Restore-A-Deck Stain Stripper & Brightener Kit – Complete Deck Restoration Solution
Removes Old Stains & Brightens Wood for the Best Staining Results
The Restore-A-Deck Stain Stripper & Brightener Kit is a powerful, eco-friendly 2-step system designed to strip old wood stains and coatings while restoring and brightening the wood surface. This biodegradable, powdered concentrate kit includes:
✔ Step 1: Restore-A-Deck Stain Stripper – Removes old stains, dirt, mildew, and coatings
✔ Step 2: Restore-A-Deck Wood Brightener – Neutralizes the stripper, brightens wood, and restores pH balance
🌱 Eco-Safe & Biodegradable – Won’t harm plants or pets when properly rinsed
🏆 #1 Rated Deck Stain Stripper & Brightener Kit – Trusted by homeowners & professionals
🔹 Why Choose the Restore-A-Deck Stain Stripper & Brightener Kit?
✅ Removes Most Oil & Latex-Based Finishes – Strips clear film-forming varnishes, transparent, and semi-transparent stains.
✅ Brightens & Restores Natural Wood Color – Eliminates tannin & rust stains, prepping wood for new stain.
✅ Neutralizes Stain Strippers – Ensures optimal pH balance for better stain absorption.
✅ Prepares Wood for Staining – Ensures proper adhesion and longer stain life.
✅ Powdered Concentrate for Easy Mixing – Makes 10 gallons total (5 gallons per product).
✅ Safe for All Exterior Wood Surfaces – Use on decks, fences, siding, furniture, pergolas, and more.
📌 Note: This kit is not needed for removing solid color stains or paints. For those, use Restore-A-Deck Paint & Solid Stain Stripper Gel.
🔹 Where to Use the Restore-A-Deck Stain Stripper & Brightener Kit?
✔ Wood Decks & Railings
✔ Fences & Outdoor Furniture
✔ Siding, Gazebos, & Playsets
✔ Pergolas & Wood Walkways
📌 Use before re-staining for best results.
🔹 How to Use the Restore-A-Deck Stain Stripper & Brightener Kit
1️⃣ Mix the Stripper: 1 container with 5 gallons of water.
2️⃣ Apply Stripper Using a Pump Sprayer: Fully saturate the wood surface.
3️⃣ Let Sit for 10-20 Minutes: Allow the stripper to lift old coatings & stains.
4️⃣ Scrub or Pressure Wash Off: Rinse thoroughly.
5️⃣ Mix & Apply Brightener: Mix 1 container with 5 gallons of water.
6️⃣ Let the Brightener Sit for 10-15 Minutes: Restores pH balance and brightens wood.
7️⃣ Rinse & Allow Wood to Dry Completely Before Staining.
📌 Pro Tip: For tougher stains, mix stripper at a 3:1 ratio (3 gallons water per container).
✔ Get Your Deck Ready for Staining with the Restore-A-Deck Stain Stripper & Brightener Kit!
✔ Removes old stains & prepares wood for a fresh finish!
✔ Brightens & restores wood to its natural beauty!
🔹 Order the Restore-A-Deck Stain Stripper & Brightener Kit today and give your deck a professional-grade restoration!
Stain Types Removed
Restore-A-Deck Package 300
I have a PTP deck that was rebuilt 2 years ago. treated after waiting a year with Behr transparent waterproofing wood finish in clear – I think this is different than a stain – acrylic? the deck needs to be stained now. I used a deck cleaner but not sure if can now stain with a product it need to strip first ?? And will a stripper remove this ?
Yes, you need to strip. Use the RAD Stripper and both additives: https://www.deckstainhelp.com/product-category/restore-a-deck-stain-stripper-additives
Brightener last.
Will this work to remove the Rock salad 20 times De stain that we previously have on our deck
No deck stain stripper will remove deck resurface coatings like the Rust-Oleum Rock Solid:
