Ipe Oil Hardwood Stain Review 3.6/5 (19)
This post was updated on May 30, 2024
Ipe Oil Hardwood Stain Stain Review 2025
IPE Oil has become popular in the past years. It is an oil-based semi-transparent stain that will give a brownish tint to your IPE or other exotic hardwoods.
My Pro Tip: IPE Oil is Messmers UV Plus for Hardwood Stain, just relabeled with a slightly different “browner” color.
If you have used the Ipe Oil Hardwood Stain, please post a review in our Star Ratings and or comment area. Our comment system does allow the ability to post pictures of your deck or exterior wood.
Note: See here for my other exotic hardwood and Ipe Stain Reviews: Exotic Hardwood Stain Reviews
IPE Oil Wood Stain Review
IPE Oil Deck Stain Rating
IPE Oil Hardwood Stain Review
Ipe Oil™ Hardwood Deck Finish is designed specifically for IPE and other Brazilian Hardwoods. Ipe Oil™ Hardwood Deck Finish offers deep penetration into dense exotic woods protecting the wood from water and UV damage.
Ipe Oil™ can be used on all types of wood including ipe, tigerwood, cumaru, or and hardwood decking and wood siding, preserving the natural grain while enhancing at the same time. Ipe Oil™ Deck Finish is a 250 VOC compliant oil-based finish that can be used in all 50 states.
Important Note: Testing for Exotic Hardwood Deck Stains
Exotic hardwoods such as IPE are extremely dense and difficult to penetrate. These wood types when stained will always fade faster than other woods such as Cedar, Redwood, and Pine. Testing will be changed to 1 year instead of 2 years for exotic hardwoods.
IPE Oil Hardwood Stain Stain Rating (1-10)
– IPE Oil comes in only a Natural Finish. This is a transparent but pigmented color that really enhances the natural grain of the wood. The finished look after drying was a beautiful rich tone of brown with a hint of red throughout our IPE wood.
Preventing UV Graying at 1 Year Mark: 5
– We only test exotic hardwoods for 1 year. IPE oil had retained most of its color. Only about 30% of the color has faded from the wood. The was still a decent amount of color left.
Wear/Tear and Peeling: 9
– IPE Oil penetrates very well into exotic hardwoods. There wasn’t any peeling of the stain from the wood, even in the high traffic areas.
IPE Oil Finish Review
Cost Per Square Foot: 6
– IPE Oil Finish retails for an expensive $60.99 per gallon. Fortunately, the IPE Oil spreads extremely well. The coverage per gallon was over 300 feet per gallon. This is double the coverage on a soft wood such as Cedar or Pressure Treated Pine. We only used 2.5 gallons for the 800 sq. foot test deck.
Preventing Mold/Mildew/Algae: 7
– Small amounts of algae were present after 2 years around the outside railings and in corners. We did not find any mold growing in or on the IPE Oil Stain.
Ease of Application: 8
– The coverage is excellent. We applied with a pad applicator, waited 20 minutes and back wiped the excess stain residue. The entire project was completed in about 3 hours.
Color Shifting (darkening) after 2 Years: 8
– The IPE Oil did not color shift/darken noticeably. No mold/mildew and very little dirt accumulation.
– Future maintenance would require a wood deck cleaner and some scrubbing to alleviate the wood of dirt. This would be enough prep prior to applying a maintenance coat of stain.
Overall Score IPE Oil Hardwood Stain at 1 Year Period: 7.38
– We liked the IPE Oil overall. Easy to apply, coverage per gallon was excellent, and the finished look was stunning. This would be a decent product for any exotic hardwood that requires annual maintenance.
Note: See here for other exotic hardwood and Ipe Stain Reviews: Exotic Hardwood Stain Reviews
Where To Buy: Mostly Online with a few retail stores, Home Depot
Cost: $65.99 per Gallon
Stain Type: Semi-Transparent – Oil-Based for Hardwoods
Available Colors: Natural Finish
Coats Required: 1 coat for most hardwood decking surfaces
Coverage Per Gallon: 300+ sq. ft for Exotic Hardwoods
Dry Time: 4-12 Hours
Manufacturer: IPE Clip
Deck Wood Type: IPE Exotic Wood
Deck Square Footage: 800 Square feet
How Many Years Tested: 1 Year
Natural Finish
*All products tested and results are from our experience. I offer no guarantee of similar results. Take into consideration that results may differ due to different wood types, exposure to UV radiation, and natural weathering.
The Best IPE Hardwood Deck Stain Video – DeckStainHelp.com
Subscribe
Notify of
161 Comments
Danielle
Danielle
Can you use Ipe oil stain on a cedar deck? Looking for a penetrating oil based stain for longevity.
Keaton Parent
Keaton Parent
Will the ipe oil ruin a non reinforced rubber roof membrane? We are doing a tiger wood deck with a rubber membrane underneath it, I just want to make sure when we put the oil on it won’t ruin the rubber.
HAF
HAF
We used this on our Ipe deck and after 4 months it looks dark, dry, and patchy with gray scrapes all over from furniture movement. I want the wood to look oiled and not dried out. Two coats would have made it too dark and would not absorb. What product would you recommend to keep a medium brown saturated looking oil finish (like new teak furniture)? Our expensive deck looks awful. Unsure of how to post a picture.
Tracy
Tracy
Can ipe oil be used on pressure treated pine? It has dried for a year, and recently has been cleaned and brightened.
Hi Crew,
We are installing an ipe deck as we speak. I see from the post below that we have to let it sit for a few weeks and breathe before we do any stains to it(great info).
My question is is there a ipe oil that can stain it black or very dark ?
We have an old Queen Anne house and it will go with the color scheme.
Thank you for your time.
Tim
Tim
My deck is a mix of pressure treated and ipe wood can I stain the treated wood with with ipe oil
Paul Goldberg
Paul Goldberg
I had a contractor use this on my IPE deck which had not been treated in 3 yrs. It was cleaned properly, however once the IPE oil was applied the wood looks like it needs another coat? A lot of the wood did not come out dark and is light in some areas and darker in others,
Maria
Maria
Our Ipe deck was installed three weeks ago. We are trying to find someone to seal it for us. We are getting different recommendations on when to treat it. One company says to wait a few weeks , another says treat it as soon as possible. What do you recommend ?
Maria
Maria
Sean
Sean
Do I need any special skills to be able to apply this to my ipe deck? Kind of a novice
Sean
Sean
Will do! And thanks for the response. Couple questions I had: everywhere I’ve looked just says to clean first, but do I need to sand it? Also, maybe a dumb question, but after you apply the oil, it’s supposed to sit for 30 min before you wipe it down, if you did a large job in one go, wouldn’t you be stepping in the wet oil as you do it? And would that affect its appearance afterwards?
Liz
Liz
Open to other stain if you have a favorite for ipe…
Liz
Liz
Need to clean house with bleach based product before cleaning ipe deck,porches, stairs…if I wet the ipe first do you think the cleaner run off will be a problem for unfinished ipe? Then planning two step cleaning: do you have a preference for rad or deck Wise 2 step kits? Hope for matte rich natural color…preference? Considering rad in light walnut and ipe deck oil…close to 2000 sq ft so want to get it right…thinking no finish on ipe currently…purchased 3 yr old home with no info from previous owner
Liz
Liz
Thank you! And the two step kit? Rad also? And bleach run off ok?
161
