Removing old stain, sealer, or varnish is the first step to getting a new finish to look right and last. If the old coating stays on the wood, the new stain can’t absorb evenly, leading to blotchy color, poor adhesion, and premature failure.
Buy DEFY Exterior Wood Stripper when you need a professional-grade, biodegradable remover that lifts old finishes and built-up grime so you can get back to clean, stain-ready wood. Use it on decks, fences, siding, log homes, and outdoor wood surfaces, then follow with a wood brightener to reset the surface and help your next stain coat perform better.
DEFY Exterior Deck Stain & Sealer Remover – Powerful, Biodegradable Wood Stripper
Easily Remove Old Stains, Varnishes & Sealers to Restore Natural Wood Beauty
DEFY Exterior Wood Stripper is a professional-grade, biodegradable deck stain remover designed to quickly and effectively strip away old stains, sealers, and varnishes, restoring wood to its natural, clean state. This easy-to-use solution removes built-up dirt, mold, mildew, and mill glaze, making it the ideal first step before applying a new stain.
🔹 Why Choose DEFY Exterior Deck Stain & Sealer Remover?
✅ Strips Old & Worn Finishes – Removes solid & semi-transparent stains, clear film-forming varnishes, and polyurethane coatings.
✅ Biodegradable & Eco-Friendly – Safe for plants, pets, and landscaping when used as directed.
✅ Restores Natural Wood Beauty – Prepares aged, weathered, and stained wood for refinishing.
✅ Water-Based & Easy Cleanup – Rinses off easily with water after application.
✅ Enhances Stain Performance – Follow with DEFY Wood Brightener for better stain penetration and long-lasting protection.
🔹 What Will DEFY Wood Stripper Remove?
✔ Semi-Transparent & Solid Color Stains
✔ Clear Film-Forming Varnishes & Polyurethane Coatings
✔ Weathered Oil-Based & Latex-Based Stains
✔ Mold, Mildew, Dirt & Old Finishes
📌 Note: If unsure whether your wood needs stripping or just cleaning, test a small, inconspicuous area first.
🔹 How to Remove Wood Stain with DEFY Exterior Wood Stripper
1️⃣ Test a Small Area First – Determine if stripping or just cleaning is necessary.
2️⃣ Apply Generously – Use a polyester brush, roller, or pump sprayer to coat the surface.
3️⃣ Allow to Sit for 15 Minutes – The solution will begin to lift and loosen the finish.
4️⃣ Scrub the Wood (If Needed) – Use a stiff bristle brush to remove the stain in the direction of the wood grain.
5️⃣ Rinse Thoroughly – Use a garden hose or pressure washer (take care not to damage the wood).
6️⃣ Neutralize with DEFY Wood Brightener – This step is essential to restore pH balance and improve stain absorption.
7️⃣ Repeat as Needed – For stubborn areas, reapply and repeat the process.
🔹 Coverage & Product Details
✔ Covers 100-150 sq. ft. per gallon
✔ Sold in 1-gallon containers
✔ Works on decks, fences, log homes, wood siding, and outdoor furniture
✔ Safe for most wood species, including cedar, pine, redwood, and hardwoods
📌 Important: Always neutralize the surface with DEFY Wood Brightener after stripping for the best stain results.
✔ Get Your Deck Ready for a New Stain with DEFY Wood Stripper!
✔ Easily strip away old stains, varnishes, and sealers
✔ Biodegradable and safe for surrounding plants & landscaping
✔ Prepares wood for a long-lasting stain finish
🔹 Order DEFY Exterior Deck Stain & Sealer Remover today and restore your wood’s natural beauty with ease!
Expert Help When You Need It
FAQs About DEFY Exterior Wood Stripper
How do I know if I should buy DEFY Exterior Wood Stripper?
DEFY Exterior Wood Stripper is a good choice if your deck or exterior wood has old stain, sealer, or buildup that needs to be removed before re-staining. It is especially useful when finishes are failing, peeling, or preventing new stain from absorbing evenly.
Can I use DEFY Wood Stripper on my type of wood?
Yes. DEFY Exterior Wood Stripper is designed for common exterior woods, including pressure-treated pine, cedar, redwood, and many hardwoods. Always test a small, inconspicuous area first, especially on older wood or surfaces with unknown coatings.
What surfaces can I use DEFY Wood Stripper on?
This product can be used on decks, fences, railings, siding, log homes, outdoor furniture, and other exterior wood surfaces. It is effective on both horizontal and vertical areas when applied generously and allowed proper dwell time.
Is DEFY Wood Stripper enough on its own, or do I need additional products?
DEFY Wood Stripper removes old finishes, but for the best results, the surface should always be neutralized afterward with a wood brightener. This restores proper pH balance and helps ensure better stain penetration and longer-lasting results.
Why is proper stain removal important before re-staining?
If an old stain or sealer is left on the wood, the new stain cannot penetrate properly. This leads to uneven color, poor adhesion, and early stain failure. Using a quality stripper like DEFY helps create a clean, stain-ready surface so your next finish performs as intended.
Ready to prep your wood the right way?
Buy DEFY Exterior Wood Stripper today to remove old finishes, restore natural wood appearance, and prepare your deck or exterior wood for a long-lasting stain.
Defy Extreme Clear Wood Coating 5 Gallon
RAD Paint & Solid Stain Stripper 5 Gallon
DEFY Composite Deck Cleaner
