DEFY Composite Deck Cleaner – Powerful, Oxygen Bleach-Based Cleaning for Composite & Vinyl Surfaces
Safely Removes Algae, Dirt, & Grime Without Damaging Composite Wood
DEFY Composite Deck Cleaner is a biodegradable, oxygen bleach-powered cleaner designed to effectively remove black stains, dirt, mildew, and weathered graying from composite and vinyl deck surfaces. Unlike chlorine bleach-based cleaners, which can damage wood fibers and surrounding vegetation, DEFY Composite Deck Cleaner is eco-friendly and safe for pets, grass, and most plants.
This powdered concentrate easily mixes with water, creating a powerful foaming action that penetrates deep into composite wood pores for a thorough cleaning.
🔹 Why Choose DEFY Composite Deck Cleaner?
✅ Safe Oxygen Bleach Formula – Lifts and removes black algae stains, dirt, and grime without harming composite materials.
✅ Biodegradable & Environmentally Friendly – Won’t damage plants, grass, pets, or surrounding areas.
✅ Foaming Action for Deep Cleaning – Works better than bleach-based cleaners, actually lifting stains instead of just bleaching them.
✅ Prepares Composite Decks for Sealing – Restores surfaces to like-new condition before applying DEFY Composite Deck Sealer.
✅ Works on Multiple Surfaces – Suitable for composite decks, vinyl siding, and aluminum siding.
🔹 Where to Use DEFY Composite Deck Cleaner?
✔ Composite & Vinyl Decks
✔ Porches & Patios
✔ Vinyl & Aluminum Siding
✔ Pool Decks & Docks
Compatible with leading composite decking brands including:
🔹 Trex, TimberTech, Azek, Fiberon, Evergrain, Duradeck, ChoiceDek, CorrectDeck, and more.
🔹 Coverage & Mixing Instructions
✔ Mixing Ratio: ¾ cup per gallon of warm water
✔ One Gallon of Solution Covers 100-200 sq. ft.
✔ One 2 lb. Container Makes 6 Gallons of Solution (Cleans 600-1,200 sq. ft. total)
🔹 How to Use DEFY Composite Deck Cleaner
1️⃣ Mix the Solution – Dissolve ¾ cup of cleaner per gallon of warm water.
2️⃣ Apply to Surface – Use a mop, deck brush, or pump-up sprayer (filter through cheesecloth if using a sprayer).
3️⃣ Let Sit for 15-20 Minutes – Watch as it foams and lifts stains.
4️⃣ Scrub or Pressure Wash – Use a stiff-bristle brush or a low-pressure power washer to remove grime.
5️⃣ Rinse Thoroughly – Ensure all cleaner residue is washed away before sealing.
📌 Pro Tip: Use DEFY Composite Deck Waterproofing Sealer after cleaning for long-lasting protection!
✔ Restore & Protect Your Composite Deck with DEFY Composite Deck Cleaner!
✔ Removes tough stains, dirt, and mildew without damaging composite surfaces!
✔ Eco-friendly, biodegradable, and safe for pets & plants!
✔ Prepares decks for sealing & extends their lifespan!
🔹 Order DEFY Composite Deck Cleaner today and bring your composite deck back to life!
