid stain. Do you think it’s necessary to sand or strip first before applying, or can I get away with good cleaning and brightening? I like your two-tone idea about solid on verticals and semi on horizontals, but I’m not going to get a color match.
When applying a solid stain, you do not have to remove all the old coating but you do want to remove what is loose and peeling. See this for tips:
I have Haden Orange Behr Solid Stain on my deck. It is peeling and looks terrible. I bought 5 gallon bucket of RAD PaintStrip. It is a very thick gel that I applied with a roller and brush. I let it sit over night (total about 20 hours) and the used my Power Washer (1700 PSI) to remove the gel/stain. It only remove 60% – 70% of the stain. I had to reapply a lot of gel and I have let it sit over night again. I am hoping for a better result this round. Do you have any suggestions?
Did you test spot it as instructed to see how thick to apply and how long the dwell time is needed? It may have been that you applied it too thin the first time.
Please post your email comment on the website to help others in the future. We cannot reply to email comment notifications.
I’ve been at this for over a week. I’ve applied the stripper VERY thick and let it work for 24 hours+. I’ve had to apply and the power wash the desk 3 times so far and I still have about 20% of the stain still on the deck. As for applying this with a airless sprayer, I do not see how that is possible, it is way to thick to go through any airless sprayer I have used. Can I thin it out? If so, with what, water? What would would the ratios be?
Did it dry out at all over the 24 hours or stay wet? Covering it with a tarp would help keep it wet. We would not suggest thinning it. Do you have some pics?
Here are the RAD airless spraying tips:
It can be sprayed with an airless sprayer. Use a minimum 0.75 GPM pump at 2500 PSI. Use 1/4″ to 3/8″ hose.
Remove all filters from both the sprayer and airless gun and use a 521 tip.
