CUTEKĀ® Wood Reviver (formerly CUTEKĀ® Proclean) is a high-performance wood cleaner designed to restore weathered, grayed, and stained wood back to its natural appearance.
- CUTEKĀ® Wood Reviver removes tough stains from iron, tannins, mold, fungus, and resins, while also eliminating mill glaze on new wood.
- The product will not remove paint or existing coatings. Use CUTEKĀ® Wood Stripper for those applications instead.
- Coverage is approximately 1 gallon per 200 to 350 sq. ft., with dwell time ranging from 1 to 24 hours based on staining severity.
- Rinsing requires a pressure washer at approximately 750 PSI with a fan tip. A garden hose is not sufficient for proper removal.
It effectively removes tough stains caused by tannins, water, iron, resins, mold, and fungus. It also eliminates mill glazeāthe invisible barrier on new woodāensuring proper preparation for coating.
CUTEKĀ® Wood Reviver cleans, brightens, and revitalizes wood, leaving it looking like new and ready for application of CUTEKĀ® Extreme.
FEATURES OF CUTEKĀ® WOOD REVIVER
Powerfully Restores Wood
Removes Stubborn Stains
Prepares New Wood for Coating
Removes mill glazeāthe invisible barrier on newly sawn or machined woodāto ensure proper stain penetration.
Typical Uses
Important Note
CUTEKĀ® Wood Reviver will not remove paint or existing wood coatings. For those applications, use CUTEKĀ® Wood Stripper.
STEP 1: PREPARE
Before starting, determine if CUTEKĀ® Wood Reviver is suitable for your specific project. Always test on a small, inconspicuous area first. Wood species and condition can vary greatly, and testing will help you determine the proper dilution, dwell time, and product amount needed.
Safety & Precautions
How to Apply
CUTEKĀ® Wood Reviver is a powerful wood cleaner and can be used diluted or undiluted depending on the condition of the wood.
Coverage
- Approximately 1 gallon per 200ā350 sq. ft.
- Wood density and smoothness
Application Steps
- Pre-wet the wood surface
- Apply generously using:
- Brush
- Roller
- Broom
- Low-pressure garden sprayer
Removal (Very Important)
- Do NOT use a garden hoseāit is not sufficient
Best practice:
After Cleaning
- Light sanding or
Clean-Up
