Restore-A-Deck Cleaner & Brightener Kit – Large-Scale Wood Restoration
Cleans, Brightens & Prepares Up to 2,400 Sq. Ft. of Wood for Staining
Our most economical and largest deck restoration kit provides enough Restore-A-Deck Cleaner & Brightener to fully clean and brighten large multi-level decks with railings, steps, and decorative features like trellises, benches, and planter boxes (1,800-2,400 sq. ft.). This kit is also ideal for large fence projects, capable of cleaning and brightening both sides of a 160-foot fence.
✔ Includes:
🛠️ (3) RAD Step 1 Wood Cleaners – Removes dirt, mildew, and grayed wood
🛠️ (3) RAD Step 2 Wood Brighteners – Neutralizes cleaner and restores natural wood color
🌱 Eco-Friendly Formula – Safe for wood, pets, grass, and plants when properly rinsed
💰 Most Cost-Effective Large Kit – Maximizes coverage at the lowest price per gallon
🏆 #1 Rated Deck Cleaning & Brightening Kit – Trusted by contractors & homeowners
✅ Cleans & Brightens Up to 2,400 Sq. Ft. – Perfect for multi-level decks, large fences, & outdoor structures.
✅ Removes Dirt, Mold, Mildew & UV Graying – Restores wood to its original, natural appearance.
✅ Prepares Wood for Staining – Neutralizes the wood for better stain adhesion & longer-lasting results.
✅ Affordable & Easy to Use – Most economical package for large surface coverage.
✔ Multi-Level & Large Wood & Composite Decks
✔ Fences (Cleans Both Sides of 160 Feet)
✔ Railings, Trellises, Pergolas, & Outdoor Stairs
📌 Perfect for prepping wood before staining for long-lasting protection.
✔ Get Professional-Level Cleaning & Brightening for Large Decks & Fences!
✔ Prepares large surfaces for staining at the most economical price!
🔹 Order the Restore-A-Deck Cleaner & Brightener Kit today and restore your deck, fence, or outdoor wood structures with ease!
Defy Marine Seal Wood Cleaner 2 Pounds
