Flood CWF-UV5 Oil Wood Stain Review 2026 3.8/5 (28)
This post was updated on January 15, 2025
At DeckStainHelp.com, we’re proud to be the number one online resource for deck stain reviews and opinions. Your feedback and continued support are what make this possible—thank you!
Many of our customers who have used Flood CWF-UV5 Oil Wood Stain report mixed reviews regarding its appearance and longevity on their deck projects. While some appreciate its initial finish, others have noted concerns about its durability over time.
Have you used Flood CWF-UV5 Oil Wood Stain? We’d love to hear your thoughts! Feel free to leave a comment below and share pictures of your completed projects if you have them. Your experience helps us—and others—better understand how this product performs.
Flood CWF Oil Review
Sherwin Williams SuperDeck Solid Stain Ratings ReviewImportant Note:  This is our 2nd review for Flood CWF UV5. See our first review here: Flood CWF5 Oil Review
  • Premium oil finish ideal for newer, less weathered wood
  • Adds minimal color and highlights the natural wood grain
  • The penetrating formula protects against moisture damage
  • The mildew-resistant finish won’t crack, peel or flake
  • Clear Tint Base can be custom-matched to most wood tones while maintaining the wood’s natural look
  • Apply quickly with a pump or airless sprayer, or brush or roll on
  • Features Penetrol®, which penetrates and protects wood from the inside out, ensuring long-lasting performance
Flood CWF5 Oil Stain Ratings (1-10)
– The Flood CWF-UV5 had a nice rich color when applied to the ACQ Pine decking. Golden with a hint of orange color. Knots were a little lighter in color than the rest of the deck but, that is normal for a true oil-based stain. Grain was highlighted well.
– Color retention was decent. Flooring lost about 30% color, but railings retained much of the original color.
Wear/Tear and Peeling: 7
– No peeling, but there was wearing around the high traffic areas.
Cost Per Square Foot: 7
– We used 4 gallons total for the 2 coats on the 400 Sq. Feet. We paid about $30 a gallon on a sale from the local Glidden store.
Preventing Mold/Mildew/Algae: 7
– Our first review of the Flood CWF-UV5 had better results. We found mold growing in the coating after two years. Surprising to us since this deck was in full sun.
Ease of Application: 7
– We applied the first coat using a pump sprayer and applied the second coat with a staining pad made for decking. We applied using the “wet on wet” technique as their directions state. We back wiped any excess stain that did not penetrate within 15 minutes.
Color Shifting (darkening) after 2 Years: 7
– The Flood CWF-UV5 slightly darkened in color on the railings. The flooring faded in color.
The Difficulty of Reapplication: 6
– Light stripping or a good deck cleaning while pressure washing will be enough prep to reapply. No sanding would be required.
Overall Score Flood CWF Oil at 2 Year Period: 7.0
The Flood CWF-UV 5 Oil is a decent semi-transparent stain that performs better than many acrylic-based alternatives. Its oil-based formula allows it to penetrate well into the wood grain, offering good initial protection and a natural finish.
However, there are some areas where the product falls short:
  • Color Retention: The stain struggles to maintain its vibrancy over time, which can be disappointing for those looking for lasting color.
  • Mold Issues: Some users have reported concerns with mold development, which may require additional cleaning or maintenance.
While it’s a step up from many acrylic-based stains, these drawbacks make it worth weighing your options when choosing the best product for your project.
Where To Buy: Glidden Paint Store, Home Depot, Paint Stores, Online Stores
Cost: $43.99 per Gallon, $219.99 per 5 Gallon Pail
Stain Type: Semi-Transparent – Oil Based
Available Colors: 27 Colors
Application Temperature: 50-80 F
Coats  Required: 2 Coats.
Dry Time: 24-48 Hours
Manufacturer: Flood
Deck Wood Type:  Pressure Treated Pine
Deck Square Footage: 500 sq. feet
UV Exposure: Full Sun
Natural Cedartone
Flood Deck Stain Photos
46 Comments
Kevin udenberg
Kevin udenberg
I used flood stain on our brand dew deck and it didn’t last one full season, and started pealing off, now I am not sure what to do, taking it all off is going to be a monumental task, I was told this was a good product, it sure didn’t hold up for me!!
Verda Smith
Verda Smith
5 months ago
Can this product be used directly on a new pressure treated deck, new wood?
Michael
Michael
Should I apply Thompsons Water Seal after using Flood?
Richard Lilly
Richard Lilly
I will be using Flood FLD520 on my new deck. I am being told that I will need to apply a sealant after the stain. Is that a good idea and do you have a recommendation for a sealant to go with this stain?
Len Laframboise
Len Laframboise
I built a bunke using rough sawn pine 20 years ago and applied cwf (2 coats) 10 years later I recoated it. This year I again recoated it. The end result is unbelievable as it it does not look it’s age. I have no experience on using cwf on a deck so can’t comment on that. I live in north Ontario so this building gets pretty extreme weather.II couldn’t be happier with the results. Also I apply it with a brush. . I’ve been using Sikkens srd on my deck and it looks terrible wears out gets brown and ugly. Maybe I’ll try. cwf on it as well but not looking forward to all the sanding.
Lady Jane
Lady Jane
My deck is 32 years old. I’ve only used oil base CWF OIL (mine doesn’t say UV5) products as water based ones tend to be like paint and peel, basically becoming a problem for next application. Some decks have needed to be stripped. I apply it every 2-3 years which is a pain, but has kept the deck in good condition.
Hilton
Hilton
Why is the stain still tacky in areas after a week
JULIE ANN LIVESEY
JULIE ANN LIVESEY
Can I restain the deck without completely removing previous stain? Prevciously stained with FLood CWF-UV5 Oil. This product seems hard to find. Have the names changed? Can I use Flood CWS Oil without UV5 on a deck that does not get alot of sun?
JULIE ANN LIVESEY
JULIE ANN LIVESEY
What does the UV mean?
mike
mike
Can I tint the stain a black color?
Susan Shay Copple
Susan Shay Copple
We have previously used a different clear product that did not last and our deck looked old and worn. We even thought we might need to replace the deck it looked so bad. We power washed the deck, let it dry then used Flood Oil Natural. Oh My! What a beautiful deck we have! It was so easy. I used a pad put on the broomstick handle and applied. The grain in the wood stands out and the color of the wood is so pretty. We used the non oil Flood Natural on the stairs we have an outside dog we didn’t want the oil on the dog’s paws and it looks beautiful too. Highly recommend this product.
Joanne
Joanne
Can you put this over put this over Thompson’s deck stain?
Van truman
Van truman
Recommendations on flood water based stain and rating?
Tracey J Wilson
Tracey J Wilson
Can I put this over top of Behr Premium Advanced DeckOver that is 3 years old? The Behr has held up well, but it has faded to a milky color. I tried adding the Flood CWF-UV5 on one railing and it looks good. Our deck is on the South side and gets sun all day long, 365 days a year. Our concern, is chemical reaction between the two, and the fact that the deck gets so hot (can’t walk in bare feet on it), that we wonder if it might get soft so that twisting a shoe on it would cause the coating to loosen.
Tracey J Wilson
Tracey J Wilson
Sad to hear this, but thank you for responding!
Zack
Zack
Can I apply this over a 10-year old application of Flood CWF-UV Acrylic/Oil sealer?
John Vallesi
John Vallesi
I used CWF-UV5 for a new brown pressure treated deck. I bought 6 gallons of the product. I waited 9 months to apply the finish to ensure the deck boards were ready to accept the stain. Once applied I loved it! Especially when it was wet as the deck looked like it was cedar. After the 1st year though there were areas where the finished wore off.
I am going to give the product another try and hopefully this time I was have better success.
Used it up in Canada where not much lasts well with our freeze thaw cycles and baking sun. But it lasts well. Goes on well and looks good even after four years. The top portion is 4 yrs and the bottom and trim are fresh. No bad. Took about 3.5 cans to do about 80’ double sided.
Kevin Bandi
Kevin Bandi
I felt compelled to post a review about the superb quality of your product. I’ve been applying it on my back deck every 2 years for 20 years, it looks better now than the day it was built. Awesome stuff, thanks for your commitment to quality.
This flood product is absolute garbage. I put it o
Talk to customer support came up with every excuse called a few professional painters in my area of Connecticut they told me they would never even consider ever using it. Bought it from Lowe’s in Lowe’s discontinued it. Do yourself a favor get anything else other than this product
This flood product is absolute garbage. I put it on my kiln dried Western Cedar and it’s sun fades blotchy spots and water stains within four months stay away from it absolutely terrible product support offered to refund my money instantly when I told him I had a problem $20,000 worth of work later do not use it
Bill
Bill
You call Flood CWF-UV5 a semi-transparent stain. But the Flood website calls it a transparent stain. That website lists two semi-transparent stains: Flood Pro Series Semi-Transparent Stain Alkyd and Flood Pro Series Semi-Transparent Stain Acrylic. Both seem to be oil-based, and the oil/acrylic has a much longer guarantee period than CWF-UV5. I can’t find any mention of either one on your site. Could you clarify, please? Thanks.
B.M.
B.M.
Based on reviews found elsewhere and the information on your site, I am leaning towards flood uv-5 for an upcoming project. Hemlock board and batten siding, new construction so it hasn’t been finished before. The wood is going up around 30% moisture, and dries to around 20 within a week. Should be finished putting siding up by mid sept.
My question- do you think uv5 would be a good choice for this aplication. It seems readily available in my area (home Depot carries it), is a decent price, and your reviews seem pretty good. Anything else you’d suggest over it in this price range?
Deborah
Deborah
Thanks for the link, but to clarify, I am looking to seal and protect a new screenporch made of construction grade pine, NOT treated lumber…. is it still recommended to leave it unprotected for 2 months ?
Deborah Bedell
Deborah Bedell
Central Wisconsin. Heavy Snow.
Newly constructed Screen porch of untreated pine. What do I need to apply to protect? The floor of this porch has 5+ year old . CWF honey gold.
Some sections (also treated with honey gold)combined with previous deck probably just Thompsons water sealed….what would mske this uniform appearance?
david
david
hello, thanks for the info and advice. The site, its GREAT!
i did a search, but didnt see info on Flood CWF-UV FLD520, penetrating wood finish. 4/2 warranty, $~96 x5Gal at HD.
None of you top rated products were available local at the time, I got it thinking it was the same as in your review for UV5 Oil, this one is water clean up and cheaper.
I had similar results application wise as you with th UV5. Two coats to smooth out finish, some dripping, spray w/back roll. Only a year on deck but holding up well (full sun, NY winter) compared to previous (Olympic MAXIMUM oil AND water based) products.
thanks again for your reviews and tips!
Alex
Alex
Reply to  david
How is yours holding up 2 years in? Like you, I could only find the FLD520 at my local HD, at $96 for 5 Gallons, seems pretty good for a decently rated product. One difference I can see with this CWF-UV FLD520 is the fortification with Penetrol which is used to improve leveling for a smooth finish. Cheers
Joy
Joy
Have decks in two locations, one lakeside, the other on wooded rural acerage. Both full sun in Massachusetts.
Always used flood cwf-uv5 on both, pressure treated pine. Lake deck 30 yrs old. Reapplied every other year. Small amount of green algae sanded off railings, otherwise protects wood very well. Have never replaced any wood. Wooded location product worked fine, same pattetn, no algae except hidden behind one post.
Easy cleaning, easy application, no stripping. Light sanding on top of lakeside railings.
Sticking with a product that works.
William N. Benoit
William N. Benoit
Can I put CW-UV5 Oil over a fence that has been covered with CWF-UV for about 15 years ??
In south western Canada, On a set of stairs.. Medium traffic,fully open to sun , rain, needs redoing every year. Disappointing.looking for a better product.
X
46
