Hi, I am Scott Paul, a leading exterior restoration contractor and business owner with over 30 years of experience in exterior wood decking. My Review of the DEFY Extreme Solid Color Wood Stain is based on my history as a wood restoration contractor and actual hands-on testing, all designed to present you with the top deck stain choices. See here for more info about me.
Defy Extreme Solid Stain Review 2025
This is my initial Review of the Defy Solid Color Wood and Deck Stain, which will be updated throughout the years. The Defy Extreme Solid Stain is an excellent choice for solid-colored wood and deck stain. As always, we appreciate your input, so feel free to leave a comment below and pictures of your completed projects using the Defy Extreme Solid Stain.
Defy Extreme Solid Color Wood Stain Review
Summary: DEFY Extreme Solid Color Wood Stain is a synthetic-resin, opaque wood and deck finish that helps protect exterior wood surfaces against water, mildew, mold, algae, and UV radiation.
This V.O.C. compliant water-based product provides a beautiful finish, fortified with transparent “oxide” based Nano Particles. Over 30 TRILLION nano-particles per square inch provide extreme protection for your wood by blocking out the sun’s harmful UV rays, moisture, and fungal growth.
How I Rated DEFY Extreme Solid Color Wood Stain
My DEFY Extreme Solid Color Wood Stain review contains a 6-step process and the final average score. Each step is on a scale of 1-10.
- The appearance after the Application
- Peeling or Wearing
- Preventing Mold and Mildew
- Ease of Reapplication
- DEFY Extreme Solid Color Wood Stain Final Score
6-Step Review of DEFY Extreme Solid Color Wood Stain
The DEFY Extreme Solid Color Wood Stain in the custom-mixed Redwood color has a beautiful finished appearance. Coverage was excellent, and the grain of the wood was completely covered, which is the nature of solid opaque stains.
2. Wear/Tear and Peeling: 9
At the 1-year mark, there was no peeling anywhere. Little to no wearing was visible.
3. Cost Per Square Foot: 8
We applied two coats to our 600 sq. feet of verticals including all railings and steps. 4 Gallons were used at a cost of $60 per gallon.
4. Preventing Mold/Mildew/Algae: 9
After 1 year a slight area of green algae was detected in a shaded area of the deck but seemed to only be on top of the stained surface. This seemed to be more of an issue of the deck’s location than with the actual stain.
5. Ease of Application: 8
The DEFY Extreme Solid Color Wood Stain is easier to apply than many of the solid color deck stains that you can find in big box stores. Using a staining brush or roller is best for efficient coverage. We applied both coats, waiting about 20-45 minutes between coats.
6. Difficulty of Reapplication: 8
Pressure wash to remove all dirt and grime using a deck cleaner. Let dry and reapply 1-2 coats of the solid stain. No need to strip off, remove any loose stain prior to reapplication.
Overall Score Defy Extreme Solid Color Stain at 1 Year Period: 8.5
The DEFY Extreme Solid Color Wood Stain is a great solid stain and shows lots of promise. It is newer to the market, but that does not mean you shouldn’t consider it. Advances in technology mean that durability is better now than previously.
Product Information
Where to Buy: Defy Solid Color Wood Deck Stain
Cost: $59.99 per Gallon, $299.99 per 5-Gallon
Stain Type: Solid Color (Opaque) Wood Stain – Water Based
Available Custom-Mixed Solid Colors: 7 Stock colors and can be custom-tinted to any color.
Coats Required: 2 Coats
Application Tools: Airless Sprayer, Brush, Roller
Dry Time: 2-4 Hours
Cleanup: Water
Manufacturer: SaverSystems
Test Deck Stats
How Many Years Tested: 1 Year
Stain Color Used: Barn Red
I used Penofin on my new cedar deck 2 years ago. It didnt hold up that well and after only one year showed dark spots of tannin or mold. Anyways I dont want to use it again as I find the extra steps of brushing and then wiping off are not really worth it. Can I still use TWP if I properly prepare my deck and what should I do. Stip ? Sand ?
You can use TWP stains as long as you strip and brighten for prep first. Look at the Restore-A-Deck Kits.
I have an older deck 20+ years several coats of solid Sherman Williams Deckscape. Mid Atlantic East coast weather with months of rain and snow.Usually mild but humid summers. The area under cover hold up well with no peeling . The exposed deck begins to peel after one year or so .Deck has been power washed and sanded I plan to power wash once again to thoroughly clean deck. Paralyzed by my next step. Should I have stripped the deck…? Is there a better product that I should use or is it best to apply the same product over the existing product.
See here for the best solid stain options: https://www.deckstainhelp.com/what-are-the-best-solid-color-deck-stains/
I just left a comment I am looking for a good Solid stain in white for a fence.
Look at using the Restore A Deck Solid stain in white: https://www.deckstainhelp.com/restore-a-deck-solid-color-stain-review/
I know this is for decks but Would you know of a good skid stain in white that is good for wood fence. I am looking everywhere and when I reread reviews many just are not good.
Yes, works great on fences.
I’d like to use Defy Extreme solid wood stain on my aging deck. Does it require a separate sealer as well?
No, and you cannot apply a sealer over a deck stain. It would peel.
I am planning to re-paint the porches on my mother’s house. There is a large downstairs front porch with a smaller upstairs front porch that both face South, then a small side porch that faces East. The decks on these porches were replaced about 5 years ago, and painted at the time (I’m thinking they were not primed, it doesn’t look like it), but the paint has nearly completely worn off in places because of sun exposure. I was considering the Olympic Rescue-It product, but see that people have a lot of complaints about its wear. I plan to put in the time needed to prep: scrape, use a cleaner, power rinse, and sand, etc. What produce would you recommend that might stand up to the sun?
Try the Gulf Deck Revive products.
thank you
I have an 27 year old deck in full sun and it has been stained several times. It shows sun damage with cracks and splinters. I have power washed it and got a lot of the old coating off. Anything that stayed on is well adhered. I read the many reviews and listened to your talks and think it is a toss-up between Defy -Extreme solid color wood stain and Gulf Synthetics Deck Revive. Do you agree with my choices? Is one more tested than the other (both seem very new with no longevity data)? Your data indicates the Defy product is available from Do-it-Best stores. I have no idea of where to get the Gulf product (the outlets in their web site claim never to have heard of the product and they did not return my call or e-mai). If you think my best choice is the Gulf product, where do I get it?
Gulf has been around for 7-9 years. Defy Extreme Solid has been around 3-4 years. Both are excellent. You can buy the Gulf directly from their website. https://www.gulfsynthetics.com/
Hi! We planned a two toned solid stain deck with restore a deck ( espresso and white). We did the top railing and floor first, I know not ideal but that’s what had to happen. It came out great! However, I just started a few spindles and the white Restore a deck barely barely shows up. It will take five coats to even look white. Is there a different product you would suggest here? Maybe a deck paint?
No, paints peel. When applying a white solid stain over a dark brown stain, you will need a few coats to cover it fully. You could try a primer first and then the RAD solid stain for the spindles. Normally we would not suggest this but it is vertical wood so it should have no issues.
Ok thank you for the advice! Any primer suggestions that would work with the RAD solid? Or does it not matter too much?
Also would you tape off each spindle or just eye ball it? I was taping off but it seems it’s going to peel off tiny bits of the RAD solid I already put down on the floor and base. Ugh!
Thanks in advance!
Not sure it matters with the primer. We never tape. Just carefully apply and wipe any drips with a wet cloth ASAP.
I sanded as much as I can as below in the picture. I am going to use the defy solid stain. I blow dry all the sand. Can I just use defy solid stain now? Do I need any cleaner or brightener before?
Give it a good pressure wash rinse and then you can stain.
Can I apply defy extreme solid stain to a well cleaned and prepped deck that still has some old Behr solid stain that is not loose or peeling?
Yes, you can.
I looked at the products on the Defy website, and I Google searched for their solid stain. Plus I looked at Do-It-Best stores (as suggested in Defy website), but I can not find solid stain products anywhere. I’m mystified. Please help.
Try the Restore A Deck Solid sTains if you cannot find them locally: https://www.deckstainhelp.com/restore-a-deck-solid-color-stain-review/
I just finished staining my deck with Defy solid stain, my grandson wanted to help so I gave him a brush and turned him loose on the steps. He did his best but after the steps dried, I see a lot of brush marks. My question is do I need to wait a certain amount of time to recoat these, or can I do it now? P.S, I did tell him he did a good job! Thanks for your help.
You can recoat it now.
Where can you buy Defy solid color stain? I can’t find it anywhere
They have to be custom mixed in a store. Check with Defy directly for help with this.
If you are looking to buy a solid stain online. Look at RAD Solid Stains as they have pre-tinted colors.
Hey, love the site. I want to apply the Defy solid stain to my deck, as I want a product I can just wash and reapply as needed down the line. The current stain is a few years old and is starting to flake. Problem is I’m not sure what type of stain was used. It’s on the vertical and horizontal surfaces of the deck. Attached some pics. With the current stain, would I need to strip and/or sand it off? Or would I be able to just clean and scrape any loose stain and apply over it? Tried testing some 80 grit sandpaper manually on the stain and it doesn’t budge. Thanks in advance!
That is a solid stain. Use a stripper and pressure wash to remove the loose stain. Let dry and spot sand if needed to remove anymore loose stain. Cover the intact stain with a new solid stain.
Thanks! Would I need to use a brightener after stripping what comes off before applying the new stain?
Yes, you have to brighten after to neutralize the stripper.
I’m applying Defy Solid stain to my cedar deck railings and posts. Do I need to apply the second coat before the first coat is entirely dry or do I wait for first coat to dry and then apply second coat? Thanks!
The second coat has to go on wood that is fully dry.
And second coat should go on the same day as the first coat?
I am going to redo my deck and have decided on using Defy solid stain. I am confused on the sq. ft. per gallon I will get. I see different sq. ft. per gallon talked about and they are different, Defy says to do two coats so how much would I need to do a 900 sq. ft. deck with two coats? Also, I will use RAD stripper and brightener, how much of that do you recommend? Thanks for your help.
About 7-9 gallons for two coats. 1-2 Packages each of the RAD Stripper and Brighener.
I want to add a custom color (Benjamin’s Moore) paint to stain for exterior treated lumber. Can this be done?
No.
You can’t add paint to the stain, but you should be able to find a paint retailer that can tint the stain to a Benjamin Moore color.
That will not work with Defy Extreme stain.
It can be done if a paint retailer has access to Ben Moore formulas that can be mixed using universal colorant, which is used to tint Defy solid stain. I am a retailer who sells Defy and also sells Ben Moore paint and we have done just this. Love the site btw
I have been staining with SW solid Deckscapes, and I don’t want to waste my money on this stain again. I have been prepping for another coat of solid stain, but did so before reading this site. I pressure washed the deck to remove any lose, peeling stain, then sanded pretty much everything with a belt sander using 80 grit, and then pressure washed using Zep multipurpose cleaner and scrubbed the surface before rinsing. I am probably going to apply Defy Extreme solid stain and try to match the original colors, but want to make sure that the deck is properly prepped so it adheres correctly. I’m attaching a few picture of the deck and ramp as it looks right now; the ramp has only had stain applied once, so it cleaned up better than the deck.
Should I use another cleaner and/or do any additional prep work before applying Defy Extreme solid stain? Thanks for your advice.
As long as the stain that is on the wood now is intact and not peeling, you should be okay to cover it with the Defy solid stain.
Appreciate the response…. I called all of do-it best store near me and unfortunately none of them sell Defy, so now I am considering RAD or Flood.
In either case, should I use a deck stripper and/or brightener before staining, or are these steps not required when applying solid stain over solid?
Yes, you should strip and pressure wash to remove any loose and peeling solid stain. Brightener after.
Appreciate… since I am attempting to remove SW solid stain, would you recommend that I use SW Superdeck stain & sealer remover and follow up with SW Superdeck revive; or should I use something from RAD and/or another strip/brightener product? Obviously not all of the solid stain will be removed and I will follow up with solid stain; just want to try to avoid peeling in the future.
To remove as much as possible your best option would be the RAD Stripper with both additives.
Thanks again… any chance you can advise me on how much of each RAD product to order? I want to ensure that I don’t order too much, or too little of each of the required products, including stains.
I am attaching an image of my deck with dimensions and color layout. I have 405 sf of decking which will be desert taupe and 81 feet of railings/spindles plus the steps and support posts which will be expresso. Although I plan to use the stripper on everything, my main concern is with the decking surface, since the railings and spindles aren’t peeling much. I live in the Dallas area so it’s probably going to be too hot and sunny to stain the deck, but I’d like to get the existing stain stripped since I already started the project. If I strip and brighten the deck now, will I need to use brightener again before staining in a few months, or just give it a good washing before staining? Again, thanks for your advice.
One of the RAD Stripper/Brightener Kits and one bottle of both stripper additives.
Probably 2 gallons of stain for the railings and 4 gallons for the floors.
You will have to clean again if you wait two months after the prep to stain. Pressure wash should be fine.
I really appreciate your willingness to answer all of my questions…
Once I get this project done, I will post some before and after pictures.
one more question… 2 coats of stain on everything?
Yes, that is correct.
How is the Defy solid stain for grip/slipperiness of the deck surface on 1-year old boards? I don’t know what it is, but the stain my in-laws used is treacherous so that was my wife’s first question.
We have never had any issues or complaints.
Here’s the pic of the deck I’m referring to in my comment below.
Should I use Defy Extreme Solid or Restore a Deck Solid on this deck? Also can I just use deck cleaner and power wash before staining or do I need to strip ?
Strip what is loose and peeling is best. Either RAD or Defy would work well.
I applied two coats of DEFY Extreme Solid Color Wood Stain on my treated lumber deck after cleaning and using DEFY Brightener as directed. The deck sat for a year to let the treated lumber dry out thoroughly. I used White/Pastel base untinted for the vertical surfaces and a gray tint for horizontal surfaces. Two days after staining, we had a freak snowstorm. Several inches of snow fell and remained on the deck until melting a day later, leaving standing water in several places until it dried about a day later. After the deck dried, the gray stain had faded wherever there was standing water that dried. Even on the vertical surfaces where water ran down, the white stain was faded enough to see the natural wood color coming through. Any advice on what I should do? Should adding more coats of stain eliminate this problem?
That is tannin bleed coming from inside the wood. Tannin bleed is a tan or brownish discoloration on the paint surface. Tannins exist in all deck woods, most notably pine, cedar, and redwood, and can bleed through to the surface, leaving a yellowish-brown stain on the surface. These stains are more noticeable in lighter paint colors.
Tannin bleed is an underlying wood problem, not a stain failure, and happens when in a very wet climate. Tannic acid can discolor the stain as the wet wood pushes the stains out towards the surface.
Try applying another coat.
I have a 300 sq. ft. pressure-treated deck that is one year old and am debating whether to use Defy Solid or Defy Semi-Transparent stain on the horizontal surfaces. The deck is in full sun, no trees, and we are in the mid-west, so we can get hot in the summer and very cold in the winter. I think I would prefer the look of the solid, especially since we would be able to choose any color to custom tint. Which product should last the longest and be lowest maintenance, assuming proper treatment prior to staining? Should I be able to apply a single maintenance coat every couple of years with the solid after removing any loose stain without further prep work?
They will last the same on a deck. Both need to be cleaned and re-coated as needed.
Our pressure-treated deck was stained with Defy Extreme semi-transparent 5-6 years ago and now is mostly worn off of the floor. We are thinking of switching to Defy solid stain. Will the old semi-transparent stain need to be completely stripped (including railings / pickets) before applying Defy solid stain?
Just use the Defy Wood Cleaner and pressure washing.
Just to clarify…..If any existing semi-transparent stain isn’t worn off (such as on railings), it’ still OK not to strip it before applying solid stain?
One more question, I think….Should brightener be applied after cleaning? (I noticed brightener is recommended on the Defy solid stain instructions).
I have a 20 yr old pressure treated deck that was previously stained with semi-transparent stain many years ago. The stain is very worn. I live in Minnesota and my deck faces south. What stain would you recommend using on an old deck?
Strip and brighten for prep to remove the old stain. Do you want a solid stain? If so, the Defy Extreme Solid stains are excellent. If you want a semi-transparent, try one of these: https://www.deckstainhelp.com/best-semi-transparent-deck-stain-reviews-2020/
Thank you. I’ve cleaned the deck and there is no flaking or peeling. The old stain is a PPG semi-transparent. Can I cover with a Defy or TWP semi-transparent that is the same color without strip/brightening? Does a semi-transparent last longer than a solid?
No, you must remove the previous coatings when switching brands of semi-transparent. ST lasts about the same as a solid stain.
Our deck was previously stained with Flood CWF solid stain. The wear pattern has no peeling or flaking. After cleaning and drying, can we cover with Defy extreme solid stain?
The Defy website does not show solid stain. Using search has no results. https://www.deckstain.com/wood-and-deck-stains.html. Is it available in California?
Check with Do-It-Best hardware stores. I believe they carry it.
I have a deck rail on four balcony porches. The top rail is a 2″-x 6″ horizontal flat supported by 1×1 posts spaced every 6″ and a 2″ x 8″ horizontal base board. Wood is prob 10-12 yrs old and was painted with white Behr Alkyd Semi-Gloss Enamel paint in Oct 2019. That went on top of the previous layer of unknown Sherwin Williams white latex paint that was sanded but not removed. It was frosty mornings in October and we now realize that the wood must have still been wet later in the day when it was painted. Ouch. QUESTION: I have scraped and sanded the railing horizontal surfaces to bare wood in some spots, but still have layer of sanded paint in others. Can I apply Defy Extreme Solid (Bright White) on top of this after a week of drying in the sun? Will that give me at least 2-3 years before flaking? These rails are decorative only and get no foot or hand traffic, but are fully exposed to Seattle wet winter. (Photo is before scraping/sanding.)
No, you cannot apply a solid stain over a paint. You would have to sand it down to the bare wood.
We have an older VERY LARGE 3-level deck, railings, and steps all with pressure-treated pine and with lots of Sun exposure in a hot, humid southern state.
Re-finished several years ago with Wolman “Durastain One Coat” Solid Color Stain in custom Chestnut Brown. Looked great for 2 years.
All vertical surfaces still OK..
Horizontal deck boards look awful. Paint peeling and boards splitting in areas with full sun. However, deck boards in a few shady areas are mostly OK.
I would like to replace worst deck boards with new P-T pine, and turn-over existing that may be usable.
I think I would like to use DEFY or FLOOD PRO Solid Color Stain in custom color to repaint entire deck.
So, 70% of deck boards will be new and 30% will be flipped old ones.
Is thorough pressure washing sufficient before new finish?
Any pre-treatment needed for new deck boards?
Also concerned about possible rain before 2nd coat.
Pressure was first for prep. Let dry and spot sand any loose or peeling paint. You can then cover the interact stain with a new solid stain. We like the Defy better than the Flood.
Hi! I live in Arizona and it is extremely hot right now. I would like to use this product on a new deck due to it’s UV protection and ease in application. Can it be applied to wet/damp wood? I plan on rough sanding and pressure washing it first. I figure the wood would be somewhat cooler if wet, or do I need to let it dry completely first? Thanks!
No, it is not designed to be applied to damp wood.
1125 sq ft of 17-year-old sun-faded covered porch and 925 sq ft 2-year-old semi-transparent stained pool deck along with railing around pool deck (sq ft unknown on railing/spindles).
I want to go with a solid light blue color for everything. I’m concerned because every solid stain I have read reviews on shows awful peeling after 1-2 years (Sherman, Olympic, Valspar, Cabot). I was told by my contractor to make everything match (because of wear difference between the deck and porch) my only good option is solid stain. I’m concerned that after a few years it will be a regrettable decision though. (The contractor will be doing the work)
Is this the right product for the job?
How many gallons should I purchase?
Defy Extreme Solid stain is very good and will work well. About 8-10 gallons for two coats.
Our contractor has used 20 gallons and asked us to get him 10 more. I sure hope 30g does it because this stuff is expensive.
We are trying to strip off old stain from deck with all Defy products to put on a Defy solid color extreme stain. Just can’t seem to get the latest coat, a darker brown off, have tried sanding also on few boards. Drops of water seem to soak in on the few places that are down to wood, but not on the wood where stain will just not come off. Use, deck stripper and low pressure washer, just won’t budge! About to give up. Help! We are in our 70s, have plenty of steam left, but this has us stumped. We used the cleaner first.
You do not have to fully remove the old coating if you are going to use a solid stain.
The previous owners used Behr Deck Over. The deck boards/stairs have been professionally sanded to bare wood and look great. I lightly sanded the railing and no paint is chipping. The paint on the spindles is textured but completely in tact and tight to the wood. Can I use your product over the spindles and railing? Thanks for getting back to me.
No, it is not possible to apply a different coating over the Behr Deck Over. It will fail if you do.
If a previous Deckover coating had been applied 7 years ago and now belt sanded to roughen up the surface and peeling scraped off why can’t your solid stain work? I was not told about this and have just received a 5 gallon bucket.
No, it has to be fully removed. No other brand of stain can go over the Deckover unless you fully remove it.
How does one get the Defy Solid deep base tinted?
At the paint store that sells the Defy solid stain.
Is Defy extreme solid cedar color stain best choice for lap cedar siding on home in northeast mich area 49777 damp near lake Huron environment….Thanks
It would work well.
I am interested in a semi-solid look but want to stick with Defy product, because that is what I have used as previous stain. And a ready made product like Arborcoat has too many negative reviews. Would it be feasible to ‘thin’ down this solid stain enough to create a semi-solid look? I contacted Defy, and they did not have any comment on thinning it out other than, ‘let us know how it turns out’.
No, that is not possible.
Are all colors of a reddish hue or do they have a dark brown?
A solid stain like this review can be tinted to any color you want.
Can Defy Extreme Solid be applied on a surface that has previously been stained with a semi-transparent stain?
As long as you prep correctly by removing any dirt and loose/peeling stain.
Good Day,
I am looking for a solid stain for an existing deck that I stained 2-3 years ago. The deck is in full sun. Being a senior I do not want to do any extra work except putting the stain down.
1. What product would you recommend?
2. Secondly, my deck is 400 sq. ft. How many gallons would I need?
3. Would I have to put 2 coats down?
Gerry
1. This product would work very well
2. Depends on the brand you choose but 3-5 gallons.
3. Yes
Does new smooth cedar siding have to age before using Defy solid stain?
Yes, all new wood has to be weathered and prepped: https://www.deckstainhelp.com/staining-a-new-deck/
Can this stain be applied over a previously applied water-based stain.
No, you have to remove the previous stain.
Hi there. I see that in your review here the DEFY Extreme Solid is quoted as covering 150-250 ft/Gallon. However on their product page it says 100-150ft/Gallon – https://www.defywoodstain.com/product/defy-extreme-solid-color-wood-stain/
Was the 150-250 based on your experience of actually using the product? It looks as though you were able to cover 600sq ft with 2 coats using 4 gallons, which according to their spec would have required 8 gallons..?
I’m re-covering a deck with an existing solid brown stain and will be using the DEFY extreme in a similar if not slightly darker color of brown.
The second coat always spreads about twice as far.
Where can I buy DEFY Extreme Solid Color Wood Stain near me 60915 60 miles south of Chicago IL
Check with Defy.
Are Defy Extreme or Restore-A-Deck available in any stores in Canada?
I would suggest checking with them directly.
Can I apply defy solid stain over a previously applied solid stain that I have power washed and sanded
Yes as long as the old stain is not peeling.
I painted my huge deck last year with olympic and now it’s peeling!!! It’s a cottage gray color. I have washed the deck down. If I lightly sand where there is peeling can I apply defy?
Yes as long as the current stain is solidly intact to the wood.
hello, ive been reading many posts here and appreciate all the help and had a few questions. We bought a house with a weathered deck that seems to have been stained previously with a solid stain and now is peeling off. Deck is roughly 10-15 yrs old as the house is 15 yrs old and i dont believe the deck was built with the house. I have been able to remove some of the peeling with a pressure washer and was going to attempt to remove more of the stain with a combination of deck stripper and sanding
1 – would that be sufficient enough to remove the old stain or is there other options?
2 – am i now limited to only solid color staining as semi-transparent would most likely show the old stain?
3 – am able to stain over with another solid stain such as the defy solid color stain if i am not able to remove all the stain such as with the vertical rails?
3 – is there a stripper that is recommended for removing solid stain specifically or are they all for stains in general?
i know that it will be time consuming to remove the old solid stain but would rather put time and effort into correctly removing and staining 1 time and just up-keeping from there. Thanks for your help and input
Post a picture.
This is after the first pass with a stripper, the stain is still really hard to remove even with using a pressure washer
You cannot strip solids stains effectively. You will need to power sand to remove it down to the bare wood. Covering over this without sanding may leed to more peeling.
After I power sand it, am I able to use a semi-transparent stain afterwards? Also should I use a 60-80 grit and then progress to smoothen such as a 160 before staining?
If you remove all, yes.
Should I use a 60-80 grit and progress to smoother such as a 160? Would the pores not open if smoothened to accept the new stain?
No. 60-80 grit is the max grit. No finer.
Ok great! Thanks for all the advice!
Last summer was so rainy I missed the window to restain my 1,500 sq. ft deck, treated pine, gets full sun daily until late afternoon.. I use a solid color stain and like the look. Parts of always peel so it has to be scraped and redone every other year. If we get another rainy spring and summer does the deck have to be bone-dry to accept a water-based solid color stain? If I start over this year and sand it down, what would the optimal weather/sun conditions be and the best brand solid color stain to get a deck finish that doesn’t peel? I’ve been using Olympic but not thrilled.
Thanks for any advice.
The Defy Extreme Solid stain is a great stain and will work very well if you do the proper prep.
And as to the first part of my question, does the deck have to be bone-dry?
