Gulf Synthetics Deck Revive Review 4.8/5 (73)
Hi, I am Scott Paul, a leading exterior restoration contractor and business owner with over 30 years of experience in exterior wood. My Deck Revive Resurface Coatings reviews and help tips are based on my history as a wood restoration contractor and actual hands-on testing, all designed to present you with the top product choices. See here for more info about me.
Gulf Synthetics Deck Revive Review 2026
This review is from a third party. I have personally used the product numerous times throughout the last four years. It has not failed like the other Deck Resurface types. Reading the comments and reviews from consumers below, you will see that the results have been excellent. This review is not an outdoor field test but a Freeze/Thaw test.
Deck Revive is a DIY acrylic-based polymer deck coating that resurfaces old decks, docks, and other treated lumber — in ANY color you choose.  Deck Revive repairs and protects wood structures from the constant expansion and contraction cycle that destroys wood.
Traditional deck stains, paints, and sealers just apply a new color to old splinters, cracks, and nailheads and have to be reapplied annually. Deck Revive actually fills in cracks and knots, locks down splinters and nailheads, and provides a new slip-resistant textured surface that lasts for years.
Unlike other “Deck Resurfacer” type products, Deck Revive is breathable, allowing moisture to escape.
Gulf3medium
Deck Revive Freeze-Thaw Performance Test
Scope: Test comparison of Rust-Oleum Deck Restore, Behr Deck Over, and Gulf Synthetics DeckRevive.
3-Step Test Parameters:
  1. The front panel and edges were coated according to manufacturer-recommended application instructions, leaving the back of the panel untreated.
  2. The panel was fully submerged in water at room temperature for 24 hours, removed from the water, placed in 15° Fahrenheit freezer for 24 hours, and removed and allowed to recover at room temperature. This process constitutes one cycle.
  3. As of this published overview of freeze/thaw testing, the panel has been exposed to 24 cycles.
Gulf Synthetics Deck Revive Test Results
  1. Deck Restore was initially soft and somewhat recovered but can be removed from the substrate with little effort. There was no evidence of substrate cracking through the coating.
  2. Deck Over was slightly softened and fully recovered, but due to its lack of film build compared to the other coatings, it displayed substrate cracking through the coating.
  3. Deck Revive slightly softened but fully recovered within the 24-hour room temperature portion
Gulf Synthetics Deck Revive Testing Video
Web site: Gulf Synthetics
Cost: $290 per Kit
Stain Type: Solid Color Deck Surfacer, water-based
Available Colors: Any Color
Coats Required: 2 Coats.
Coverage Per Gallon: 200 sq. ft for 2 coats per kit.
Application Tools: Brush, Roller
Dry Time: 2-8 Hours
Cleanup: Water Cleanup
VOC Compliant: 250 Compliant in all States
More Info: Product Data
Manufacturer: Gemini Coatings
*We offer no guarantee of similar results. Consider that results may differ due to different wood types, exposure to UV radiation, and natural weathering.
338 Comments
Teresa
Teresa
I used GULF Synthetic in Sept of 2015 on my front porch. Today is 5/1/17. We live in NY with harsh winters. The porch gets a little morning sun but is otherwise shaded. Application of this product is difficult but I did it myself. I followed directions completely and made sure I was totally ready to move quickly when I began the process. The porch still looks great with no pealing or wearing noted. I must note we shovel this porch when it snows. :) I think It is the best product out there to cover that nasty deck situation you might have. The only thing I find to be a very small issue is the “grit” The surface is gritty however it beats splinters. I now plan to do my back deck 1350 sq feet, a huge undertaking. This product is costly but at least it does what it says. I have researched all these products and I think using the Gulf is the way to go.
Dianna
Dianna
Reply to  Teresa
Does the deck synthetc coating show any wear after you shovel?. We get a lot of snow , therefore lots of shoveling and I am looking for a product that would withstand tht.
Teresa
Teresa
Reply to  Dianna
no it held up well.
Ri enn
Ri enn
Reply to  Teresa
Do you mean that grit releases continuously? We walk into our house onto hardwood floors. I would be worried that the grit would scratch them. thanks.
Ri enn
Ri enn
OK. thanks.
Michael
Michael
Reply to  Teresa
Is it gritty in a good way, that you have firm traction when the surface is wet? We live in western NY. I also want to avoid the bubbling or peeling in the Summer. I am retired and can’t afford to do the job twice. I want to do it right the first time.
Mitch
Mitch
Reply to  Michael
i am the original owner and developer of DeckRevive. i am originally from Rochester, NY and can relate to the harsh winters. i have the first batch of DeckRevive on my deck in georgia whuch was applied in 2008. No peeling and still looks like the day i applied it
Curriers painting/decorating
Reply to  Mitch
I have been using the product for 5 years now this will be my 6th year I have no complaints of peeling I love this product and it’s the only one I will use for my business in ct..
Bill Stratman
Bill Stratman
Reply to  Mitch
Is it in the sun?? I have sunny areas and they don’t do well with Deckover
Jeanette
Jeanette
Reply to  Teresa
what about Olympic Rescue It Max , resurfacer+Primer+Sealant
Joel
Joel
Gulf synthetic as compared to rustoleum 4X or is it the same product
Carlin
Carlin
Do you need to use permabond on a new deck or can you just apply the Deck Revive?
Wanda
Wanda
We used this product on a very weathered full sun back deck some years ago. It lasted beautifully for a long time and now we would like to reapply. Our painting contractor advised that this product was so thick that it would not work well since it had been treated previously. Do you have a solution. The product is really incredible.
Dave Mulford
Dave Mulford
Can Deck Revive be used on a composite deck?
Laureen
Laureen
Where can i buy deck revive
Duane Troxler
Duane Troxler
Does this product come in a version that does not have the grit?
Wanda nelson
Wanda nelson
This product was used on my deck 5 years ago. It has held up beautifully. It is now time to spruce up and apply again. What is the procedure?
Mitch
Mitch
Reply to  Wanda nelson
i am the developer of the product and have a solution for sprucing it up. mitch 678 234 7584. owner of gulf synthetics
Jen
Jen
Reply to  Mitch
How can we make this product less rough? I don’t want it to feel like I’m walking on sandpaper. Thank you!
Sue Case
Sue Case
One year old Flood (pro series) solid color shows mold/mildew after one year. Yuck. Does Gulf Synthetic protect old deck wood rom mold/mildew? I don’t read any where here (and other sites) if Gulf Synthetic protect deck wood against mold? Flood acrylic stain still cover wood good but removing mold with bleach and water major pain. Any suggestions on what I can do keep “green” stuff away (long term).
Tim Townsend
Tim Townsend
What do you use to tint or add color to the “Deck Revive” ?
Kurt
Kurt
I’m trying to determine what final color/tint I’ll get.
Gulf Synthetics website says to mix one gallon of exterior gloss acrylic latex paint to the one gallon of the liquid component of their Deck Revive. So whatever color paint I add, would be diluted 2 to 1, so to get a specific color/tint, I’d add paint that is about twice as dark as the final color I want? Could I test this by adding a small amount of the tinted paint to an equal amount of white paint and test paint small sections?
Mark Currier
Mark Currier
Thank you gulf synthetics and Gemini industries 5 years now using deck revive on customers decks we now have done 104 decks in the last 5 years out of all them we had 4 minor repairs which took about ten minutes and it wasnt a product failure either only product we will use I guarantee my deck for 3 years other solid stain will not hold up to this product we also proved that it will work on wire ourmt trex decking.this has been our best year and we are growing more each year with more believers.thanx again gemini…
Nancy Atkinson
Nancy Atkinson
Can it be used in cement porches?
Steve Perry
Steve Perry
How will this product act if put over a coat of properly prepared DeckOver that has been on the deck for 2 years?
John J
John J
Can you give detailed info/instructions on how to apply Deck Revive like what type of brush is best to use? or can a roller or pad be used? or can it be sprayed on? How often does DR need to be stirred/mixed? What quantity is best used at a time?
Mark Currier
Mark Currier
Would like to inform the growing number of homeowners who are realizing that deck revive from Gemini industry is the leading deck surfacing product on the market that I have and Gemini lab has confirmed my testing with their own that we can now resurface your old worn out trex decking Gemini lab has given my testing along with theirs the ok so all you owners of worn out trex decking you have your solution I knew it would work I am ct and Rhode islands only deck revive professional call me if you need service or I can also answer questions you may have a great day and spread the word it is not the same failing stain product that others are selling thank you
joanne M ostrander
joanne M ostrander
Reply to  Mark Currier
will this work as well on a new deck that hasn’t been stained before?? thanks!
Tony Cantin
Tony Cantin
I am very interested in your trex experience with deck revive. Thank you for offering your assistance.
Billie Bob Norton
Billie Bob Norton
Do you ever use punctuations such as periods or commas? Just askin’….
Mark currier
Mark currier
It’s not an English class sorry
susan
susan
Love the texture and the grit in this product and it is what I expected. Keeps the dogs from slipping and it saved our 20-year-old pine deck from being demoed.
Mike McCoy
Mike McCoy
I came across this product when considering refinishing a 10 year old PT deck. The deck had an original stain on it, which I was able to clean off pretty easily with a pressure washer. I purchased 2 full kits and 1 Permabond, for a 390sq ft deck.
I used a Sherwin Williams exterior gloss acrylic for color.. the color seemed to mix okay.
I had this applied by professional paint contractors locally, and after they did one tier of the deck I regretted the decision. This is going to add a great deal of texture and grit to your deck, be aware. I didn’t like it so much that I stopped half way through.
I was left with one untouched kit which I am going to return, however the company is hitting me with a 30% restocking fee even though the package is literally untouched. For the premium they charge over the cost of off the shelf resurfacing solutions, its just not worth it. If you are planning on applying this yourself, you are going to be in for a tough time — my contractors were misterable working with it, having to continuously mix it every 10 or 15 minutes to keep it from turning to sludge.
Great mistake on my part.
Buyer be very, very aware.
John J
John J
Can you give more detailed information/instruction on how to apply Deck Revive? For example what type of brush is best? Can a paint roller be used? Can it be sprayed on? How often does Deck Revive need to be stirred/mixed? What quantity can be best used at a time?
Billie Bob Norton
Billie Bob Norton
Reply to  Mike McCoy
Mike – did you do any research on the product or read the descriptions about it? Do you expect them to give you a full refund when they have a restocking policy? Too bad you decided to give the product a poor review when in fact you should give yourself a poor review for not reading and comprehending before purchasing the product. Sad, very sad…….
Sandy
Sandy
I am dealing with a Behr Deckover disaster. The pain peeled very quickly and what is left, cannot be removed. Can I use the Gulf Synthetics Deck Revive product on top of the Deckover Gulf Synthetics Deck Revive after power washing? Getting new boards is simply not an option for me, financially. My deck is large, about 24′ by 12′. Thanks
Gail
Gail
We pressure washed it. Used stripping stuff. And pressure washed again. Then sanded. Not all came off. Then used the cleaner. Can’t get it all off. Can I use this stuff now?
Gail
Gail
I have deck over on it.
Mark currier
Mark currier
Reply to  Gail
Get a floor sander and remove it first I do these types often you must remove it first or it will peel off the revive because you are bonding to a failing product
Reid
Reid
With the gritty finish, would it be better to paint the fence and railings part of the deck than to apply Deck Revive? If so, would the paint color be different from the product color even if using the exact same paint?
Clint
Clint
I used deck revive a couple years ago and the deck still looks great. However, I want to change my color. What are the steps involved in going over deck revive? Since the permabond has been used could I apply any latex over it like deck and dock from Sw, or do I need to use your product. Also would I need to use permabond again before I use your product or another latex?
Michael Maddox
Michael Maddox
where can you purchase Deck Revive in metro Atlanta ga.
Jon Martinez
Jon Martinez
How is this product with very high heat temperature. Arizona
Bob Double
Bob Double
Can you apply 3 coats of Deck Revive over Perma Bond?
Mark currier
Mark currier
I am a professional deck revive installer I service ct and rhode island I have do 72 decks in four years it’s the only product I will use I advertise the product on my company vehicle and local papers many people think it’s the same junk from he he and rustolium no comparison powetwash first we will not due moisture will stay in wood a long time we moisture test all ways first we use floor Sanders for prep note all the seams must be free of debris before and after it could cause minor failure due to water trapment airflow beneath is a plus with concrete revive a clear sealer called wet look will aid in beauty and rock salt apps we are currier painting and decorating in Brooklyn ct we are the only real representative of this product in ct and rhode island and the most experienced with the product it is the number one product on the market today follow us on Facebook thank you
Hal Adcock
Hal Adcock
Hi, I just power washed my deck. Let it dry for 7 days. I used Sherman Williams woodscaped exterior house stain that my neighbor gave me. My deck is open to the weather, the color is perfect, but their are so many cracks in every board I think I have to apply another product. What would you recommend. Thanks, Hal.
Sugarz
Sugarz
Last year I used a Deck Resurfacer and it started peeling within 1 month. I followed the mfg. directions to the “T”. My question is for the areas where it is still pretty secured do I need to get that removed before using your product?
Bill
Bill
How to paint a already painted deck
Brooke
Brooke
I live close to the ocean and my ex used standard decking screws that have rusted. I not only have to do a front entry but also a 14 x 28 deck. In fact, the rusting has run down onto the stained deck surface (steps). I guess my choices are to try and replace every screw with a stainless one or use your Gulf Deck Revive. The deck color is a very light grey (stain). Will your product permanently cover these rust stains? What type of steps will be involved? How hard is this to do (I am disabled with a very bad back)?
Mark Currier
Mark Currier
Reply to  Brooke
Once again remove it with a floor sander and itcwill also remove the rust from the screws most of the time they will snap if u try to remove them prime them with a rust treatment or primer
Milton Strange
Milton Strange
What about Deck Revive color choices? Will it cover, colorwise, the darker old stain on my deck?
Larry Rudisill
Larry Rudisill
So do you have to strip the old stain off the deck before using this?
Jeremy
Jeremy
Looking to paint a new deck. Do you recommend using deck revive on a new pressure-treated deck?
Cris Underwood
Cris Underwood
Can this product be used on a wooden fence?
Lisa
Lisa
Can I buy this product anywhere in Columbus oh?
Joan
Joan
Can this product be applied to a floating dock for a pond? It will be put on before the dock is in the water. Thank. you
Rob
Rob
Can Gulf be used over trex type products?
FrankG
FrankG
I applied Behr Deck Over throughout the surface of my cedar deck only 2 years ago and like the latetest ratings have confirmed it hasn’t stood up to test of wear, primarily prone to peeling. I am now interested in redoing th surface with Gulf Synthetics. Would I be able apply it overtop of the existing surface followin a light sanding? Having to sand every area down back to bear wood would be such an enormous task. Or, is there any other alternative that you might suggest?
FrankG
FrankG
Yup…………That makes a lot of sense. Seems that this a case of ‘live & learn’
Thank you for your answer.
Rhonda
Rhonda
Reply to  FrankG
We are dealing with the same situation, we used Deck Restore and it’s peeling terribly. We were advised to flip the boards over (cheaper than buying new lumber, but time consuming).
DavidW
DavidW
Hi – Thanks for the article, probably saved us lots of toil, $ and frustration! My painter told me our deck has been stained and then painted. The best he can offer is to keep repainting every 1-2 years and expect peeling. Do you think the DeckRevive product can help us?
sharon p
sharon p
if applied correctly using the perma bond first……..how long can this product last on your deck?
allen
allen
Can Deck Revive be used on a painted deck ?
EPS
EPS
I put the PermaBond on at the end of last summer. Some areas have worn but most of the deck surface still has the bonding agent in place. Can I put the deck revive on now or should I recoat with primer again?
Brandy
Brandy
Can this product be used without paint added in? I would love to just stain my deck or leave it natural looking but with protection from the elements. Can this product be used like that?
Dennis Freeman
Dennis Freeman
Would a concrete bonding agent applied to the wood first help these products to adhere better? It works well on concrete I just don't know about wood. These are concrete based products are they not?
Ellen
Ellen
Mistakes were made. We used Olympic Rescue It, which is peeling horribly after 2 years. We tried to pressure wash it off, but it's taking forever. Can we put this over what is left? We want our deck to, you know, not look like crap.
MikeV
MikeV
Would this product be appropriate on untreated wood? Our condo building has a stairwell from which we would like to remove the doors – top floor, middle landing and ground floor, remove the carpet and leave open.There would be exposure to the elements near where the doors are removed. I think it would be much cheaper to seal the untreated wood (once carpet removed) as opposed to replacing all wood with pressure treated. Thoughts??
Todd LaFontaine
Todd LaFontaine
When I applied Deck Revive 4 years ago, I wasn't aware of the requirement to first apply the bonding product first. Unfortunately approximately 40% of Deck Revive has pealed off. I will now have to sand blast the whole 400 sq ft deck and reapplying the Deck Revive, but this time apply the Gulf synthetics binding agent first. Not looking forward to that job!!
I would like to place an order for enough Deck Revive & the bonding agent, but first, would you please tell me now much of each product I will require. I will be applying 2 coats of Deck Revive. Thank you…
Deckguy
Deckguy
So you guys are selling this product and trashing other manufacturers by claiming to be an impartial deck staining review site? Interesting…
Tamie
Tamie
I just received a check from using Rustoleum from a class action lawsuit (only covered 1/3 of the cost to replace for product and removal). They are not trashing other manufacture as it is public knowledge of the lawsuit. Accurate information is appreciated by the rest of us.
Cindy
Cindy
How is the GEMINI product with heat after a full day of sun exposure? Apparently, the other products get too hot to walk on.
Randy
Randy
after using the gulf synthetics Deck Revive ……………. what stain or coating would you recommend ?
Nancy
Nancy
Wish we would have waited. Sounds like a great product, but my question is….am I now stuck with the Behr Deck Over I have on my deck? We only did one coat (I know, bad move!) and ran out of time (weather-related) last year. We were going to do a second coat this year, but there's already peeling going on. Are there any methods to remove some (or most) of the Deck Over?
Michelle M
Michelle M
what kind of warranty do they offer ? Where can you purchase this product and much would you need for a 20×20 deck
Shirl
Shirl
I am thinking about using deck revive. Sounds like the best product, based on research. Question,can I fill in holes and splits with their deck filler then put their dealerover
over it?
Joann
Joann
Reply to  Michelle M
where can you buy this product? Southfield, Michigan?
Reply to  Michelle M
Where can I buy this product in n.y.s.?
James Henderson
James Henderson
Excellant article – can this product be purchased in Canada
1 2 3
338
