Wooster Wide Boy Bucket – High-Capacity Stain & Sealer Bucket with Lid
Holds Up to 4 Gallons – Perfect for Large Staining Projects
The Wooster Wide Boy Bucket is a high-capacity, professional-grade bucket designed for effortless application of oil-based stains, sealers, and wood toners. With a 4-gallon capacity, this bucket is perfect for large projects such as deck staining, fence sealing, and wood restoration.
🔹 Why Choose the Wooster Wide Boy Bucket?
✅ High-Capacity Design – Holds up to 4 gallons, reducing the need for frequent refills.
✅ Ideal for Oil-Based Stains & Sealers – Designed to work seamlessly with brushes, rollers, and stain pads.
✅ Includes Lid for Easy Storage – Prevents spills, evaporation, and contamination between uses.
✅ Durable & Lightweight – Built to withstand heavy use while remaining easy to handle.
✅ Perfect for Large Staining Projects – Works great for decks, fences, siding, and outdoor wood surfaces.
🔹 Best Uses for the Wooster Wide Boy Bucket
✔ Deck Staining & Sealing
✔ Fence & Railing Staining
✔ Wood Siding & Log Homes
✔ Large Outdoor Wood Projects
Padco Pro Stain Pad 10inch Refill
