TWP 100 Pro-Series Stain & Gemini Restore-A-Deck Kit Combo – Prep & Stain in One!
Complete Wood Restoration System for Long-Lasting Protection
The TWP 100 Pro-Series Stain & Gemini Restore-A-Deck Kit Combo provides everything you need to prepare, restore, and stain your wood deck, fence, or exterior surfaces in one convenient package. With this system, you can deep clean, brighten, and protect your wood, ensuring maximum durability and beauty.
✔ (1) TWP 100 Series 5-Gallon Pail – Premium Oil-Based Stain & Sealer
✔ (1) Gemini Restore-A-Deck Cleaner & Brightener Kit – Eco-Friendly Wood Prep System
🏆 #1 Rated Penetrating Wood Stain & Prep System – Trusted by homeowners & professionals for over 25 years
🌞 Prevents UV Damage, Water Absorption & Graying – Long-lasting protection for your outdoor wood
🔹 Why Choose the TWP 100 Pro-Series Stain & Gemini Restore-A-Deck Kit?
✅ Deep Cleans & Prepares Wood for Staining – Removes dirt, mold, algae, and graying
✅ Brightens & Restores Natural Wood Color – Neutralizes cleaner for even stain absorption
✅ Penetrating Oil-Based Formula – Enhances wood grain while sealing against moisture
✅ Protects Against UV Rays & Water Damage – Prevents fading, warping, & cracking
✅ Ideal for All Exterior Wood Surfaces – Works on decks, fences, log homes, siding, outdoor furniture, and more
✅ Easy to Apply & Maintain – Professional results at a cost-effective price
📌 Note: TWP 100 Series is not compliant in all states. Check VOC restrictions before purchasing.
🔹 What’s Included in the TWP 100 Stain & Prep Kit?
(5 Gallons) TWP 100 Pro-Series Stain – Deep Penetrating Protection
✔ Premium oil-based stain & sealer for long-lasting results
✔ Preserves wood’s natural beauty while preventing graying
✔ Sheds water & resists mildew and mold growth
✔ Prevents cracking, splitting, and freeze damage in colder climates
✔ Enhances wood tones & protects against UV exposure
📏 Coverage: 150-250 sq. ft. per gallon (varies by wood porosity).
Available in 8 Beautiful Wood-Tone Colors:
🎨 101 Natural – Clear with minimal tint for a natural look
🎨 102 Redwood – Rich, warm redwood finish
🎨 103 Dark Oak – Deep, classic wood stain
🎨 105 Cape Cod Gray – Near semi-solid gray appearance
🎨 106 Prairie Gray – Light gray with a subtle wood tone
🎨 115 Honeytone – Light golden-brown hue
🎨 116 Rustic – Medium brown with warm undertones
🎨 120 Pecan – Rich brown with a slight red tint
📌 TWP 105 Cape Cod Gray & 106 Prairie Gray have a near semi-solid finish.
Step 1: Gemini Restore-A-Deck Wood Cleaner
✔ Removes dirt, grime, mold, mildew, and gray weathering
✔ Prepares wood for better stain absorption
✔ Eco-safe & biodegradable – safe for plants, pets, and grass
📏 Coverage: 750-1,000 sq. ft. per container.
Step 2: Gemini Restore-A-Deck Wood Brightener
✔ Neutralizes the cleaner & restores wood’s natural color
✔ Removes rust stains & tannin stains from fallen leaves
✔ Improves stain adhesion & extends stain longevity
✔ Eco-friendly & easy to apply
🔹 Where to Use the TWP 100 Pro-Series Stain & Gemini Restore-A-Deck Kit?
✔ Wood Decks & Railings
✔ Fences & Pergolas
✔ Siding & Log Homes
✔ Outdoor Furniture & Playsets
📌 Perfect for any exterior wood that needs deep penetration, UV protection, and long-lasting water resistance.
🔹 How to Use the TWP 100 Stain & Prep Combo Kit
Step 1: Clean Your Wood with Restore-A-Deck Cleaner
1️⃣ Mix the Cleaner: Each container makes 5 gallons.
2️⃣ Apply Using a Pump Sprayer or Brush: Fully saturate the wood surface.
3️⃣ Let Sit for 10-15 Minutes: The cleaner foams and lifts dirt & grayed wood fibers.
4️⃣ Scrub or Pressure Wash Off: Rinse thoroughly with a garden hose or pressure washer.
Step 2: Brighten the Wood with Restore-A-Deck Brightener
5️⃣ Mix the Brightener: Each container makes 5 gallons.
6️⃣ Apply Using a Pump Sprayer or Brush: Fully saturate the surface.
7️⃣ Let Sit for 10-15 Minutes: Neutralizes the cleaner and restores wood pH balance.
Step 3: Apply TWP 100 Pro-Series Stain
9️⃣ Ensure Surface is Ready: Wood must be completely dry before staining (24-48 hours after cleaning).
🔟 Apply Stain Using Brush, Roller, or Pump Sprayer: Work wet-on-wet for even absorption.
1️⃣1️⃣ Back-Brush or Use a Stain Pad: Ensures even penetration & smooth finish.
1️⃣2️⃣ Let Dry Completely: Allow 24-48 hours before heavy foot traffic.
📌 For best results, apply TWP stain when temperatures are between 50°F-90°F.
✔ Get Professional-Quality Results with the TWP 100 Stain & Prep Kit!
✔ Deep clean, brighten, & stain your wood for maximum protection!
✔ Penetrates deep into wood fibers to prevent graying & water damage!
✔ Eco-friendly, easy to use, and works on multiple wood surfaces!
🔹 Order the TWP 100 Pro-Series Stain & Gemini Restore-A-Deck Kit today and keep your deck or exterior wood looking beautiful for years!
Technical Specifications – TWP 100 Wood Stain
Coverage: 150–250 sq. ft. per gallon, per coat.
Recommended Coats: 2 Coats (Wet-on-Wet Application)
Dry Time: 4 to 24 Hours
TWP Natural Effect Top Coat 5 Gallon - Step 2
This combo really delivered! The Gemini Cleaner/Brightener Kit made prepping easy — the cleaner removed dirt and gray wood effortlessly, and the brightener brought back the wood’s natural color and balanced the pH perfectly.
Staining with the TWP 100 Series (I used Cedartone) was smooth and easy. It soaked in nicely, brought out the wood’s beauty, and didn’t leave any streaks. I love that it repels water, blocks UV rays, and won’t peel.
Overall — this kit made my deck look amazing and should keep it protected for years. Highly recommend for an easy, professional-looking project!
