Restore-A-Deck Solid Color Stain Review 4.8/5 (8)
This post was updated on August 25, 2025
Hi, I am Scott Paul, a leading exterior restoration contractor and business owner with over 30 years of experience in exterior wood decking. My Review of Restore-A-Deck Solid Color Wood Stain is based on my history as a wood restoration contractor and actual hands-on testing, all designed to present you with the top deck stain choices. See here for more info about me.
Restore-A-Deck Solid Stain Review 2026
This is my initial Review of the Restore-A-Deck Solid-Color Wood and Deck Stain. This review will be updated over the years. As deck restoration contractors, Restore A Deck Solid-Color Stain will be our go-to Solid-Color Stain for 2026 due to its ease of use, 5 pre-mixed solid colors (the only solid stain on the market that comes pre-mixed), and the ability to prep and stain on the same day.
Note: Restore-A-Deck Wood Stain is the only stain we have tested that can be applied to dry or damp wood. Applying damp wood allows you to prep and stain on the same day, saving you a tremendous amount of time.
Restore A Deck Solid Color Wood Stain Review
Summary: Restore-A-Deck Solid Color Wood Stain is an extremely durable synthetic-resin, opaque wood finish that helps protect against the damaging effects of water, fungi, and UV radiation on exterior wood surfaces. This V.O.C.-compliant water-based product provides exceptional protection for nearly all exterior wood surfaces in a beautiful matte finish.
Restore-A-Deck Wood Stain can be applied the same day as the prep. Make sure that all standing water has dried off the surface after prep. Typically 2-4 hours at 70º F and less than 50% humidity.
Restore-A-Deck Solid Color Wood Stain can be used on interior or exterior horizontal and vertical wood surfaces, including wood siding, log homes, decks, fences, outdoor wood furniture, pressure-treated wood, and all other natural wood surfaces.
How I Rated Restore-A-Deck Solid Color Wood Stain
My Restore-A-Deck Solid Color Wood Stain review contains a 6-step process and the final average score. Each step is on a scale of 1-10.
  1. The appearance after the Application
  2. Peeling or Wearing
  3. Cost Per Square Foot
  4. Preventing Mold and Mildew
  5. How Easy Was the Application Restore-A-Deck Solid Color Wood Stain
  6. Ease of Reapplication
  7. Restore-A-Deck Solid Color Wood Stain Final Score
6-Step Review of Restore-A-Deck Solid Color Wood Stain
1. Appearance After Initial Stain Application: 10
Note: We used a two-toned deck stain approach for this Restore A Deck Solid Stain Review. This review is for the White Solid color stain applied to all verticals. To see our review of the RAD Semi-Transparent Stain, Click Restore A Deck Wood Stain
The Restore-A-Deck wood stain color we used was the Solid Classic Color in White for the Railings and Semi-transparent Dark Walnut for the Floor. The two coats applied to our PTP wood covered nicely and did not show any wood grain, which is expected with a solid stain. The application was even, and there were no overlap lines.
2. Wear/Tear and Peeling: 10
At the 2-year mark, there is no wearing or peeling anywhere on the white verticals.
3. Cost Per Square Foot: 8
We applied two coats to our 350 sq. feet of verticals that included all railings and steps. 2 Gallons were used for $59 per gallon.
4. Preventing Mold/Mildew/Algae: 9
Like other water-based solid color deck stains, the Restore-A-Deck Solid Color Stain will not promote mold or mildew growth. This is one of the main advantages of using a water-based coating. At the 2-year mark, the deck showed no mold or mildew.
5. Ease of Application: 8
Our favorite aspect of the Restore-A-Deck Wood Solid Color Stain is the ability to stain and prep on the same day. We tested this by cleaning and brightening the wood with the Step 1 and Step 2 Restore A Deck Cleaner/Brightener Kit and applying the RAD stain 1 hour after the prep. The Restore-A-Deck applies more easily to damp wood than dry wood. We also found that the coverage was better when applied to damp wood.
We applied both coats of the White RAD Stain to the wood with a roller and brush, waiting about 30 minutes between coats. The second coat goes on very easily and covers twice as far as the first coat. Overall, application with the Restore-A-Deck solid stain is very easy. It spreads excellently and is easy to work with.
6. Difficulty of Reapplication: 8
Clean and reapply using their Step 1 Deck Cleaner and a light pressure washing.
Overall Score Restore-A-Deck Solid Color Stain at 2-Year Period: 8.88
The Restore-A-Deck is a great Solid Color Stain. It is the only solid stain on the market that comes pre-mixed, making it much easier to choose a color. Restore-A-Deck Wood Stains have allowed the ability to Prep and Stain on the Same Day, giving it a huge advantage over other brands that perform just as well. If you are looking for the future of exterior wood and deck stains, consider the Restore A Deck Solid Color Wood Stain and its prepping systems.
Product Information
$67.99
More Info: Restore-A-Deck Solid Color Stain
Cost: $59.99 per Gallon. Products ship free on their website.
Available in Pre-Mixed Solid Colors: Classic White, Coastal Gray, Desert Taupe, Cypress, Brown Oak
Coats  Required: 2 Coats
Coverage Per Gallon: 200-400 sq. ft. Coverage varies depending on the age and type of wood.
Application Tools: Airless Sprayer, Brush, Roller
Dry Time: 2-4 Hours
Cleanup: Water
Manufacturer: Restore-A-Deck
Test Deck Stats
Deck Square Footage: 350 Square feet
UV Exposure: Full Sun
White
Restore-A-Deck Solid Stain Photos
How To Restore Your Deck All in One Day Video
345 Comments
LEW
LEW
3 months ago
I have a 28 year old deck that was last stained with Cabot oil based stain 3 years ago. I want to restain with restore a deck semi solid stain. Can I just pressure wash the deck before applying the stain?
RIck Norell
RIck Norell
5 months ago
I have a 25 year old shed with cedar trim and vertical t1-11.siding. It has portions with graying wood, some mold or mildew (particularly along the bottom of the t1-11 panels, and staining. I made annual applications of linseed oil for the first 15 years and then stopped (bad on me), I want to refinish the shed using a acrylic based SOLID stain. Will your three step process work on a shed (approximately 300 sqft of wood surface area). I live in eastern Idaho which is a semi-arid desert (low precipitation, low humidity, lots of sunshine)
RIck Norell
RIck Norell
5 months ago
Scott, thank your for your quick reply. I have a few follow-up questions.
Are your three products pet safe? There’s a colony of cats nearby that occasionally frequent my yard and I don’t want to cause any injuries.
Is the brightener step needed if I am using a Solid stain rather than semi-transparent?
My job is small, 300 sq feet and the T1-11 is very dry. The Solid documentation states that only one stain coat is necessary on vertical members. 95% of my project is vertical T1-11 + vertical trim and the remainder is trim mounted horizontally. Looks like I should may get by with 1 gallon but 2 gallons ensures sufficient product. Which would you recommend 1 or 2 gallons of solid stain?
Your paint comes pre-mixed, nice! Always advantageous to mix product during use, easy with a gallon pail of paint but how do your recommend mixing with your container?
Thank you for your time!
Julie
Julie
6 months ago
We used a Sherwin Williams solid stain for our decks. It did not hold up well (less than a year) with traffic from our dogs launching themselves off the deck to chase squirrels. Do you think Restore A Deck would last a couple of years?
bilJ
bilJ
8 months ago
for an old deck on it’s last leg, would you recommend the Restore-a-Deck solid stain (water based) or the Defy solid-stain (acrylic)? I am down to one of these two, just to try to get a few more years out of the deck before replacing all the wood. We have about 1350sq ft total. We will be using a stripper and then a brightner. Can’t finish the entire thing in one day, so the being able to stain while it’s damp isn’t really a huge factor, but it’s nice that we could do it in sections that way.
I have no preference between the two, and both are readily available in the chosen colors, just looking to see if would would work better in this instance. I would go with the Gulf Synthetics revive, but for the size of our deck, it’s more than double the cost of these two options.
deck
Judi
Judi
11 months ago
What do I use for a deck cleaner and brightner?
Xavier
Xavier
Is RAD solid stain deck like a paint that will sit on top of the deck surface, or is it penetrating? What are the risks to see it peeling down the road?
Xavier
Xavier
Was your use on vertical surfaces only? Or you have positive experience/feedback on horizontal surfaces (deck floor)?
Xavier
Xavier
OK…what is the best way to apply? brush, roller, pad, etc ?
Sagar
Sagar
will this RAD solid stain help to fill small cracks and splinters in the surface? If not, do you recommend something else be applied before using this?
Roger Davidson
Roger Davidson
We have an older pier on a large lake in central Alabama and have used solid color deck stain for several years. Because of all the changes in treated lumber over the years, some of the decking was there 20 years ago and some replaced 4-6 years ago needs replacing. The old decking has aged but it is still strong compared to some of the new decking that is now rotting away. We chose solid-color stain so it would have a similar appearance. What solid-color deck stain do you recommend? When re-applying, what suggestions do you have in addition to pressure washing? Any advice would be appreciated.
How does the solid espresso look after applying to a fence? More black than brown? How does it look in the full sun? Full sun photo on their website looks gray.
Thanks. Sounds like no gray tones. What would you suggest for this fence after strip with both additives and brighten?
PXL_20240318_155530976
PXL_20240318_155514712
Will do. In the meantime what’s the pros and cons between semi and solid stains. What are some pros for choosing a solid stain besides covering up imperfections
Anthony
Anthony
Your review is based on the railings which usually hold up much better and longer than the floor. What is your rating on the floor.
SEV
SEV
You did not use the solid stain on the deck floor, correct? How do you know that it will hold up as well as on the railing?
I have had 4 deck refinishers tell me to go with SW SuperDeck Exterior Waterborne Solid Color Deck Stain, they have heard of, but have no experience with Restore-a-Deck. Why are they wrong? Did SW change it’s product recently? Also, one said that synthetic resin in RAD would sit on top, not soak into checkering cracks. Can they get a discount on this product? Is it available locally in MIchigan or only online? Thanks.
SEV
SEV
Thanks very much
David Francis
David Francis
Can you use solid restore a deck on a previously solid stained deck?
Garrett Garner
Garrett Garner
I have a new fence that is rough cut pressure treated pine with 3 1×6 rails per section. I would like to stain it white or something to keep it light in color like new wood. Since it is rough wood, should I spray the stain? What would be the easiest way to apply the stain and which stain would work the best?
Carmen Schmidt
Carmen Schmidt
In the photos shown on this page for the Restore-A-Deck stain, what is the stain used for photos on page 1, 2, 3, and 6? The stain colors aren’t listed for these photos. I previously bought the Cypress solid stain color and it is too red for my liking. Can a new Restore-A-Deck color stain color be painted directly over the old color? The Cypress stain was painted on part of the deck and rails a few weeks ago. Thank you!
Samantha
Samantha
I’ve been looking for the best solid stain to use on my year old (never been stained yet) privacy fence. I was contemplating using BM Arborcoat. I was told to use only one coat as it contains a sealer and once it’s absorbed into the wood and sealed it will not allow another coat to be absorbed but will sit on top and peel. This makes sense to me unless it’s a wet on wet double coat. Also, the wood needs to be very dry as the sealer would seal in the water and then it would cause the stain to peel later. Do solid stains actually absorb into wood?
I just found your site and see that you recommend Restore-a-Deck as your go-to solid stain. I like the coverage that you got with two coats of the white since that is the color I will be using. I’m a bit confused though as to why it can be used on damp wood. Does it not contain a sealer to protect the wood? I don’t see that it’s water resistant or waterproof either. Is it really more beneficial to not seal the wood nor have water resistance? Aren’t these some of the reasons to stain wood?
I also know I need to pressure wash it before staining with RAD but do I need to use a special cleaning product also?It still looks very clean as it is. I’d like to get it done soon as we are having great weather this week.
Thank you so much.
Pete
Pete
I have two decks that are 28 years old at my home. They were never stained, just pressure washed. Are there some boards that I should change before I stain the deck? Or should I just change all the decking surface since the deck is so old? I would use the Restore-A-Deck. I attached some snapshots of the worst looking boards.
Pete
Pete
I want to extend the life of two 28 year old decks at my home using Restore-A-Deck stain, I am wondering what existing boards should be changed before I stain it. Or should all the decking be replaced (reuse everything else). Decks were never stained, but were pressure washed. Attached are photo examples of deck.
Pete
Pete
Would you recommend pressure washing before doing the cleaner and brightener kits? Thank you!
Alex
Alex
We just moved into a new house with a 10-12 year old 690sqft deck that has seen better days. I have lightly sanded and cleaned with Olympic deck wash. I was planning to paint with Behr advance deck over but thank God I checked reviews and found this site.
The deck area with the stairs was fixed with new wood and Sherwin Williams super deck solid deck stain. I am looking to cover the entire deck with a grey solid stain from RAD. The deck has some slight splintering but still solid. Looking for some advice on how to proceed.
1. Do I need to remove all the SW stain from the old and new wood before I stain with the RAD grey?
2. What about wash and brighten?
Matt
Matt
I’m just finishing stripping a semi solid stain off of my deck with a stripper solution do I need to use a brightener I’m planning on bleaching it to kill the mold etc. Also what kind/brand of stain is the easiest to reapply later so I want have to strip it again I’ve got roughly 1000sq ft of deck and I don’t want to go through this again it’s been a pain
Matt
Matt
I’m thinking semi transparent
Matt
Matt
I’m thinking semi transparent but whatever will last longest and not have to be stripped again
bill epps
bill epps
one year aged treated wood dock in salt water 400 feet long. what would you recommend?
Greg
Greg
Would you recommend Restore-a-deck solid stain or gulf synthetics deck revive for a old deck with splinters and cracks? Will gulf synthetics deck revive last longer than a restore-a-deck solid stain?
Amy Eston
Amy Eston
I have a deck in bad shape. I have replaced bad boards and sealed it.
I just need to paint it a color as a bandaid until I can replace it in a year or two.
what are your recommendations?
I was not aware of the class action suit against rock solid. I used it last fall on a small porch.
it is a vacation cottage so it’s fine that it looks a little rough. Now we will see how it holds up.
Amy Eston
Amy Eston
Thanks. Where do I buy it. I see company website and Amazon. Is it available locally?
Larry Rudisill
Larry Rudisill
Will RAD adhere to other solid stains such as SuperDeck, or Behr, or Arborcoat? Or do you need to strip the previous stain off?
Larry Rudisill
Larry Rudisill
Alex K
Alex K
Hi – have a customer in NC looking for a very specific mixed color to match pre existing stained trim that none of the premixed solids would match. Ideas for best solid stain for a deck with the ability to color match?
Richard J
Richard J
Im in upsate NY. MY tongue and grrove deck has peeling paint or solid stain cant tell which, that I am going to wirebrush, sand, and clean but I dont expect to get all the paint /solid stain off the deck. There is minor splintering of wood but the surface of the deck is solid.
Which RESTORE product is best for this application
X
345
