Gemini Restore-A-Deck Kit – The Easy Way to Bring Your Exterior Wood Back to Life
The Gemini Restore-A-Deck Cleaner and Brightener Kit is a powerful, two-step system designed to restore and prepare your exterior wood for staining. Whether you’re dealing with years of neglect or just prepping for a recoat, this eco-friendly solution makes the process simple and effective.
Step 1: Gemini Restore-A-Deck Wood Cleaner
This concentrated powdered formula deeply cleans your wood by removing:
- Grime and dirt buildup
- Mold and mildew
- Algae and green growth
- UV-induced graying
Ideal for prepping neglected wood or stripping away contaminants before applying a new deck stain.
Step 2: Gemini Restore-A-Deck Wood Brightener
After cleaning, the brightener is applied to:
- Neutralize the pH of the wood
- Open the wood pores for optimal stain penetration
- Brighten and enhance the natural wood tone
This step is essential for improving the appearance of aged wood and ensuring longer-lasting stain performance.
Why Choose the Gemini Restore-A-Deck Kit?
- 100% Biodegradable and Eco-Friendly
- Concentrated Powder Formula – Cleans and restores up to 1,000 sq. ft.
- Preps Wood for Staining – Ideal for all wood types including cedar, redwood, and pressure-treated pine
- Restores Grayed Wood – Brings your deck or exterior wood back to its natural color
Ready to restore and stain? The Gemini Restore-A-Deck Kit is your first step toward a beautiful, refreshed deck.
Frequently Asked Questions – Gemini Restore-A-Deck Cleaner & Brightener Kit
Do I need to use both the cleaner and brightener?
Yes. The two-step system is designed to work together. The cleaner removes dirt, mold, and gray wood fibers, while the brightener neutralizes the cleaner’s high pH and enhances wood appearance. Skipping the brightener can lead to poor stain performance and uneven results.
How much does one kit cover?
Each Gemini Restore-A-Deck Kit contains concentrated powder that treats up to 1,000 square feet of wood surface. Coverage may vary depending on wood condition and porosity.
Can I use this kit on wood that’s already been stained?
Yes, if you’re prepping for a recoat and the previous stain is lightly worn or faded. However, if the old stain is peeling or heavily built up, you’ll need a stain stripper instead of the cleaner to remove it fully.
How long should I wait to stain after using the kit?
Allow the wood to dry for 24–48 hours after rinsing off the brightener, depending on temperature and humidity. The wood should feel dry to the touch before applying stain.
Is the Restore-A-Deck Kit safe for plants and grass?
Yes. Both the cleaner and brightener are biodegradable and eco-friendly. We still recommend rinsing nearby vegetation with water before and after use as a precaution.
What tools do I need to apply the cleaner and brightener?
Use a pump sprayer or watering can to apply each solution. A scrub brush or pressure washer (on low pressure) can help agitate the surface during cleaning.
Can I use this on vertical wood surfaces like fences or siding?
Absolutely. The kit is effective on all exterior wood, including decks, fences, pergolas, wood siding, and outdoor furniture.
CUTEK® Wood Reviver & Brightener
