Wolman™ DeckBrite™ Wood Cleaner Review 4.6/5 (17)
Wolman Deck Brite Deck Cleaner Review – Updated 2026
Wolman™ DeckBrite Wood Cleaner is an oxygen-powered wood cleaner used to clean and restore decks and other weathered wood. When mixed with water, DeckBrite quickly and safely restores dirty, weathered-gray, mildew, and algae-stained wood to its bright, natural, like-new look. DeckBrite is used to prep for the reapplication of wood stains as well.
Wolman™ DeckBrite™ Wood Deck Cleaner Rating (1-10)
Removal of Graying, Dirt, Grime: 7
– Wolman™ DeckBrite cleans and removes grayed wood very effectively. We prefer oxygenated-based wood cleaners and the DeckBrite performs as we would expect.
Cost Per Square Foot: 9
– Excellent! Powdered deck cleaners are hard to beat when it comes to cost.
Removal of Old Stain: N/A
– Wolman™ DeckBrite is wood cleaner and preps stains for re-coating. Not designed to strip wood or deck stains.
Ease of Application: 7
– We had trouble getting the powder to dissolve into the cold water. This caused some clogging with the pump sprayer. Not sure of the “blue” tint this product creates. It did not seem to harm the wood.
Final Appearance of Cleaning: 8
– The IPE wood had been restored to about 80% of its natural state. There remained a small amount of graying.
Overall Score for Wolman™ DeckBrite™ Wood Deck Cleaner: 7.75
– The Wolman™ DeckBrite is a decent wood and deck cleaner. If you need to prep your deck prior to application then using this product would be effective. There are better Oxygenated Deck Cleaners on the Internet (Restore-A-Deck) but if you are shopping at a big box store and need to choose between Wolman™ DeckBrite and other brands, we would suggest the Wolmans.
Where To Buy: Menards, Sears, and Paint Stores
Product Type: Powdered Concentrated Deck Cleaner
Available Sizes: 1 pound and 2.25 pound containers
Manufacturer: Wolman
Deck Wood Type: Hardwood IPE Decking
Deck Square Footage: 750
The condition of Deck: Unstained graying wood.
How Much Product Used:
2 Pounds Retails for $39.99
33 Comments
I have a cedar wood deck and stairs stained with Wolmans Semitransparent Stain. It gets a lot of use as a commercial entrance. Where the traffic is heaviest there are bare wood spots.. I have sanded with 120 grit the horizontal portion of the deck (for adhesion) as I intend to restain it. Can I use the Wolmans Deck Brightener and Cleaner on the bare sports safely or will it damage the surrounding areas where the stain is still present. I would like to clean the bare spots but not damage any area which have currently have stain.
Kellie
Kellie
Can I use Wolman’s Deckbrite to clean an already painted wood deck? It is painted white.
Pete Homes
Pete Homes
Wolman DeckBrite is an amazingly great product. After 10 years of my having used some 3 or 4 other cleaners, this is the best I’ve tried – for ease of use, for powerful results and for safety to the plants and grass surrounding my deck. Based on my experience, the cause of the clogging you described in your review may have been your failure to have followed the instructions — which call for lukewarm (not cold) water, and for stirring some 3 to 5 minutes until the entire solution has turned white in color. DeckBrite just cleaned 2 years of grime and mildew from our deck “simply” by applying, letting it foam for 10 minutes, scrubbing some dirtier spots with a short-bristle floor scrub-brush, then hosing off – without the time-consuming trouble of covering and uncovering the plants! It foamed and cleaned best in areas where I had only lightly wet beforehand (again, according to the instructions). In other areas where I had pre-sprayed more water, it foamed less and required more scrubbing.
Morgan Baker
Morgan Baker
If you use Wolman Deckbrite, do you need to use a brightener after it? I know some cleaners can affect the pH of the wood so usually a “brightener” is recommended afterwards to neutralize the pH. This almost seems to be a hybrid “cleaner/brightener” in one.
thanks,
Morgan
Kim
Kim
I used HD-80 to strip my rough pine siding- what brightener should I apply? BEFORE I re-stain.
Onesteppharma
Onesteppharma
On the off chance that I utilize wolman deckbrite to prep the deck before recoloring why do I have to apply a brightener? Wolman promotes their item as a wood cleaner and brightener.
scott
scott
Below, you note that Deckbrite does raise ph level and thereby brightens wood. Wondering then if cleaner/brightener products like Wolman Deck"brite" (and Olympic Oxy-Deck) can also serve as a "brightener" for use after a stripper used like RAD stripper or HD 80 ? (ask in part as I have deckbrite & oxy-deck supply on hand) thanks.
Roy
Roy
Very easy to apply and took cedar back to original color of wood. Had very few spots of dark tannin oil stains that I used a cleaner spesifically made to clean those.
Mike Kirk
Mike Kirk
I saw a Wolman product at the Big Box store today while looking for wolmans Deck Brite. Its called (Wolmans) Deck Cleaner. It is to be hooked to a garden hose, and has a valve on it that you can switch from Off to Spay (solution), or Rinse. There is no info on what the chemicals are in the container. Anyone used this yet?
Mike Kirk
Mike Kirk
It was only $7.49 at Menards. Says it will do 1500 sq. ft.
David Kaeli
David Kaeli
12 years ago
I used DeckBrite on my cedar deck. The deck has 2-3 coats of Cabot Clear Solution. The deck had grayed in exposed areas. I followed the instructions with DeckBrite. I applied with a stiff brush, and used a high-pressure hose to rinse.The cleaner/brightener turned into a weak stripper for my deck. It cleaned up the grayed areas, but stripped the less exposed areas. Now I have a bit of a mess on my hands.
Any suggestions on how to proceed? I am putting on Defy Extreme once I get the deck properly prepped. But the DeckBrite really created a lot more work than I expected. It would seem I have to go back to using a stripper, and then a brightener (again).
David Kaeli
David Kaeli
12 years ago
Thanks. Any suggestions on a stripper? You only reviewed 3 – I know not to use Behr products, but the other two I need to wait weeks for. Any feedback on Jomax or Cabot Stain Problem Solver Wood Stripper.
Rick
Rick
12 years ago
the directions are under the sticker on the lid — peel and lift and unfold
Jim Thomson
Jim Thomson
12 years ago
My Wolman Deckbrite did not come with any directions. They said it was under the lid , no luck.
Is it possible to send me directions?
12 years ago
If I use wolman deckbrite to prep the deck before staining why do I need to apply a brightener? Wolman advertises their product as a wood cleaner and brightener.
Fernando
Fernando
13 years ago
If I use deckbrite to clean the wood do I need a brightener afterwards?
Teresa
Teresa
13 years ago
I stripped Wolman Durastain and then used deckBrite afterwards. I am going to apply Defy Extreme. Is there anything else I need to use before applying the stain?
stan
stan
13 years ago
can you use this product to clean algae and mildew or mold off roof asphault shingles ?
X
33
