This post was updated on February 27, 2024
Can you Apply Deck Stain over Paint
The simple answer is no, you can never apply any type of deck stain over a painted surface. You will have immediate failure if you do. If your deck is painted, then you would have to fully remove your paint off your deck by power sanding. Deck Sanding Tips.
Once you fully remove the paint off your deck, you can then use any type of deck stain that you like. We always prefer the penetrating semi-transparent deck stains for appearance and ease of reapplication as needed.
Have a Deck Stain question? Ask in the comments below.
For more info, see our Deck Stain Facts section with over 150 simple Q&A articles that answer all the questions that you have regarding deck staining, cleaning, and prep.
Gday, I have a heap of decking oil on hand, i want to know if theres any real reason i cant or shouldnt use it on ply sheets as a ceiling in a living area in a shed,not concerned about colour or grain showing etc, and yes ceiling will be insulated with batts if that makes a difference. Any clear answer of yes its fine or no its a no go for health reasons etc etc would be great. Cheers
You would have to ask the manufacturer of the oil brand as to if it can be used indoors or not. There is no way for us to answer this correctly as all products have different chemical properties.
A strip of Arborvitae leaves are brown from staining the fence. Will damage be confined to these leaves?
Not sure but probably.
