DEFY Wood Prep Products – The Essential First Step for a Perfect Stain Application
Proper wood preparation is crucial for ensuring maximum stain penetration, longevity, and overall performance. DEFY offers a complete line of wood prep products, including DEFY Wood Cleaner, Stain Stripper, and Wood Brightener, to help you restore and prep your deck, fence, or wood siding before staining.
1. DEFY Wood Cleaner – Remove Dirt, Mold & Mildew
A powerful, oxygenated wood cleaner designed to remove:
✔ Dirt, grime, and mildew stains
✔ UV-damaged wood fibers
✔ Old, gray, and weathered surface buildup
✅ Restores wood’s natural color before staining
✅ Safe for all wood types, including pressure-treated lumber, cedar, and exotic hardwoods
✅ Eco-friendly, biodegradable formula
🔹 Best For: Preparing new or lightly weathered wood before staining.
2. DEFY Stain Stripper – Remove Old Stains & Coatings
A professional-grade stain stripper that effectively removes:
✔ Old, worn-out stains (water-based and oil-based)
✔ Sealants, clear coatings, and semi-transparent stains
✅ Strips previous stains without sanding
✅ Works on decks, fences, log homes, and wood siding
✅ Fast-acting and easy to use
🔹 Best For: Removing previous stains or coatings before applying a fresh stain.
3. DEFY Wood Brightener – Restore & Neutralize Wood Before Staining
A must-use final step to:
✔ Neutralize the pH after using DEFY Wood Cleaner or Stain Stripper
✔ Restore the wood’s natural color and enhance stain absorption
✔ Open wood pores for better stain penetration
✅ Brightens and restores dull, gray wood
✅ Improves stain adhesion and longevity
✅ Essential for getting the best results with DEFY Wood Stains
🔹 Best For: New wood, stripped wood, or cleaned wood before staining.
Why Use DEFY Wood Prep Products?
✔ Prepares wood for even stain absorption
✔ Improves stain performance and durability
✔ Eco-friendly and safe for plants & landscaping
✔ Works on all exterior wood surfaces
Achieve Professional Results with DEFY Wood Prep
For the best stain adhesion and longest-lasting results, always prep your wood properly before staining. Use DEFY Wood Cleaner, Stain Stripper, and Brightener to get your deck, fence, or siding ready for a flawless, long-lasting stain finish!
