R-A-D™ Guard Mildew & Algae Cleaner & Preventer – Ready-To-Use Formula
No-Rinse, Long-Lasting Protection Against Mold, Mildew & Algae
R-A-D™ Guard RTU (Ready-To-Use) is an eco-safe, no-rinse cleaner and mildew/algae preventative designed to remove and prevent mold, mildew, and algae stains on exterior surfaces. Unlike traditional cleaners, R-A-D™ Guard works over time, eliminating stains without pressure washing, scrubbing, or rinsing. This powerful bleach-free, acid-free formula is safe for existing paints, stains, and sealers, making it the perfect maintenance solution for wood decks, siding, patios, roofs, and more.
📌 Note: R-A-D™ Guard is not intended for prepping wood before staining. It is designed to clean and prevent mildew/algae stains from forming after staining or on existing surfaces.
🔹 Why Choose R-A-D™ Guard?
✅ No-Rinse, No-Scrub Formula – Works without pressure washing or scrubbing.
✅ Prevents & Removes Mold, Mildew, and Algae Stains – Keeps wood and exterior surfaces clean for up to 2 years.
✅ Eco-Safe & Pet-Friendly – Contains no bleach, chlorine, acids, or phosphates.
✅ Can Be Applied Over Existing Paints, Stains & Sealers – Won’t damage surfaces while cleaning.
✅ Works on Multiple Exterior Surfaces – Use on wood, composite decking, paver patios, concrete, stucco, siding, asphalt roofs, and more.
🔹 Where to Use R-A-D™ Guard?
✔ Exterior Wood & Composite Decks
✔ Brick & Paver Patios
✔ Asphalt & Tile Roofs
✔ Fences, Outdoor Furniture, & More
🔹 How R-A-D™ Guard Works (Application Instructions)
📌 Patience is Key! R-A-D™ Guard takes 1-3 weeks to fully remove stains, depending on rainfall and severity of mold/algae buildup.
1️⃣ Pre-Wet Surrounding Landscaping – Protect plants by spraying them with water before applying.
2️⃣ Pour R-A-D™ Guard into a Pump Sprayer – Use as-is (ready-to-use formula).
3️⃣ Apply to Dry Surfaces – Fully saturate the targeted area (avoid puddling).
4️⃣ Let Mother Nature Work! – Do not rinse; rainfall and natural moisture will activate cleaning over time.
5️⃣ Deep Cleaning Continues – R-A-D™ Guard penetrates deep into the surface to remove mildew/algae stains.
6️⃣ Reapply as Needed – Repeat every 12-24 months or when new stains appear.
📌 Important: All paints and stains must be fully dried and cured before applying R-A-D™ Guard.
🔹 Coverage & Maintenance
✔ Coverage: 200 sq. ft. per gallon
✔ Maintenance: Reapply every 12-24 months for ongoing mildew & algae prevention
📌 Pro Tip: Use R-A-D™ Guard immediately after staining to extend the life of your stain and prevent mildew buildup.
✔ Keep Your Deck & Outdoor Surfaces Clean for Years with R-A-D™ Guard!
✔ Safe for use over existing stains, sealers, and paints!
🔹 Order R-A-D™ Guard Mildew & Algae Cleaner & Preventer today for effortless exterior maintenance!
