8.7K
This post was updated on June 16, 2025
Restore-A-Deck Stain & Prep Videos
Restore-A-Deck Semi-Transparent Wood Stain is an advanced, water-based, semi-transparent stain formulation designed to penetrate deep into wood pores for maximum protection and longevity. Restore-A-Deck Wood Stain protects the wood from harmful UV rays and damage caused by water penetration. Restore-A-Deck Semi-Transparent Wood Stain is safe to use, has a low odor, and is easy to clean up with soap and water. It is ideal for all wood types including pressure-treated pine, cedar, fir, or redwood.
This collection of Restore-A-Deck Restoration videos will review the Stain and Prep products and will also include How-To Videos using the Restore-A-Deck Products.
How to Restore Your Deck all in One Day | DeckStainHelp com
How To Strip A Deck Stain | DeckStainHelp com
How To Apply A Wood Deck Brightener | DeckStainHelp com
Applying A Deck Stain to a Damp Deck | DeckStainHelp com
How To: Prepare Your Deck for Stain
How to Restore a 30 Year Old Deck
Best Way to Clean and Stain a Deck
How To: Stain Your Deck
Cleaning and Staining Decks and Retaining Wall In One Day
Subscribe to DeckStainHelp.com channel
I have a cedar deck that I used Sikkens Proluxe Cetol 1 RE on 3 years ago. I wanted to recoat it this year. My local hardware store recommended that I use Olympic Deck Cleaner which I did. Now it’s removing the Sikkens product on much of my deck. It’s loosened, bubbled or stripped in some areas and seems untouched in others. What would you suggest that I do now?
Strip it all down so the wood is bare and then brighten last. This will give an even appearance when you recoat.
Hello, I will be using TWP stain in a new fence (installed in Feb 2023) What steps should I do to prep the fence for the stain? It has no grayed at all.
Clean and brighten the wood with their Gemini Restore Kit.
