Hi, I am Scott Paul, a leading exterior restoration contractor and business owner with over 30 years of experience in exterior wood. My Deck Revive Resurface Coatings reviews and help tips are based on my history as a wood restoration contractor and actual hands-on testing, all designed to present you with the top product choices. See here for more info about me.
Gulf Synthetics Deck Revive Review 2026
This review is from a third party. I have personally used the product numerous times throughout the last four years. It has not failed like the other Deck Resurface types. Reading the comments and reviews from consumers below, you will see that the results have been excellent. This review is not an outdoor field test but a Freeze/Thaw test.
Deck Revive is a DIY acrylic-based polymer deck coating that resurfaces old decks, docks, and other treated lumber — in ANY color you choose. Deck Revive repairs and protects wood structures from the constant expansion and contraction cycle that destroys wood.
Traditional deck stains, paints, and sealers just apply a new color to old splinters, cracks, and nailheads and have to be reapplied annually. Deck Revive actually fills in cracks and knots, locks down splinters and nailheads, and provides a new slip-resistant textured surface that lasts for years.
Unlike other “Deck Resurfacer” type products, Deck Revive is breathable, allowing moisture to escape.
Deck Revive Freeze-Thaw Performance Test
Scope: Test comparison of Rust-Oleum Deck Restore, Behr Deck Over, and Gulf Synthetics DeckRevive.
3-Step Test Parameters:
- The front panel and edges were coated according to manufacturer-recommended application instructions, leaving the back of the panel untreated.
- The panel was fully submerged in water at room temperature for 24 hours, removed from the water, placed in 15° Fahrenheit freezer for 24 hours, and removed and allowed to recover at room temperature. This process constitutes one cycle.
- As of this published overview of freeze/thaw testing, the panel has been exposed to 24 cycles.
Gulf Synthetics Deck Revive Test Results
- Deck Restore was initially soft and somewhat recovered but can be removed from the substrate with little effort. There was no evidence of substrate cracking through the coating.
- Deck Over was slightly softened and fully recovered, but due to its lack of film build compared to the other coatings, it displayed substrate cracking through the coating.
- Deck Revive slightly softened but fully recovered within the 24-hour room temperature portion
Gulf Synthetics Deck Revive Testing Video
Web site:Â Gulf Synthetics
Cost: $290 per Kit
Stain Type: Solid Color Deck Surfacer, water-based
Available Colors:Â Any Color
Application Temperature:Â 45-95 F
Coats Required:Â 2 Coats.
Coverage Per Gallon: 200 sq. ft for 2 coats per kit.
Application Tools:Â Brush, Roller
Dry Time:Â 2-8 Hours
Cleanup:Â Water Cleanup
VOC Compliant:Â 250 Compliant in all States
More Info:Â Product Data
Manufacturer:Â Gemini Coatings
*We offer no guarantee of similar results. Consider that results may differ due to different wood types, exposure to UV radiation, and natural weathering.
I used GULF Synthetic in Sept of 2015 on my front porch. Today is 5/1/17. We live in NY with harsh winters. The porch gets a little morning sun but is otherwise shaded. Application of this product is difficult but I did it myself. I followed directions completely and made sure I was totally ready to move quickly when I began the process. The porch still looks great with no pealing or wearing noted. I must note we shovel this porch when it snows. 🙂 I think It is the best product out there to cover that nasty deck situation you might have. The only thing I find to be a very small issue is the “grit” The surface is gritty however it beats splinters. I now plan to do my back deck 1350 sq feet, a huge undertaking. This product is costly but at least it does what it says. I have researched all these products and I think using the Gulf is the way to go.
Thanks for your review!
Does the deck synthetc coating show any wear after you shovel?. We get a lot of snow , therefore lots of shoveling and I am looking for a product that would withstand tht.
It should. Use a shovel with a rubber edge will help. If you dig into it with metal, it will be an issue.
no it held up well.
Do you mean that grit releases continuously? We walk into our house onto hardwood floors. I would be worried that the grit would scratch them. thanks.
The grit is in the product and does not come off.
OK. thanks.
Is it gritty in a good way, that you have firm traction when the surface is wet? We live in western NY. I also want to avoid the bubbling or peeling in the Summer. I am retired and can’t afford to do the job twice. I want to do it right the first time.
Yes it has traction to it so it is not slippery when wet.
i am the original owner and developer of DeckRevive. i am originally from Rochester, NY and can relate to the harsh winters. i have the first batch of DeckRevive on my deck in georgia whuch was applied in 2008. No peeling and still looks like the day i applied it
I have been using the product for 5 years now this will be my 6th year I have no complaints of peeling I love this product and it’s the only one I will use for my business in ct..
Is it in the sun?? I have sunny areas and they don’t do well with Deckover
what about Olympic Rescue It Max , resurfacer+Primer+Sealant
Garbage and they have a class action lawsuit against them as well: https://www.deckstainhelp.com/olympic-rescue-it-review-2014/
Can you tell me how to find the colors for the deck revive kit?
And how do you purchase the product?
You can buy it on our website or here: https://www.gulfsynthetics.com/
For colors, you add the color by adding a gallon of gloss acrylic latex paint to each kit in any color you want.
Is the stated coverage accurate?
Can permabond be painted over a stain that isn’t peeling or do you have to remove a stain before applying
It should work as long as the prior coating is fully intact.
Can Gulf Deck Revive be applied over a SW solid deck stain?
It should be okay as long as the current stain is intact and not peeling.
I see that you have to mix a gallon of exterior paint with this product. Is there a particular exterior paint recommended?
Any exterior paint should work, just make sure it is acrylic (not oil-based) latex and is a high gloss. Sherwin Williams should have options.
How would this product hold up to two 70 lb dogs running around/nail scratches? Any feedback appreciated.
Yes, it should.
I have a large deck and am replacing the boards you walk on. The rest is still okay but painted. Can I use the deck restore on both the new pressure treated and the painted older surfaces? Also, should I paint the crossbeams under the wood I’m replacing?
New wood needs to weather for 3+ months. The only reason to paint the crossbeams would be for aesthetic purposes.
Scott, do you have insight into the painted older surfaces part of Norma’s question? That’s my situation too. We bought a house with a painted deck and need to replace several boards that have rotten spots and repaint many chips/scratches on the others. We’re hoping maybe we could use this product over the new boards as well as the existing painted ones (after scraping all loose and peeling paint). Any advice?
It should work okay as long as all failing areas that are peeling are removed.
Thanks – I appreciate your response, and this site!
I am preparing to restore a lumber (pressure treated) deck using one of the deck restore products. I am looking to choose between the Cabot deck correct and Pittsburgh revitalize for heavy to moderate needs. Prices are similar for 5 gallon containers and my deck looks similar to pictures shown in their respective brochures. Cleaning and large crack filling look to be similar for both, and they both require 2 coats to complete the restoration. I have approximately 1000 sq ft of deck to restore. I have ruled out other recovery products for various reasons. after reading your reviews, it looks like you recommend the Gulf Synthetic Deck Revive product, which I will look into.
I would be interested in a recommendation amongst the 3 products mentioned above. I know nothing lasts forever, but if I can get another 5 – 10 years out of this deck, I would be happy. It appears that once you use one of these types of restorative products, nothing more can be done to the deck besides sanding all off. Looks like they cannot be patched or recoated with another coat of same product.
Thoughts or comments?
We would not use any other brand but the Gulf. Cabot and Pittsburgh brands have the same issues as Behr Deckover and Rust-Oleum’s Deck Revive/Rock Solid.
Why is Perma Bond not sold with deck revive “Full kit”?
Can I purchase a similar product (Perma Bond) in a store?
You would have to ask the manufacturer.
Should I fill in large cracks in deck boards along with large knots with wood filler before hand?
No need. Cracks are normal in wood decking.
I’m replacing the floor in a boat. I’m using new 3/4″ marine plywood. Will this product (Gemini Deck Revive) do what I’m hoping for on new material? It is a fishing boat so color, grittiness and protection (breathability) are very important. There won’t be carpet or vinyl going over it. Plus, I’m old and don’t want to do this again. My assumption is to apply the entire kit. Thank you
Yes, it will work for this.
Do you have any knowledge / experience with ArmorRenew Deck & Concrete Patio Re-surfacer from ArmorProxy? Or PRO RENEW WOOD AND CONCRETE RESURFACERfrom Epoxy Central?
Sorry but never used it or seen it.
Thank God I found your site and product reviews. You prevented me from going with Rustoleum RockSolid and the similar Behr product for my back deck re-furb project. My deck is 12×24 so I’m thinking I’d need 2 kits for a proper 2 coat application. I’ve pressure washed the surface and sanded the hand rails. Spraying mildew/mold cleaner on it today. I’m not sure of the original paint, but I’ve been in the house for 5 years and now I need to do something. Based on the pictures, can I just apply the Perma Bond, then paint directly over existing paint with the Deck Revive?
As long as your previous paint is not peeling, you can cover it.
I’m thinking of using this on our wooden Adirondack chairs. Would the grit be uncomfortable to sit on and rest your arms on? We bought these inexpensive hand made Adirondacks and they guy who made them did not seal them properly with polyurethane, so there are spots where there is none. They look terrible now and I was thinking this product might improve the look and also help them last longer. Would I need to remove all the old poly first?
Yes, you will have to remove the poly. Not sure if the grit will be too uncomfortable but it should not be that bad.
Can I use a spray gun with this product?
No, too thick.
Thanks…I guess it’s the old fashion way!
I have a 25year old deck, just power washed and cleaned with deck wash solution. It has some minor surface cracks, can I use a solid stain or product like the Gulf Deck Revive is only option?
Cracks in a deck are normal and are not an issue. You can use any stain type that you want.
Im in south Florida and im putting in a bid on a 2300sf dock to clean prep and seal and it is badly weathered and may need a couple areas filled with wood filler or putty or something but my question is will the Restore-A-Deck Semi-Transparentbe ok to use or should i look at something solid color maybe Gulf Synthetics Deck Revive
Wood filler and semi-transparent stains will not blend. Solid stains will. Use the RAD Solid Stain.
Would you recommend RAD solid over Deck Revive ?
Both would work well, just depends on the look you want. The gulf will have a more “textured” look to it.
I have a deck that was painted with behr restore about 10 years ago. No peeling, but now I can see the deck beneath starting to bleed through. I power washed it, and I want to repaint just to give me one more year before tearing it off. Can I use the behr replacement product over it?
Not sure, you would have to ask Behr as we stopped using all their products due to very poor performance.
I would like to use Deck Revive on my deck floor. I hear that the surface is coarse. I have benches and prefer not to have rough seats. Is there another product that I can use on my benches that will complement the DeckRevive on the floor? I prefer that it is not a stain since I would like to have a paint color to match the DeckRevive floor. Thanks in Advance
You can use a solid color stain that matches the deck revive paint.
Any recommended products?
Will this product work on a composite deck?
It should.
I have been doing trex decking for three years now i also sent my samples with untreated samples to gemini lab and they verified my research that it will work i also put a coating for concrete on it after that gives it a wet look makes concrete revive look wet on a sunny day does not fail the product after 4 years proven to work
10×16 pressure treated wood deck, 50 years old, central NY, 1-2 coats of old deck paint mostly intact under eaves, mostly peeled off in sun, some splintering there too. I’ve washed it with a stiff scrub brush and deck cleaner w/mildew remover (strong bleach smell). No pressure washer on hand, so used the garden hose. Then I found this site! Will Gulf Synthetic work on this varying surface, and do I still need to pressure wash – wouldn’t that further tear up the aging wood? If the mildewcide wash is a problem, how long before it’s not? Many thanks.
Yes, you will have to pressure wash and it will not tear up the wood. The Gulf will work great.
I am considering deck revive for refinishing my deck. I have sanded most of the deck with a belt sander to remove the old coating I believe it was paint over the top of a solid stain. Can you tell me if deck revive would work for my deck based on the attached photos and can you also advise if I need to do any more prep work before applying deck revive? Also if there is a better option than deck revive please let me know so I can consider that too. Thanks!
Yes, it would work very well. Give it a good pressure wash as this will open up the pores.
how do i tell how old deck revive is, as there are no batch numbers or date on materials
Not sure, you would have to ask them.
Can I use DeckRevive over old textured deck paint? There are areas on our deck where the old paint will not come up.
It should work.
Does this product work for a concrete dock?
To all deck revive users this our 7th year over 150 decks nobody is suing us or Gemini because it’s the only deck product when applied correctly and maintained correctly last for many many years I want to share something we have been putting a concrete sealer over our deck revive the next day it gives It a wet look does not hurt the product I feel it helps it even more stays cleaner to we also proved it on trex decking with the sealer and concrete with the sealer it works this is our trademark product all we will use
What brand or type of concrete sealer do you use over the deck revive?
does this Deck Revive come with any kind of warrantee? It’s a lot of money for this kind of product, however I haven’t seen a negative review yet…
Not sure. Ask them.
I give a 3 year warranty on all my decks
I used an Olympic semi transparent stain on my new deck three years ago. After just two years it started to look awful. The deck it attached to an above ground pool, hence subjected to the chlorine. Any recommendations? Thanks
Pressure wash for prep and then use the Gulf Deck Revive.
Thank you. Where may I obtain that product? Color choices?
Post some pictures here in comment area for prep help.
Would DeckRevive be a good product for an old power washed composite deck?
Not sure, best to ask them.
Hello, is this deck worth restoring? It splinters in spots and has areas of deeper crevices and is rough. The spindles are ok but the top rail needs done as well. Opinions on what you think may be best? I don’t know that we’ve ever sanded it but with ots roughness not sure it’d matter in most areas. Appreciate your insight 🙂
Yes, it is worth it. Strip and then brighen for prep. You do not need a coating like the Gulf on it but you can if that is the look you want. We would look at a penetrating semi-solid like TWP or Armstrong Clark.
Thank you so much for your reply. So how do I fill in those thinner crevices? (probably from sun drying it out with no protection) which will likely splinter out in someone’s foot? We have lots of barefoot kids here and for the past 5 years of doing nothing because I thought I was going to have to replace it $$$, I’d tell everyone WEAR YOUR SHOES and don’t hold the side too hard as you walk down the stairs!!
Fillers will not work on decks. Just leave as is and you can lightly hand sand or pol sand to remove splinters before staining.
Thanks…can’t wait to see how this goes…nervous though 🙂
