3.3K
This post was updated on February 21, 2024
Best deck stain for IPE wood?
Like other exotic hardwoods, it is best to use a semi-transparent penetrating deck stain for IPE wood. A semi-transparent deck stain developed specifically for exotic hardwoods will penetrate the wood appropriately to protect it over the course of a year. Exotic hardwoods like IPE wood do not soak up the deck stain as well as other hardwoods. The two best brands of semi-transparent deck stain for IPE wood are Restore-A-Deck and Armstrong Clark.
#1 Best Hardwood Deck Stain | #2 Best Hardwood Deck Stain | #3 Best Hardwood Deck Stain |
From: $47.99 *Free Shipping | From: $79.99 *Free Shipping | From: $99.99 *Free Shipping |
More information about deck stain for IPE wood
- IPE Exotic Hardwood Stain Review
- Hardwood Deck Stains
- Hardwood Deck Stain Tips for Ipe
- IPE Staining Instructions
- IPE & Exotic Hardwood Stain Video Reviews
I have an ipe wood deck about 1000 square feet. Used Restore a Deck which said to wet the wood slightly before applying. It now shows every paw or footstep. I want to resand and restain with a different product. I am in San Diego. CAn you assist in pros and cons of TWP vs Armstrong-Clark vs Cabot oil vs Messmer’s. I want it to be a beautiful light walnut like stain. Thank you in advance for your help! Enid
TWP Natural Effect has the longest UV and color protection for IPE. RAD stain and AC stains are the following best brands out there for IPE. Messmers would be a distant 4th. Cabot is a poor stain.
A couple questions:
1) is it typical to need to reapply stain to a Brazilian Ipe wood deck annually?
2) once the Ipe deck is stained, how long does it take the stain to dry?
1. Yes.
2. Varies based on the stain brand you end up using.
Does an IPE deck need some type of sealant after staining with the Armstrong-Clark stain? Thank you.
No and you can never apply a sealer over a deck stain. It would peel.
We have several items that need to be stained and protected to preserve the original look. Both projects are Brazilian Ipe wood based.
The first items are Jensen outdoor furniture, which incorporate Ipe wood into their designs. We used their recommended Penofin based restoration process and are extremely unhappy with the outcome. It faded extremely quickly and needs to be removed and refinished.
The second is a brand new Ipe deck that we do not want to make the same mistake (use of Penofin).
How do you recommend stripping the Penofin?
Is it the same as other recommendations you have suggested? To strip with Restore-A Deck Stripper and Brightener kits.
I assume I just need to clean the new deck and not brighten (the new deck color is beautiful as is).
Can I then simply use the Restore-A Deck Light Walnut on all pieces and surfaces?
Yes, strip the Penofing and Brighten:
See here about new wood:
Great!!
A follow up question … must the stripper be removed with a pressure washer. Is a strong regular spray enough. What pressure do you use?
I want to make sure I do not damage the non-wood portion of the furniture.
Pressure wash off.
