Best Deck Stain for Canada 4.8/5 (106)
Hi, I am Scott Paul, a leading exterior restoration contractor and business owner with over 30 years of experience in exterior wood decking coatings. My Best Deck Stain Canada reviews and help tips are based on my history as a wood restoration contractor and actual hands-on testing, all designed to present you with the top deck stain choices. See here for more info about me.
The Best Deck Stain for Canada in 2026
DeckStainHelp.com has become the Internet’s go-to resource for wood deck restoration-related. Since this article was first released, Restore-A-Deck Wood Stains was introduced. It is a high-quality, durable, semi-transparent stain ideal for Canadian climates. Our go-to stains for Canada’s climate are:
My Top-Rated Deck Stains Canada
  2. TWP Semi-Solid LOW-VOC Stains
  3. TWP 200 Series
  4. Armstrong Clark Stains
  5. Defy Extreme Stain
Feel free to leave me a comment below with questions you may have.
TWP-Semi-Solid-Colors-Earth-Seaform
What is the Best Deck Stain for Canada’s harsh climate?
These days, choosing a deck stain considers more factors, such as the environment. Many deck stain companies are forced to comply with these tighter regulations or leave business. Areas like Canada have stricter guidelines for shipping deck stains than other areas.
Canada also has harsh weather that can wreak havoc on a deck stain. Long, hard winters and large amounts of snowfall can deteriorate an unprotected deck quickly. So, finding a VOC-compliant deck stain that will hold up to Canadian winters can be tricky. To answer the common question, “What is the best deck stain for Canada?” we will look at several brands.
Canada Requires 250 VOC Deck Stains
Canada restricts decking stains and coatings and changed its limits back in 2012. The lower VOC changes mainly affect oil-based coatings. By lowering the amount of “solvents” that can evaporate into the ozone, you need to increase the amount of “solids.” This can cause issues with oil-based stains, which may have drying and curing problems. A few good oil-based stains are still allowed but are not as readily available at your local stores. You may need to go online to find them and have them shipped. Examples would be the TWP 200 Series and Armstrong Clark Wood Stains. If you choose water-based for Canada, ensure they are a true semi-transparent stain and fully penetrating. Many companies like Behr and Valspar will lie about the opacity of their semi-transparent stains, resulting in their coatings looking opaque.
Avoid Deck Stains in Canada at Big Box Stores
Avoid deck stain brands like Behr, Olympic, or Valspar, which can be readily available at your local Home Depot, Lowes, or Menards. These brands are not high quality, film on top of the wood instead of penetrating, and are prone to peeling in Canada’s harsh climate.
Olympic and Behr Deck Stain Failures
My Top Picks for Canada Deck Stain
Restore-A-Deck Wood Stain can be applied to dry or damp wood. Applying to damp wood allows you to prep and stain on the same day, saving you a tremendous amount of time. In 2018, our first full year of using the Restore-A-Deck stain, we had zero issues with performance and saved a tremendous amount of time with the ability to prep and stain on the same day. The Restore-A-Deck stain comes in both Semi-Transparent and Solid Colors.
$49.99
$229.99$247.99
Restore-A-Deck Hardwood IPE Stain
2. TWP Semi-Solid Low-VOC Stain
Available in 30 Custom Colors, the TWP® Semi-Solid Pro-Series Low-VOC will keep your wood beautiful, fresh, and looking new longer! The ease of application and maintenance will allow you to enjoy your investment for years.
TWP® Semi-Solid Pro-Series provides a broad spectrum of weather protection, is water repellent, and aids in color retention. TWP® Semi-Solid Pro-Series resists water absorption that causes warping, cracking, and splitting and prevents freeze damage in colder climates. Use TWP® Semi-Solid Pro-Series to Restore and Protect YOUR GREAT OUTDOORS!
$73.99
5.00out of 5
$294.95
$87.99
$374.95
TWP Semi-Solid Lighthouse
3. Armstrong Clark Wood Stain
Another great choice for the best deck stain in Canada is Armstrong Clark Deck Stains. If you prefer an oil-based formula rather than a water-based one, this stain is ideal. Its low-odor oil formula is compliant with all environmental standards in Canada.
This unique formula revitalizes the wood by replacing its missing natural oils. The non-drying oils condition the wood, while the drying oils form a protective barrier on the surface. It will withstand harsh winters and ensure maximum protection in a low VOC formula perfect for Canada.
$69.95$79.95
$269.95$328.95
$320.00$379.00
$335.00$389.00
Armstrong Clark Cedar Tone
4. TWP 200 Series Stain
Another semi-transparent oil-based option for Canada is the TWP 200 Series. Containing paraffin oil, the TWP 200 series penetrates wood extremely well. Paraffin oil is a “non-drying” oil that enhances the wood cell’s structural stability, greatly improving the wood’s life and appearance.
$61.99
$234.95
5.00out of 5
TWP 1503 Dark Oak
5. Defy Extreme Wood Stain
Defy Extreme is a water-based VOC-compliant formula that is still durable enough for Canadian weather. Defy Extreme will outperform all other water-based stains on the market. This unique deck stain combines Nanoparticles and synthetic resins to produce a one-of-a-kind formula that provides optimal UV protection like no other tinted transparent wood stain.
Defy is a penetrating stain that dives deep into the wood pores so moisture cannot get in. This is an excellent choice compared to film-forming stains that stay on the surface and would not hold up well to harsh weather conditions. Defy’s high-performing, low-VOC formula makes it a good candidate for the best deck stain for Canada.
$59.99
$269.99
Defy Stain Cedartone
Need Help Choosing A Canadian Deck Stain? Ask Below!
Subscribe
Notify of
719 Comments
Rob
Rob
6 months ago
Hi Scott. You have Restore-A-Deck as your #1 choice, but in your review you say that Defy will outperform all other water based stains on the market. If that is the case, why did you choose Restore-A-Deck as number 1? It seems that Defy may also be prepped and stained in one day. Thanks,
Tammy Wilson
Tammy Wilson
8 months ago
I am taking your recommendation and have ordered Armstrong Clark semi transparent stain for my new pressure treated deck (installed last summer). My question is, is there a deck cleaner and brightner available in Canada I can buy? Restore a deck I could order if I had to.
Art
Art
9 months ago
My deck is 2 years old do I have to sand the deck before staining
10 months ago
Where can the top 5 stains be bought in new brunswick stores?
Krista
Krista
Do you recommend the Twp 200 series and the Armstrong Clark stains more than the restore a deck stain for a new deck just built Aug 2024 in Canada? My other comment below was also asking if now is a good time to stain before winter? It will only have been a couple months since we built the deck. Or perhaps we should wait till spring/summer 2025? Restore a deck was listed in your top 5 but I noticed you recommended twp & Armstrong in your comments below. Thank you so much for your help, I want to do it right the first time! 😀
Krista
Krista
We built a deck this past summer (Aug 2024)in Ontario, Canada using micro pro sienna chemically treated wood. Should we stain it now before winter or wait till spring/summer 2025? Planning on using your recommendation of restore-a-deck.
Sylvia
Sylvia
We have a deck made of fir. It has been stained a couple times, but now the wood on the one side where there is lots of sun and snow in winter is looking grey and black. What should we do to restore it?
Debbie Bennett
Debbie Bennett
Great information you have provided. I live in Canada and want to stain my treaded wood deck than is now one year old. What is your recommendation for the type of stain I should use with our harsh winters and strong uv from sun. I do not want it to peel. I like the semi transparent look. Is it best to use the twp semi solid pro series to resist water, warping, cracking and splitting in our cold climate? or would you suggest the twp 200 series stain that is a non drying oil? Also do i need to wash the deck prior with any type of cleaner prior to staining it? Also is this a good month September to treat my deck Looking for your professional help. Thanks
Debbie Bennett
Debbie Bennett
thank you so much
Kirsten
Kirsten
Hi. I used Ready Seal for my fence and it still looks great after 2 years, What are your thoughts for using it on a deck? It’s hard to find any ‘non-boxstore’ stain locally.
bob
bob
where can I purchase the Restore-A-Deck in Canada
J Hencher
J Hencher
My question is about restaining when needed. The trouble with refinishing decks is that while a lot of the old stain peels away easily, some always stays behind and prevents new product from sticking/penetrating. Ideally, I’d like a product that I can use now, then reapply in a year or two with maybe just a quick power wash and light sanding. Will the products in your “Best stains for Canada” behave like this? Thanks
Tim B
Tim B
Do you ship to a P.O. Box (e.g the UPS Store in Ogdensburg, NY)?
James Mctaggart
James Mctaggart
This is the deck right now
17162314588205382923758782786424
17162314948055085269924168405745
17162315213255220102982204200342
James Mctaggart
James Mctaggart
Ok. I like it. Starting to check out some of your suggestions for stains .
Jim Mctaggart
Jim Mctaggart
Got a question for you guys. We bought a can of behr deck stain and sealer. The previous year it was sanded and stained a couple of women doing nothing but decks. Last year I resanded the deck , reapplied more deck stain due to the fact it was peeling. This year it is peeling again and I will have to redo it again. Please is there something that I have missed in the process.
DIY-er
DIY-er
What is your recommendation for a semi transparent oil stain for a new cedar pergola? Preconditioner?Life expectancy? We live northwest of Edmonton Alberta.
Sandra Frost
Sandra Frost
We rebuilt a large dock and deck at the waters edge and spent probably around $800 dollars on Thompsons Water Seal stain only to have it peel and come off in many areas the first winter and this winter, the second one even more has come off. Staining all sides of the wood was a huge undertaking and not something that I want to have to do every spring. What product do you suggest I order, one that will last and do I need to sand the wood first and add a sealer after I restrain?
Thanks so much
Sandra
Carl
Carl
What’s the best stain we can buy in Canada rather than shipping from US? Shipping costs are very expensive.
Carol Sullivan
Carol Sullivan
The best wood stain for Vancouver Island that has mold kill or protection from mold?
John Warner
John Warner
We have a older deck that has had oil based stain in the past (Cutex). We want to switch to a semi-solid or solid color and have been looking at your 4 recommendations. Restore-A-Deck and Defy are water based. TWP 200 series is semi-transparent (their other products don’t ship to Canada). Armstrong Clark has only two colors that could possibly work with our current house siding and deck railing. Do you have the next 4 best in the list?
Beth
Beth
umm, the question is best deck stain that we can actually legally GET in Canada, please… at very best, we could mail order some of these ideas, but Ottawa has made sure we can’t buy them… it sure would be helpful if you ranked what we CAN buy… thx
Anita
Anita
what are your reviews on CUTEK stain for decks?
Lauren Brown
Lauren Brown
Where can I buy Armstrong Clark deck stain in Ontario
Shawn
Shawn
It will cost me $150 to have a gallon of Defy stain shipped to my house. Is it that much better than a stain that I can get much cheaper at a local paint store?
Shawn
Shawn
I appreciate your help I ordered 3 gallons of Defy stain. thank you
Shawn
Shawn
This site says best deck stain in Canada and features Defy stain as there forth pick and you cannot get this in canada.
Claire Warren
Claire Warren
What are the advantages and disadvantages between a water-based stain and oil-based stain? Is one better than the other?
Marc
Marc
Hi Scott, We just bought some white pine for my balcony and would like to know the proper product to apply. We applied sherwin williams super deck semi transparent stain and were not satisfied with the look. Before installing them I want to know if we can apply a solid stain on top and what product do you suggest? I was told that some solid stains do not apply well on white pine.Thank you.
Marc
Marc
Thanks for your response.
jerry
jerry
longest lasting solid oil stain for West Coast Canada, Deep Cove area
I have stripped and clean my 19year old deck and want to restain it. What is the best brand of semi-transparent stain available at retail stores in Canada. Olympic, Behr, Beautitone, Benjamin Moore, Thompsons……
Shengrong
Shengrong
Where can I order TWP200? I live in South Ontario. I cannot find where to order. What other band would we use? We would like to use transparent, or semi-transparent (nature) stain. Thanks.
Sandy
Sandy
How can you say TWP is top rated for Canada if it is not available to purchase in Canada ? I need to know where to purchase these top rated deck stains.
Wilmer
Wilmer
where can I buy it?ì
1 4 5 6
719
