DEFY Wood Restoration Products – Restore, Protect, and Extend the Life of Your Wood
Revitalize Your Deck, Fence, or Exterior Wood with Professional-Grade Restoration Solutions
DEFY offers a complete line of wood restoration products designed to clean, brighten, strip, and protect your wood surfaces before staining. Whether you’re dealing with mildew, old stain coatings, or weathered gray wood, DEFY products ensure maximum stain adhesion, enhanced longevity, and a flawless finish.
1. DEFY Wood Cleaner – Deep Cleaning for Weathered & Dirty Wood
A powerful, oxygenated cleaner that removes:
✔ Dirt, mildew, algae, and mold stains
✔ Gray, UV-damaged wood fibers
✔ Surface contaminants preventing proper stain adhesion
✅ Safe for all wood types, including softwoods and hardwoods
✅ Biodegradable & eco-friendly – Won’t harm plants or landscaping
✅ Essential for cleaning new or lightly weathered wood before staining
🔹 Best For: Cleaning decks, fences, siding, and log homes before applying stain.
2. DEFY Wood Brightener – Restores & Neutralizes Wood Before Staining
An essential step after cleaning or stripping wood, this brightener:
✔ Neutralizes wood after using DEFY Wood Cleaner or Stain Stripper
✔ Restores wood’s natural color and removes tannin stains from cedar and redwood
✔ Opens wood pores for deeper stain penetration and better adhesion
✅ Improves stain performance and longevity
✅ Restores dull, faded, and gray wood surfaces
✅ Recommended for all exterior wood types
🔹 Best For: Prepping new, stripped, or cleaned wood before applying stain.
3. DEFY Stain Stripper – Removes Old Stains & Sealers
A professional-grade stain stripper designed to:
✔ Break down and remove old oil-based and water-based stains
✔ Strip semi-transparent stains, sealers, and coatings
✔ Eliminate the need for sanding before re-staining
✅ Fast-acting formula saves time and effort
✅ Works on decks, fences, log homes, and wood siding
✅ Recommended before using DEFY Wood Brightener
🔹 Best For: Removing previous stain layers before applying a fresh coat.
4. DEFY Composite Deck Cleaner – Specialized Cleaning for Composite Wood
A powerful cleaner designed specifically for composite decking that:
✔ Removes black mildew stains and environmental buildup
✔ Restores composite decks to their original color
✔ Prepares surfaces for DEFY Composite Deck Sealer
✅ Works on Trex®, TimberTech®, and other composite brands
✅ Safe and biodegradable formula
✅ Easy spray-and-rinse application
🔹 Best For: Cleaning and restoring composite wood decking and fences.
5. DEFY Composite Deck Sealer – Long-Lasting Protection for Composite Wood
A durable, clear finish that:
✔ Prevents mildew and black stains on composite decks
✔ Protects against moisture and color fading
✔ Fortified with zinc nano-particles for superior UV resistance
✅ Easy application and maintenance
✅ Long-lasting protection against the elements
✅ Crystal-clear finish that won’t alter the original color
🔹 Best For: Sealing and protecting composite wood decks and fences.
Why Use DEFY Wood Restoration Products?
✔ Prepares wood for superior stain adhesion
✔ Improves stain performance and durability
✔ Eco-friendly and safe for plants & landscaping
✔ Works on all exterior wood types and surfaces
Achieve Professional-Quality Wood Restoration with DEFY!
For the best stain performance and long-term wood protection, always prep your wood properly before staining. DEFY Wood Restoration Products make it easy to restore and protect your deck, siding, or fence, ensuring beautiful, long-lasting results!
🔹 Order your DEFY Wood Restoration products today and bring your wood back to life!
