Restore-A-Deck Solid Color Stain Review 4.9/5 (9)
Hi, I am Scott Paul, a leading exterior restoration contractor and business owner with over 30 years of experience in exterior wood decking. My Review of Restore-A-Deck Solid Color Wood Stain is based on my history as a wood restoration contractor and actual hands-on testing, all designed to present you with the top deck stain choices. See here for more info about me.
  • Restore-A-Deck Solid Color Stain is the only solid stain on the market that comes pre-mixed in 5 colors, simplifying color selection significantly.
  • This stain can be applied to damp wood, allowing homeowners to prep and stain on the same day, saving considerable time over competing brands.
  • At the 2-year mark, tested results showed zero peeling, wearing, mold, or mildew on pressure-treated pine in full sun exposure.
  • Priced at $59.99 per gallon with free shipping, the stain earned an overall score of 8.88 out of 10 across six tested categories.
Restore-A-Deck Solid Stain Review 2026
This is my initial Review of the Restore-A-Deck Solid-Color Wood and Deck Stain. This review will be updated over the years. As deck restoration contractors, Restore A Deck Solid-Color Stain will be our go-to Solid-Color Stain for 2026 due to its ease of use, 5 pre-mixed solid colors (the only solid stain on the market that comes pre-mixed), and the ability to prep and stain on the same day.
Note: Restore-A-Deck Wood Stain is the only stain we have tested that can be applied to dry or damp wood. Applying damp wood allows you to prep and stain on the same day, saving you a tremendous amount of time.
Restore A Deck Solid Color Wood Stain Review
Summary: Restore-A-Deck Solid Color Wood Stain is an extremely durable synthetic-resin, opaque wood finish that helps protect against the damaging effects of water, fungi, and UV radiation on exterior wood surfaces. This V.O.C.-compliant water-based product provides exceptional protection for nearly all exterior wood surfaces in a beautiful matte finish.
Restore-A-Deck Wood Stain can be applied the same day as the prep. Make sure that all standing water has dried off the surface after prep. Typically 2-4 hours at 70º F and less than 50% humidity.
Restore-A-Deck Solid Color Wood Stain can be used on interior or exterior horizontal and vertical wood surfaces, including wood siding, log homes, decks, fences, outdoor wood furniture, pressure-treated wood, and all other natural wood surfaces.
How I Rated Restore-A-Deck Solid Color Wood Stain
My Restore-A-Deck Solid Color Wood Stain review contains a 6-step process and the final average score. Each step is on a scale of 1-10.
  1. The appearance after the Application
  2. Peeling or Wearing
  3. Cost Per Square Foot
  4. Preventing Mold and Mildew
  5. How Easy Was the Application Restore-A-Deck Solid Color Wood Stain
  6. Ease of Reapplication
  7. Restore-A-Deck Solid Color Wood Stain Final Score
6-Step Review of Restore-A-Deck Solid Color Wood Stain
1. Appearance After Initial Stain Application: 10
Note: We used a two-toned deck stain approach for this Restore A Deck Solid Stain Review. This review is for the White Solid color stain applied to all verticals. To see our review of the RAD Semi-Transparent Stain, Click Restore A Deck Wood Stain
The Restore-A-Deck wood stain color we used was the Solid Classic Color in White for the Railings and Semi-transparent Dark Walnut for the Floor. The two coats applied to our PTP wood covered nicely and did not show any wood grain, which is expected with a solid stain. The application was even, and there were no overlap lines.
2. Wear/Tear and Peeling: 10
At the 2-year mark, there is no wearing or peeling anywhere on the white verticals.
3. Cost Per Square Foot: 8
We applied two coats to our 350 sq. feet of verticals that included all railings and steps. 2 Gallons were used for $59 per gallon.
4. Preventing Mold/Mildew/Algae: 9
Like other water-based solid color deck stains, the Restore-A-Deck Solid Color Stain will not promote mold or mildew growth. This is one of the main advantages of using a water-based coating. At the 2-year mark, the deck showed no mold or mildew.
5. Ease of Application: 8
Our favorite aspect of the Restore-A-Deck Wood Solid Color Stain is the ability to stain and prep on the same day. We tested this by cleaning and brightening the wood with the Step 1 and Step 2 Restore A Deck Cleaner/Brightener Kit and applying the RAD stain 1 hour after the prep. The Restore-A-Deck applies more easily to damp wood than dry wood. We also found that the coverage was better when applied to damp wood.
We applied both coats of the White RAD Stain to the wood with a roller and brush, waiting about 30 minutes between coats. The second coat goes on very easily and covers twice as far as the first coat. Overall, application with the Restore-A-Deck solid stain is very easy. It spreads excellently and is easy to work with.
6. Difficulty of Reapplication: 8
Clean and reapply using their Step 1 Deck Cleaner and a light pressure washing.
Overall Score Restore-A-Deck Solid Color Stain at 2-Year Period: 8.88
The Restore-A-Deck is a great Solid Color Stain. It is the only solid stain on the market that comes pre-mixed, making it much easier to choose a color. Restore-A-Deck Wood Stains have allowed the ability to Prep and Stain on the Same Day, giving it a huge advantage over other brands that perform just as well. If you are looking for the future of exterior wood and deck stains, consider the Restore A Deck Solid Color Wood Stain and its prepping systems.
Product Information
$69.99
More Info: Restore-A-Deck Solid Color Stain
Cost: $59.99 per Gallon. Products ship free on their website.
Available in Pre-Mixed Solid Colors: Classic White, Coastal Gray, Desert Taupe, Cypress, Brown Oak
Coats  Required: 2 Coats
Coverage Per Gallon: 200-400 sq. ft. Coverage varies depending on the age and type of wood.
Application Tools: Airless Sprayer, Brush, Roller
Dry Time: 2-4 Hours
Cleanup: Water
Manufacturer: Restore-A-Deck
Test Deck Stats
Deck Square Footage: 350 Square feet
UV Exposure: Full Sun
White
Restore-A-Deck Solid Stain Photos
How To Restore Your Deck All in One Day Video
349 Comments
Michele
Michele
2 months ago
Scott, I have a HUGE deck, partial 2 floors. I have re-stained this 2 times over the past decade. We like it natural, first time Behr Waterproofing Wood Stain Natural/clear. It peeled horribly within months of application.
Couple of years later, we’d replaced so many boards, had planking of various ages that we decided to use a solid stain for uniformity. Benji-Moore Arborcoat (not on your ‘faves’ list).
We did a lot of work prepping the deck first: sanding/ stripping/ brightener. It looks like crap a little over 2 yrs later. Not only is this an expensive project but laborious. We want to hire someone to do this for us now. But it’s time to get this right. What do you suggest? Most of deck is in full sun. Have dog that runs around on it. Moderate foot traffic in summer. Pics attached.
3993DD94-EAFD-45AA-82DD-35820F6F7655
A1A8CA0B-7AB2-41AC-ADBE-2165A159AA00
740C5487-A076-49AD-8067-219E9CE7E007
CD4C9D72-CB5B-4C73-8025-06E045B2E1CB
Theresa
Theresa
2 months ago
In your review of Restore a Deck you mentioned no peeling on vertical surface after 2 years. Thai not unusual for most decent stains. What was the wear and peeling on horizontal surfaces? Thanks
LEW
LEW
8 months ago
I have a 28 year old deck that was last stained with Cabot oil based stain 3 years ago. I want to restain with restore a deck semi solid stain. Can I just pressure wash the deck before applying the stain?
RIck Norell
RIck Norell
10 months ago
I have a 25 year old shed with cedar trim and vertical t1-11.siding. It has portions with graying wood, some mold or mildew (particularly along the bottom of the t1-11 panels, and staining. I made annual applications of linseed oil for the first 15 years and then stopped (bad on me), I want to refinish the shed using a acrylic based SOLID stain. Will your three step process work on a shed (approximately 300 sqft of wood surface area). I live in eastern Idaho which is a semi-arid desert (low precipitation, low humidity, lots of sunshine)
RIck Norell
RIck Norell
10 months ago
Scott, thank your for your quick reply. I have a few follow-up questions.
Are your three products pet safe? There’s a colony of cats nearby that occasionally frequent my yard and I don’t want to cause any injuries.
Is the brightener step needed if I am using a Solid stain rather than semi-transparent?
My job is small, 300 sq feet and the T1-11 is very dry. The Solid documentation states that only one stain coat is necessary on vertical members. 95% of my project is vertical T1-11 + vertical trim and the remainder is trim mounted horizontally. Looks like I should may get by with 1 gallon but 2 gallons ensures sufficient product. Which would you recommend 1 or 2 gallons of solid stain?
Your paint comes pre-mixed, nice! Always advantageous to mix product during use, easy with a gallon pail of paint but how do your recommend mixing with your container?
Thank you for your time!
Julie
Julie
11 months ago
We used a Sherwin Williams solid stain for our decks. It did not hold up well (less than a year) with traffic from our dogs launching themselves off the deck to chase squirrels. Do you think Restore A Deck would last a couple of years?
bilJ
bilJ
for an old deck on it’s last leg, would you recommend the Restore-a-Deck solid stain (water based) or the Defy solid-stain (acrylic)? I am down to one of these two, just to try to get a few more years out of the deck before replacing all the wood. We have about 1350sq ft total. We will be using a stripper and then a brightner. Can’t finish the entire thing in one day, so the being able to stain while it’s damp isn’t really a huge factor, but it’s nice that we could do it in sections that way.
I have no preference between the two, and both are readily available in the chosen colors, just looking to see if would would work better in this instance. I would go with the Gulf Synthetics revive, but for the size of our deck, it’s more than double the cost of these two options.
deck
Judi
Judi
What do I use for a deck cleaner and brightner?
Xavier
Xavier
Is RAD solid stain deck like a paint that will sit on top of the deck surface, or is it penetrating? What are the risks to see it peeling down the road?
Xavier
Xavier
Was your use on vertical surfaces only? Or you have positive experience/feedback on horizontal surfaces (deck floor)?
Xavier
Xavier
OK…what is the best way to apply? brush, roller, pad, etc ?
Sagar
Sagar
will this RAD solid stain help to fill small cracks and splinters in the surface? If not, do you recommend something else be applied before using this?
Roger Davidson
Roger Davidson
We have an older pier on a large lake in central Alabama and have used solid color deck stain for several years. Because of all the changes in treated lumber over the years, some of the decking was there 20 years ago and some replaced 4-6 years ago needs replacing. The old decking has aged but it is still strong compared to some of the new decking that is now rotting away. We chose solid-color stain so it would have a similar appearance. What solid-color deck stain do you recommend? When re-applying, what suggestions do you have in addition to pressure washing? Any advice would be appreciated.
How does the solid espresso look after applying to a fence? More black than brown? How does it look in the full sun? Full sun photo on their website looks gray.
Thanks. Sounds like no gray tones. What would you suggest for this fence after strip with both additives and brighten?
PXL_20240318_155530976
PXL_20240318_155514712
Will do. In the meantime what’s the pros and cons between semi and solid stains. What are some pros for choosing a solid stain besides covering up imperfections
Anthony
Anthony
Your review is based on the railings which usually hold up much better and longer than the floor. What is your rating on the floor.
SEV
SEV
You did not use the solid stain on the deck floor, correct? How do you know that it will hold up as well as on the railing?
I have had 4 deck refinishers tell me to go with SW SuperDeck Exterior Waterborne Solid Color Deck Stain, they have heard of, but have no experience with Restore-a-Deck. Why are they wrong? Did SW change it’s product recently? Also, one said that synthetic resin in RAD would sit on top, not soak into checkering cracks. Can they get a discount on this product? Is it available locally in MIchigan or only online? Thanks.
SEV
SEV
Thanks very much
David Francis
David Francis
Can you use solid restore a deck on a previously solid stained deck?
Garrett Garner
Garrett Garner
I have a new fence that is rough cut pressure treated pine with 3 1×6 rails per section. I would like to stain it white or something to keep it light in color like new wood. Since it is rough wood, should I spray the stain? What would be the easiest way to apply the stain and which stain would work the best?
Carmen Schmidt
Carmen Schmidt
In the photos shown on this page for the Restore-A-Deck stain, what is the stain used for photos on page 1, 2, 3, and 6? The stain colors aren’t listed for these photos. I previously bought the Cypress solid stain color and it is too red for my liking. Can a new Restore-A-Deck color stain color be painted directly over the old color? The Cypress stain was painted on part of the deck and rails a few weeks ago. Thank you!
Samantha
Samantha
I’ve been looking for the best solid stain to use on my year old (never been stained yet) privacy fence. I was contemplating using BM Arborcoat. I was told to use only one coat as it contains a sealer and once it’s absorbed into the wood and sealed it will not allow another coat to be absorbed but will sit on top and peel. This makes sense to me unless it’s a wet on wet double coat. Also, the wood needs to be very dry as the sealer would seal in the water and then it would cause the stain to peel later. Do solid stains actually absorb into wood?
I just found your site and see that you recommend Restore-a-Deck as your go-to solid stain. I like the coverage that you got with two coats of the white since that is the color I will be using. I’m a bit confused though as to why it can be used on damp wood. Does it not contain a sealer to protect the wood? I don’t see that it’s water resistant or waterproof either. Is it really more beneficial to not seal the wood nor have water resistance? Aren’t these some of the reasons to stain wood?
I also know I need to pressure wash it before staining with RAD but do I need to use a special cleaning product also?It still looks very clean as it is. I’d like to get it done soon as we are having great weather this week.
Thank you so much.
Pete
Pete
I have two decks that are 28 years old at my home. They were never stained, just pressure washed. Are there some boards that I should change before I stain the deck? Or should I just change all the decking surface since the deck is so old? I would use the Restore-A-Deck. I attached some snapshots of the worst looking boards.
Pete
Pete
I want to extend the life of two 28 year old decks at my home using Restore-A-Deck stain, I am wondering what existing boards should be changed before I stain it. Or should all the decking be replaced (reuse everything else). Decks were never stained, but were pressure washed. Attached are photo examples of deck.
Pete
Pete
Would you recommend pressure washing before doing the cleaner and brightener kits? Thank you!
Alex
Alex
We just moved into a new house with a 10-12 year old 690sqft deck that has seen better days. I have lightly sanded and cleaned with Olympic deck wash. I was planning to paint with Behr advance deck over but thank God I checked reviews and found this site.
The deck area with the stairs was fixed with new wood and Sherwin Williams super deck solid deck stain. I am looking to cover the entire deck with a grey solid stain from RAD. The deck has some slight splintering but still solid. Looking for some advice on how to proceed.
1. Do I need to remove all the SW stain from the old and new wood before I stain with the RAD grey?
2. What about wash and brighten?
Matt
Matt
I’m just finishing stripping a semi solid stain off of my deck with a stripper solution do I need to use a brightener I’m planning on bleaching it to kill the mold etc. Also what kind/brand of stain is the easiest to reapply later so I want have to strip it again I’ve got roughly 1000sq ft of deck and I don’t want to go through this again it’s been a pain
Matt
Matt
I’m thinking semi transparent
Matt
Matt
I’m thinking semi transparent but whatever will last longest and not have to be stripped again
bill epps
bill epps
one year aged treated wood dock in salt water 400 feet long. what would you recommend?
Greg
Greg
Would you recommend Restore-a-deck solid stain or gulf synthetics deck revive for a old deck with splinters and cracks? Will gulf synthetics deck revive last longer than a restore-a-deck solid stain?
Amy Eston
Amy Eston
I have a deck in bad shape. I have replaced bad boards and sealed it.
I just need to paint it a color as a bandaid until I can replace it in a year or two.
what are your recommendations?
I was not aware of the class action suit against rock solid. I used it last fall on a small porch.
it is a vacation cottage so it’s fine that it looks a little rough. Now we will see how it holds up.
Amy Eston
Amy Eston
Thanks. Where do I buy it. I see company website and Amazon. Is it available locally?
Larry Rudisill
Larry Rudisill
Will RAD adhere to other solid stains such as SuperDeck, or Behr, or Arborcoat? Or do you need to strip the previous stain off?
Larry Rudisill
Larry Rudisill
Alex K
Alex K
Hi – have a customer in NC looking for a very specific mixed color to match pre existing stained trim that none of the premixed solids would match. Ideas for best solid stain for a deck with the ability to color match?
Richard J
Richard J
Im in upsate NY. MY tongue and grrove deck has peeling paint or solid stain cant tell which, that I am going to wirebrush, sand, and clean but I dont expect to get all the paint /solid stain off the deck. There is minor splintering of wood but the surface of the deck is solid.
Which RESTORE product is best for this application
Keith
Keith
Thanks for all you do to provide this very helpful resource.
We have a covered porch with 6×6 cedar posts and 4×8 cedar beam facing south, taking direct sun throughout the day. This work was done 10 years ago when we moved into the home. The stain has held up nicely for areas not exposed to the sun, but peeling in areas that do have direct exposure to the sun. I’ve pressure washed most of the stain off of the posts (please see photo below). I plan on sanding them today.
For the beam, the stain is on there good. I won’t be able tp pressure wash the beam to strip it down to bare wood like I did the posts without damaging the wood. Can I just clean the beam with deck cleaner, lightly pressure wash to remove any loose stain, and apply RAD over both posts and beam? If so, which product would you recommend?
Brett Hollenbeck
Brett Hollenbeck
Can I use a RAD solid water based stain over a previous oil based stain on my deck? The current stain is OneTime wood, which did not last anywhere near 7 yrs as advertised. It is very weathered, but no pealing, and has now been power washed. Thanks
Brett Hollenbeck
Brett Hollenbeck
Greg
Greg
I have a small wood deck that was painted before I bought my house. It peeled but the spots that didn’t peel where hard to strip. So I sanded, pressure washed, let dry and applied a peel stop primer from zinsser. Painted with Behr porch and patio. After a year it’s held up to weather and traffic, but my plastic chairs stick and peel off little spots whenever they’re moved. I live in Florida. The deck gets sun half of the day. Any recommendations on a more durable paint that can be applied to already painted surfaces?
Myra French
Myra French
Where can I find the sample colors of the restore-a-deck solid stain?
James C Williams
James C Williams
I spent a fair amount of monies on a deck product named Wood rx, was suppose to be a good product.
I bought a airless sprayer and 10 gallons of this stuff did an 85 ft deck and ramp and my back deck 28 ft by 16 dec. after seven or eight months it is peeling I am very disappointed can I use your product to spray over this or how do I go about re-doing these decks. They were All treated lumber which I was told had to be weathered for 8 months which I did, my question is can I use your product over my peeling deck as is?
I went to your website and I drove the 8 miles each way to this store that you list is selling your product, I got there and they do not sell your product. I’m asking if you could tell me for sure where in this area sells your product. Thank you
On your website you list a paint company called North Cromwell paint on Haggerty Road in Michigan, Walled Lake area that sells your product. I went there today and they do not sell your product. I live in the town of Farmington Hills Michigan can you direct me to someone that sells your product locally that I can drive to and talk to about Restore a deck products and purchase it from them? I understand that you’ll ship for free etc., but I’d really like to talk to somebody that’s handled your sproduct here in Michigan. Can you please Provide me with a paint store that handles your product, Thank you John
Ginny
Ginny
I understand the basic difference between opaque and semi-permanent stain, but I am not clear how you decide which one to use. I live in an HOA and we are required to use cedar color on our decks but the type of stain is not designated. I have cleaned and brightened the deck but I’m not sure where to go from here. I don’t know if what was originally used was semi-transparent or opaque. And does it make a difference if I put semi-transparent over opaque?
Ginny
Ginny
Had to wait until the deck dried out after the rain. Thanks in advance.
Ginny
Ginny
Thank you! Appreciate the help!
Thank you for responding. So again I’m looking for step one through X. Step one, pressure wash get all the peeling off is there a step two of using a chemical to clean the deck and then step three to sand and a step for to shine the deck to open up the pores and then a step five to apply you’re solid stain decking? When I apply your solid stain, if the boards are dry and the humidity is 70% am I good to still put the stain on? Just looking for a clear directions, but again thank you for getting back to me so soon. This is a great feature you guys offer. John
I’ve been using Sherman Williams decks scape solid stain The last three years. I live in Michigan and each spring it peels up all over the place. I pressure wash it, scrape it, clean it and in some portion sand it, we have a lot of humidity and it’s hard to get a few days without humidity to apply the solid stain. I’m thinking of trying your products. Would like to know your step one, step two, step three etc. I would use a solid stain. I want to avoid it peeling each year. Adding another coat every two or three years is not a problem, dealing with all the peeling and starting over from scratch each year is the problem. Part of me thinks that the boards have never dried out or there’s too much snow in moisture in the winter and they never get a chance to dry out. Also applying the stain if there’s humidity in the air. I can apply the stain when it’s 40 to 60% but it’s hard to find a couple of days words that are under. How does humidity and applying your stain work? Your advice and plan of attack is welcomed.
Jeff
Jeff
Great site! I’m likely going the RAD solid gray route. I’ve stripped my cedar deck with a Diambrush, fill holes/rot and will final sand to 60 or 80. Deck was previously finished in Benj Moore solid Arborcoat
Question – Do I have to get 100 % of any former stain remnants off? Think the grey color, not any loose stain or chips. Basically does it have be sanded to pristine almost ‘newly installed wood’ condition?
Question – do I need any sort of brightener/pre-stain or can I just use the RAD Solid Stain right over the newly stripped/sanded wood?
Dennis
Dennis
I will be sanding my 15 year old cedar deck down to the bear wood. Would it be considered new wood? I read in a comment reply that new wood would have to wait 30 days to be stained. Is this true for an older deck? I will be applying RAD solid color stain?
Dennis
Dennis
Hi, I live in the northeast USA. Last year I sanded my cedar deck down to the bear wood. I applied a water base primer and painted two coats of white California Allflor porch and patio. It came out beautiful! A few weeks later it started tanning.I was told to put an oil based primer and coat the deck again with the California Allflor porch and patio.The next season it peeled terribly and has been peeling every since.(See pictures) I was devastated. I contacted California paint again with no resolution.
I am planning to sand the deck down again to the bear wood (Cedar). I want to use a white solid color again.What product would you recommend? How can I prevent tanning again through the white? Or should I just go with a light gray color if tanning is inevitable ?
Dennis
Dennis
Thank you for your fast reply. Also should I prime this older cedar wood deck which has quit a bit superficial cracks or just apply the Restore A Deck alone? If so oil or water base primer.
Thank you again!
Paula
Paula
Does the solid RAD stain last longer than semi-transparent? I’m restaining a pressure treated, full sun deck in western NC. Comments read say solid provides better UV protection so I thought it would last longer. Tired of sanding and restaining every 2 years
Jeff
Jeff
Posted this at RAD this morning and did not get a response that leads me to a solution down the road & wondering if anyone here can give advice.
My post: Replaced an old PT deck with new cedar April of this year. Per instructions, allowed it to weather 3 to 6 months, in this case 4 months as I just went through the RAD process this past week. Clean/brighten/stain. The cleaner seemed to do its job. The weathering was scrubbed off mostly with hard bristle brush and then power washed off. Brightener immediately was applied, allowed to sit for about 15 minutes then the whole deck power washed for 1/2 hour. The deck was permitted to dry for a day & 1/2 until I could get to staining. The stain was applied with a hand brush and appeared to be soaked up easily. The deck is a modest size (30 x 12) and I had just enough in the 1 gallon to do the job. Per instructions on the label, only 1 coat was applied being it was on new decking. The stain was light walnut, semi transparent. The result was less than great as it ended up quite blotchy. Questions…is this usual or expected when using the lighter stains on (new) cedar? Would I expect the next year maintenance reapplication to partially correct this? Is there an obvious mistake that was made here that you can see? The lack of absorption around the knots lead me to believe either the wood needed much more than 4 months to weather, or this is the expected result with that type of stain. If so, are there any immediate correction actions that can be taken? Thanks for any help you can provide.
RAD response: No, this is not a normal result, and not sure what went wrong outside of your wood having very uneven porosity. The easiest thing to do is clean and recoat in the Spring. No immediate concerns as it is protected.
Continuing…
So it is what it is, I suppose, but I can look forward to no better result come next season reapplication. (?) Should I consider sanding with 60 or so to make porous? Should I consider a darker stain or even a solid stain or a different stain? Will I need to strip this RAD completely off or can I clean it up and apply another coat of something else? Any advice?
Jeff
Jeff
Thanks. Any issue applying RAD solid over the RAD semi-trans next season?
Melanie
Melanie
I would like some clarification here. I was under the assumption that if changing from RAD semi to RAD solid, one would need to first strip the Semi off 1st.
I’m in a similar situation, though it has nothing to do with porosity or knots, just a change. Stripped last year, then did one coat of RAD Semi & now want a RAD solid.
I’m not just checking that I’ve read this correctly.
We have a solid dark brown stain throughout on the rails, ballasters, posts, and deck from a previous owner. Looks slopped on with little preparation and the components have weather related checking and cracking. Currently the finish is peeling on the flat surfaces. We’d like to go with white for the rails and ballasters with a dark color for the deck surface. Any ideas to get the white to cover or is this simply a horrible idea? Suggestions to remove the existing finish are welcome.
Climate is middle TN with exposure to sun, shade, some snow, and rain. Thank you in advance.
Ed G
Ed G
Why doesn’t anyone give straight upfront reviews on composite deck refinishing products?
Donna Pedrick
Donna Pedrick
I’m sanding my deck, I’ve used 60 then 80 grit .. what should my final grit number? I’m using RAD solid
Rian
Rian
We applied behr solid stain paint to our fence several years ago. We’re in the process of sanding down the fence as the wood – paint has cracked up in places where snow sits etc. Do we need to remove the existing behr solid stain paint or can we just paint over it with another product.
Andria
Andria
can this be used over behr solid color waterproofing stain and sealer? has some peeling and worn areas
Andria
Andria
How much would I need for 814sq ft?
Donna
Donna
I just hand scraped and removed Olympic Rescue It NIGHTMARE off my 30×60 deck. I would like to use a solid stain but never want to scrape my deck again if I want to touch it up in the future. What product can I use for a solid stain and reapply for touch up in the future? Do solids come in an oil base ? Do acrylic or water bases peel ? Also, some of my knots are leaking sap. Will this affect my new application. Please Help !
Kate
Kate
Covering over an existing solid stain particularly chocolate brown Arborcoat. Any special prep?,
Joyce
Joyce
I have a new pressure treated pine deck installed 9 months ago and am now ready to sand, clean, brighten and stain. Should I sand before cleaning and brightening or after. It needs major sanding.
Joyce L Marlow
Joyce L Marlow
Sorry. I don’t understand. Are you saying cleaning 1st, sanding 2nd and then brighten 3rd?
Joyce
Joyce
Is it best to clean with a commercial cleaner for decks (which I thought was best as it removes the mill glaze) or to have the new deck power washed?
Joyce
Joyce
I was under the impression that a commercial cleaner needs to be applied and then use a brush to scrub the deck clean. Is it best to power wash or scrub?
Thanks for all your help.
Scott Hemphill
Scott Hemphill
Is this item available in stores
Jim Caldwell
Jim Caldwell
What is the best deck stain for the Seattle Washington area
Jim Caldwell
Jim Caldwell
solid
Jim Caldwell
Jim Caldwell
Thanks. Your service is appreciated!
Shirley McCray
Shirley McCray
If I use solid white stain on the gazebo, and dark semi-transparent on the floors, do you think the high-back glider seats should be solid white or dark semi-transparent?
Chrissy Goodrich
Chrissy Goodrich
Has anyone used the cottage gray semi transparent color and have a picture?
Carol
Carol
How well does this hold up in extremely cold, snowy winters and hot humid summers? Minnesota…
Carol
Carol
Thanks for the quick response. We’re thinking of hiring a guy to redo our deck and he’s pushing pretty hard to use Cabot solid stain. I’m not impressed with the reviews that I’ve seen.
tracey wilson
tracey wilson
Can this solid stain be put over Russet colored Behr premium deck over that has been cleaned, scraped & sanded with a pole sander? There are still many areas where the deck over is still in tact, but there are also bare wood areas and wood putty as well, now (thanks to this crappy stuff). We will be priming it with Rustoleum rock solid clear deck primer. Not sure if we should topcoat with Kilz porch deck and floor paint of this solid stain???
Rory
Rory
Looking to use the RAD solid deck stain over stripped deck. How long does it last? Are there any 2 or 3 or 4 year reviews for durability? Thx
Joe S
Joe S
Can I add sand or silica to solid RAD for use on deck floor boards?
Krista
Krista
We have a cedar garage door that we believe was stained with SW SuperDeck Charcoal. It has faded and developed lighter colored spots over the last couple of years. Can we use RAD solid over this or is there something else you suggest? We are hoping for a very dark brown finish.
Courtney C
Courtney C
I am painting a cedar playhouse. Is the RAD solid color classic white stain a good one to use for this project? Also, what stain applicators do you recommend I use?
Bill Terwilliger
Bill Terwilliger
We have a dark stain on our deck now. We would like to change it to a light cream color. Is that possible with RAD prep and stain? We live in Indiana and the
Deck is in full sunlight.
Bill Terwilliger
Bill Terwilliger
Here’s what is on the deck now.
Bill Terwilliger
Bill Terwilliger
Here is the picture of the deck, product is Olympic stain
Jenny Taylor
Jenny Taylor
I am having a hard time having restore a deck semi transparent 5 gallon pecan or dark walnut colored stain delivered in California – I live right outside of San Francisco and I cannot get anyone to deliver the product to me or even allow me to purchase it where do I go to get restore deck products delivered or purchase and pick up
Bee
Bee
I live in the Pacific Northwest where it rains the majority of the year. I stained my deck two years ago with armstrong clark semi-transparent oil-based stain had to replace it again last year because it was moldy and patchy now this year it’s moldy and patchy again so I’m ditching that. I wanted to know if I can cleanand brighten it with restora deck next year and then put this type of stain over the top of it?
Additionally what type and brand of stain do you think is best for an extreme rainy climate
Rondi
Rondi
We live on the east coast of Florida, full sun, humidity and salt. Our deck and stairs are 2 years old.
Will RAD solid stain hold up well or would you recommend another product?
Rondi
Rondi
How long will the semi-trans last on horizontal surface with light traffic?
Catherine McCue
Catherine McCue
Can Restore-A-Deck Solid Stain be applied over Behr solid stain (applied a couple of years ago)?
Michele
Michele
Do you know anything about Valspar solid stain with 10 year guarantee? How does it hold up?
Brenda Peek
Brenda Peek
We just installed a cedar deck that has been up for about a month and a half. How would we prep and what is best water-based or oil base if we live on the bay in Texas with high moisture and lots of rain?
Tong
Tong
Our deck is maybe 5-10 years old, looks never been painted before. We did pressure wash 2 weeks ago and I use the wood cleanser and scrub the surface yesterday. But probably the pressure wash and scrub is too much, now somehow it looks rough. Do we need to sand to make the surface smooth before paint?
Also we are struggling on whether to choose solid stains or semisolid or semitransparent. I want it to be more durable, I don’t want it peel in a year and we need to prep and repaint every year. Please help on decision-making…
vjai
vjai
My deck is probably 10 years old. Looks like it was never treated before. I had a friend do pressure wash on it a couple of months ago. That cleaned my deck very well. The pictures attached are what it looks like now (2 months after pressure wash). For various reasons, I was not able to stain the deck since then.
I am unsure about solid vs semisolid vs semitransparent stains. The condition of wood to me looks like I should do a solid stain. Please help me in decision-making. I am not a handy person, have hired a person. We will be using Restore-a-Deck cleaner to clean it further and will be using the stains recommended here.
Teresa
Teresa
Reply to  vjai
I would so love to see what you ended up choosing. My deck boards looked so bad after power washing that I sanded them. However, they still appear uneven in looks.
Dawny
Dawny
I have a deck stained with solid stain, Sherwin Williams Deskscape, finished in 2013. Deck boards are a dark brown, Bench, railing, fascia trim and perimeter boards are a dark, warm cream. I plan to reapply a solid stain in similar colors (probably RAD in Espresso and Desert Taupe).
I have power washed the deck without cleaner. Existing stain is very compromised in areas where the deck was exposed to the elements. Some boards will have to be replaced, mainly perimeter boards and fascia trim but a few deck boards are damaged enough to warrant replacement.
Should I replace the damaged boards and wait until the spring to strip, brighten, sand and apply solid stain (to allow the new boards to age)? Or can I do all of this at the same time (this fall). I live in northern Illinois so there won’t be an option to complete project until probably April or May if I don’t get it done before late October, early November.
Also, given the photos, I believe I need to strip off what I can and then sand the deck. Is this correct? If you can’t get all the stain removed, is it safe to reapply a coat of solid stain?
Dawny
Dawny
Thanks for the quick response!
Muchelle
Muchelle
Has anyone used the coastal grey? Is it a warm grey or a cool grey? Thx!
Annette Merwine
Annette Merwine
I would like to do a two color application. Solid and semi transparent. I’ve have decided on my colors and confident on application. But not sure on how to incorporate the two colors. My thoughts were having the solid stain on the uprights and spindles. Semi solid on deck boards and top railing. Any help would be appreciated. Going to use restore a deck solid and semi transparent.
Great site, lots of information and easy to navigate.
Kim
Kim
I am in the process of trying to refinish our deck. The previous owner used Behr deck over. What is the best method for removing it? Some has just peeled off but I read that it must all be removed before adding RAD. Should I use a paint stripper? Power wash? Sand? Clean and brighten? In what order? Is RAD the best product? We need it to be a light color because it gets direct sun. Thanks!
Kim
Kim
What is your experience with Armstrong-Clark stain over RAD? Is one better than the other?
Raylene Pak
Raylene Pak
Reply to  Kim
I had a very bad experience with the Behr Deck Over paint. Getting it off was an even worse experience. I found using the Porter Cable 4” Restorer in conjunction with its Porter Cable PXRARP01 Restorer Paint and Rust Remover Roller Wheel to be very effective in removing that finish without compromising the underlying wood. Added benefits were it left the wood nicely sanded, was relatively inexpensive and something an inexperienced DIY’er could do.
Can you recommend and supply a stain perform well for a north facing southern Ontario deck? The deck surface has old pressure treated planks that have been turned over to expose a less weathered face. Hoping to increase the effective life of an appropriate stain, all cracks and screw head depressions have been filled with a light brown epoxy wood filler (P.C.Woody brand) followed by a thorough 60 grit sanding. Some brown end-cut preservative has been applied to plank edges and ends.
I have since been informed that a deck stain may not bond well to a wood filler. However, now that the filler has been used, can you recommend the most suitable solid and/or semitransparent stain for this deck.
Frank
Frank
Thanks for the helpful review. The picture of RAD Dark Walnut semi-transparent stain you used on the horizontals do not match the picture you have on this review. Did you start with naturally dark wood deck boards? I’m looking to get a dark finish, and the picture RAD has for Dark Walnut doesn’t come close. Thanks!
Frank
Frank
I thought as much. Thanks! If you happen to have a picture of the pressure-treated pine before staining, please share. Many thanks!
Gerald Burke
Gerald Burke
Hello,I have lightly sanded my cedar deck ready to cover again with Para cedarcare protector well I can not find this product anywhere its a water base product any ideas out there.Thanks
Donna
Donna
I’m having my old deck restored (floor, rails, and stairs) with new KDAT pressurized pine. I am thinking about a two tone look with a darker floor and white rails. There will be metal balusters. Is it okay to use solid stain on new wood (after waiting 1-2 months)? I know semi transparent is usually recommended, and only one coat, but I don’t see white in semi transparent.
Donna
Donna
Thank you. I love the look of the deck with dark walnut floor and white rails that was tested with the RAD solid stain. Could I use the solid RAD stain on new floor deck boards too?
William
William
Hello, this site has been very helpful in researching for my project (new to decking). I’m looking to re-surface our deck (20+ years old), which has two solid color paints (unsure if it’s solid color stain or exterior paint) – white on railings/verticals and a maroon-ish on the deck floor. The paint is peeling, wood is rotting in some areas (planning to use wood expoxy to fix the rotted areas) and has some mildew. Do I need to strip or can I just apply a cleaner and power wash before I sand and apply paint? As for the paint, I assume the best way to match the color is to take a sample into a local store? There doesn’t appear to be a maroon-ish color for the RAD solid color stain and the local stores don’t seem to carry the Defy solid color stain…Thanks in advance!
William
William
Thanks very much. Do you recommend solid color stain vs. exterior paint for the deck? And should I use the RAD stripper + 2 additives even if it’s a solid color paint I’m trying to remove?
William
William
Thanks very much. Will I need to brightener as well to neutralize the stripper/additives?
Janeece Anderson
Janeece Anderson
Where can I purchase this? I can’t find it online..
Jill
Jill
Hello! We just bought a house that has a 600 square foot deck that is in need of repair. The previous owners used Rust-oleum Deck and Concrete Restore 2x One Coat Solid Stain. We have pulled boards that had dry rot and replaced them with pine because we thought we were going to use Behr Deceiver (no way after reading reviews). So we possibly have different types of wood down on the deck. We have narrowed our choices down to RAD Solid Stain, Gulf Synthetics Deck Revive or KILZ Porch and Patio Latex Paint. My question is, if we have different types of wood, will the solid stain cover that fact or will you be able to see the difference? Out of these three products, what would you recommend? My gut is telling me Gulf Synthetics, but that cost has got me scared. Do we need to strip the Rust-oleum Solid Stain completely or just power wash and remove loose pieces? Thanks so much for your help and advice!
Jill
Jill
Thank you so much!
Karen
Karen
12×12 pressure treated wood deck with Cabot semi_ transparent stain 3 years ago. No peeling. Small areas of mildew in corners. Do i need to prep first with RAD brightener and or cleaner then use RAD solid stain? Or just stain? Thanks
What would be the best way to apply a solid stain? Looking to redo a 1200 square ft deck with the solid Cyprus color. Power washed it, used deck cleaner and sanded. Now the final step.
Dan
Dan
Your Wear/Tear Peel review for Restore-a-Deck was for the verticals. Did you test how their solid stain did on the deck itself, as in the horizontals?
Renee Sturges
Renee Sturges
My deck is old, but clean and sanded, no rot. Some boards have a dent from removed split pieces. I am looking to cover with a paint or stain but do NOT want it to peel. What product is best to use to avoid peeling?
Haley
Haley
Our deck was previously coated in Deckscapes solid stain in black. We’d like to change it to a lighter color because it’s very hot on your feet midday (even here in Maine). I’m considering the RAD solid stain in coastal grey. What’s our best course of action for prepping? My husband wants to do it himself, but we’re new to deck maintenance. Thank you!
Haley
Haley
No need to sand or otherwise treat? The grey stain will cover despite it being black currently? Thanks!
Haley
Haley
No need to use a stripper? Thanks for your time!
Sara
Sara
Can this product be used with a HVLP sprayer?
Nathalie
Nathalie
Hi! We are in the process of restoring our deck on our seasonal camping lot. We have bought last year an older deck and rearranged it to fit our need and camper. We had to had pieces to the deck to complete it with new wood. Plus, we added a brand new railing to it with new wood. The “old” part of the deck was solid painted. We have removed the paint last year with a pressure washer. Now, we want to stain or paint it this year, but we are wondering what would be our best solution: stain or a solid paint. And should we put the railing the same color? The wood on the older part doesn’t look too good….and I am afraid that stain will not cover enough and it will not look good… it’s grey and have cracks…perfect for a camping site though. Thanks for your help!
Sharon Ann
Sharon Ann
I have a cedar Arbor I stained with Cabots Solid stain about 4 years ago no peeling and I want to use Restore A deck Solid stain can I just go over it or do I have to clean and brighten Or strip it?
Hi, what Tip size do you recommend for airless spraying of the railings with the RAD Solid Stain. The two tone deck looks great. I want to do the same.
Tanner
Tanner
The RAD app sheet recommends 0.013 to 0.015 for tip size.
liz
liz
cn this be used on a dock that sits over water?
John Muller Associates
More of a comment than a question first. Just below my first question i looked again at JIMS pics. I have almost the EXACT same deck situation…peeling, divits/cracks and crowded boards. I wanted to know if the ballisters are in fair shape can I just scrape the bad areas, sand and wash. Then paint with a brush or roller?
By the way I am carefully running my circular saw down through the joints in order to re-space and remove old debris and paint.
??After I measure the deck surface square footage what is th best way to calculate the paint quantity for the ballisters, top railings and steps?
Im prepping my deck for your solid stain. Im using PC pe reviewsetrfier on the questionable areas and fill divits with PC wood paste. Is this going to cause an adhesion problem with your solid stain? PS I love your reviews and hope that i am not to late.
Thank your John
I am getting ready to stain our deck. Not sure what was used on it before but it is peeling on the floor boards. The railings seem ok. Can I just pressure wash and clean it and use RAD solid stain over what doesn’t come off or are there additional steps I need to take. Thanks.
Do I need to apply any type of primer before I use the RAD solid stain? Thanks.
Gloria Jordahl
Gloria Jordahl
My deck has 2 applications of One Time over the course of 8 years, the last being applied in 17. What would you recommend doing to freshen it? Could I use Restore a deck to restrain it or an other stain? What preparation would need to be done?
Gloria Jordahl
Gloria Jordahl
Would I be better off just reapplying One Time again? Had hoped I could just restrain without sanding or stripping..
Peter
Peter
How many people have used restore A deck SOLID stain on there deck and at the two year mark how does it look now and are you happy with the results ?? Please people let me know !
Beverly Lemaster
Beverly Lemaster
My client has a newly built wrap around porch on their house. It has only been 4 weeks. It will be getting a lot of harsh sun so this product seems ideal. How long do you recommend waiting before the floors are stained? The builders are wanting me to go ahead and stain the post before they put up the screen on the section that will be a screen porch.. what would be your recommendation?
Les
Les
Have pine deck refinished 3 years ago. Many new boards replaced at that time. Now time to refinish and used Deck Over last time. Unhappy with results. Replaced boards peeled badly while older boards seem to have held up better. Thinking of using Cabots solid cedar stain. What are your thoughts for prep and refinish?
Les
Les
Thanks for timely response even though it’s not what I wanted to hear!
Peter Madsen
Peter Madsen
Just bought a house built in ’96 that needs to be stained before closing. It is weathered, not sure if or what it was treated with last. See pictures of two tone appearance due to sun. Thinking of going with RAD solid stain product if available but was hoping for more colors, is it tintable or similar product? Looking to have a durable long lasting coating that stands up to Wyoming weather. Am I in the right track?
Caroline
Caroline
We used a solid stain on our deck about two years ago. I know it was Cabot brand but I’m not sure what the actual product was. I think it was the solid color acrylic deck stain in redwood. I have never liked the color and now it is mostly peeling off. We power-washed with a brush attachment and just water. Do we need to do any additional prep or can we just cover over the remaining Cabot stain? And which product would you recommend?
I purchased a house that has a deck that needs some love. Looks like the previous homeowner used a resurfacer as it has a gritty surface and the parts peeling off are really thick. I’m guessing I would need to strip and sand the deck before using the RAD? Also, I need to replace 8 boards that are rotting. Would those need to season before using the RAD on those?
I have a very large deck that was stained with Sikkens Mahogany many years ago. I would like very much to change the color to a much lighter one. One of the contractors I spoke with said he would simply power wash the deck with water, allow it to dry and then apply two coats of any stain – however, he warned that staining lighter might take a third coat. Is this the type of stain you would recommend to go lighter. Thanks so much for any advice.
Here are two photos. Thanks again for your time and advice.
349
