This post was updated on May 8, 2025
Evaluating Cabot and Behr Deck Stains: Are They the Best Choices?
When it comes to selecting a deck stain, many homeowners gravitate toward readily available options at big box retailers like Home Depot and Lowe’s. Among these, Cabot and Behr are popular choices. However, both brands have exhibited performance issues over time, leading to questions about their long-term efficacy.
Common Issues with Cabot and Behr Deck Stains
Despite their widespread availability, both Cabot and Behr deck stains have been associated with several durability concerns:
Premature Wear and Peeling: Users have reported that these stains tend to wear out and peel sooner than expected, especially under harsh weather conditions.
Inconsistent Color Retention: Over time, the stains may fade unevenly, leading to a blotchy appearance on the deck surface.
Mold and Mildew Growth: Some formulations have been noted to be susceptible to mold and mildew, particularly in shaded or damp areas.
These issues suggest that while Cabot and Behr stains are accessible, they may not provide the long-lasting protection and aesthetic appeal that homeowners desire.
Alternative Deck Stain Options for Enhanced Durability
For those seeking more reliable and enduring deck stain solutions, several professional-grade products have demonstrated superior performance:
TWP 100 Series: An oil-based, semi-transparent stain known for its deep penetration and excellent UV resistance.
TWP 1500 Series: Designed for areas with stricter VOC regulations, this series offers similar benefits to the 100 Series with improved environmental compliance.
Armstrong Clark Wood Stain: This stain combines oils and resins to provide both conditioning and protection, suitable for a variety of wood types.
Restore-A-Deck Wood Stain: A water-based stain that allows for same-day cleaning and staining, offering convenience without compromising quality.
Defy Extreme Wood Stain: Utilizes nano-particle technology to enhance UV resistance and prevent graying, making it ideal for decks exposed to intense sunlight.
These alternatives not only address the shortcomings observed with Cabot and Behr stains but also offer additional benefits such as easier maintenance and longer intervals between reapplications.
Conclusion
While Cabot and Behr deck stains are commonly found in major retail outlets, their performance issues—ranging from premature wear to susceptibility to mold—raise concerns about their long-term value. Homeowners aiming for durable and aesthetically pleasing results may find better satisfaction with professional-grade alternatives like TWP, Armstrong Clark, Restore-A-Deck, and Defy Extreme. Investing in these high-quality stains can lead to enhanced deck longevity and reduced maintenance efforts over time.
Behr Deck Stain Failures
| Feature | Behr Deck Stain | Cabot Deck Stain |
| Availability | Home Depot (exclusive) | Lowe’s, Ace, Menards |
| Base Type Options | Mostly water-based | Oil- and water-based available |
| Ease of Application | Difficult to apply evenly | Applies more easily than Behr |
| Dry Time | 4–6 hours between coats | Varies by formula (6–24 hours) |
| Durability | 1–2 years before peeling | 1–2 years before peeling |
| UV Protection | Moderate | Moderate |
| Mold/Mildew Resistance | Fair | Fair to moderate |
| Consumer Ratings | Mixed to poor | Mixed to average |
| Best Use Case | Budget DIY projects | Light-duty decks or fences |
More Info on Will Deck Stains Peel
Have a Deck Stain question? Ask in the comments below.
Hi, I just had a new redwood fence installed. How long should I wait for the wood to weathered? When I stain the fence I would like to go with a transparent redwood stain like TWP100. I’m located in Morgan Hill, CA.
See here about new wood. https://www.deckstainhelp.com/how-long-should-you-wait-to-stain-a-new-deck/
You would need the TWP 1500 Series for CA.
Just put a new deck up with pressure treated pine August in Michigan should I wait till spring to stain with semi transparent stain
See here about new decks.
MInWax stainable wood putty: Is there a way to cover it with a transparent stain? Seems that only solid stains will do the job.
I have a new standard pine deck floor with alot of knot holes that need to be filled. I filled a few before I realized the problem.
No, wood fillers never work well for decking and will not “stain” to blend with a transparent or semi-transparent deck stain.
How would one handle a knot hole repair previous to or after staining short of flipping or replacing the board
You leave them as is since fillers will not work. Or replace the wood.
Where can you get these stains, do they come in solid colors
See this for the best solid stains: https://www.deckstainhelp.com/what-are-the-best-solid-color-deck-stains/
What would you recommend for a board fence that we would like to stain solid white?
I like to know the best way to remove Behr Deckover product. It’s not a typical stain So far I’ve removed a great portion with a pressure washer but there is 40% remaining on the deck. Any recommendations?
See this. Same type of product:
Who makes the best oil base semi transparent exterior color black stain
No black colors that we know of. Very dark brown colors would be Armstrong Clark Black Walnut or TWP 1504 Black Walnut colors.
