Hi, I’m Scott Paul. Since 1993, I’ve been specializing in prepping and stripping exterior wood decks. Over the years, I’ve tested just about every product on the market and have compiled a comprehensive list of the top wood and deck stain strippers.
My reviews and tips are based on decades of experience as a wood and deck restoration contractor. Each recommendation comes from hands-on testing, ensuring you get the best product options for your needs.
Looking for expert advice? Learn more about me here and discover how my experience can help make your project a success.
The Best Deck Stain Strippers 2026
With over 30+ years of restoring decks as a contractor, I have done extensive research to find the best deck strippers and compared the positives and negatives of each brand and product. However, if you’re still not sure which deck stripper is best for you, I can help. Just post a comment or question below, and I’ll reply as soon as possible.
Without further ado, here’s a look at my four best deck stain strippers of 2026:
- Restore-A-Deck Deck Stripper with Booster/Thickening Gel Additives: My top-rated deck stain stripper features a special blend of pre-mixed solvents with 5 gallons of the original Restore-A-Deck Stripper. It provides an effective solution for even the most stubborn deck stains.
- Restore-A-Deck Wood Stain Stripper: The Restore-A-Deck powder is consistently considered one of the best deck stain removers and easily removes old stain or varnish, along with dirt, mildew, mold, and mill glazes.
- R-A-D PaintStrip Stripping Gel: Stripping deck paint instead of stain? Eco-friendly R-A-D™ PaintStrip works fast and removes up to 5 layers of deck paint in 45 minutes or less.
- Defy Exterior Wood and Deck Stripper: Defy Stripper’s biodegradable formula restores wooden decks to a like-new appearance while removing transparent and semi-transparent deck stains.
Read on to learn more about the best deck strippers available and tips on choosing a deck stain stripper and how to use it effectively.
Scott’s Steps to Stripping a Deck Stain
The best deck stain stripper for your project can vary depending on the type of stain or paint you need to remove. Here are a few things to consider and steps to take when buying deck stain removers.
1. Gather Your Deck Stripping Equipment and Materials
- Water! You need a water source for pressure washing and rinsing
- Pump Sprayer for applying your deck stripper
- Deck scrub brush to help agitate the stripper
- Pressure Washer – Not 100% needed, but it will help remove coatings
- Gloves, goggles, and masks
- Tarps to cover plants and your home
- A Premium Deck Stripper!
- A Wood Brightener to neutralize when done
2. What to Look for in a Deck Stain Remover
Before you select a deck stain stripper, consider the following to ensure you select the right product for your job:
- What are the application requirements? Some deck stain strippers require special equipment to be applied to or cleaned off your deck. Make sure you’re aware of the requirements before making a purchase.
- What type of stain do you need to remove? Certain deck stain strippers work best with different types of stains. Make sure you know whether your deck is covered in a solid, transparent, or semi-transparent stain, then find a compatible stain remover to ensure a job well done.
- Is the deck stain stripper biodegradable? Finally, make sure your deck stain remover is biodegradable. This will ensure a safer stripping process and keep harmful residue from entering your yard or nearby waterways.
3. Why Use a Deck Stain Stripper?
Whether your current deck stain has seen too much wear and tear or you’re just ready for a refresh, a deck stain stripper can make it easier to remove old stain by softening the old coating down to the bare wood. The best deck strippers will help remove built-up dirt, mold, mildew, and grime from the wooden boards. Once removed down to the bare wood, you can use any deck stain type you choose. Using a deck stain stripper will make pressure washing easier and with less potential damage to the wood.
4. How I Use a Deck Stain Stripper
I will guide you to deck stain and paint removal and provide a walkthrough of the process. However, the basic steps are as follows:
- Remove all furniture from the decking and place it 20-30 feet away.
- Cover plants, landscaping, furniture, windows, and anything else that isn’t getting stripped.
- Make sure you’re wearing proper gloves and eyewear.
- Use a brush or sprayer to apply an even layer of stain remover to the wooden deck.
- Let the deck stain stripper sit for at least 10-15 minutes for thicker coats of deck stain.
- Use a pressure washer or garden hose to remove the coatings and stain remover.
- If needed, repeat the process, then rinse thoroughly.
- Apply Wood Brightener to neutralize.
Scott’s Pro Tips for Stripping a Deck
To get the best results using a wood stain stripper, let the product sit for several minutes after applying it to the wood. This allows the stain stripper to penetrate and break down the old stain. The dwell time depends on the type of existing stain. For instance, most semi-transparent oil-based stains will be removed more easily than semi-solid deck stain.
For hard-to-remove stains such as acrylic or silicone-based stains, several applications and longer dwell times may be necessary. In extreme cases, such as when dealing with a solid deck stain or paint, some sanding may be needed to remove the existing stain fully.
Once the failing deck stain seems to have softened, it is best removed with a power washer using light to moderate pressure. The caustic stripper raises the wood’s pH level during the stripping process, causing it to appear very dark. This darkening is why a Wood Brightener is needed to restore the pH balance and lighten the wood.
5. What is the Best Deck Stripper?
This is a very popular question that I get here at Deck Stain Help, and it varies based on the condition of your deck and the type of stain you are trying to remove from it. Not all stain strippers will work for all deck stain types. For Example, a regular deck stain stripper will not remove a solid-color stain or paint entirely. To remove a solid-color stain or paint, you will need a Paint Stripper and possibly some power sanding.
My Top-Rated Wood Deck Stain Strippers
#1 Restore-A-Deck Deck Stripper with Booster/Thickening Gel Additives
- My go-to stain stripper for difficult-to-remove stains such as Behr and Olympic water-based wood stains.
Restore-A-Deck Stain Stripper Booster Additive is a special blend of solvents added to 5 pre-mixed gallons of the original Restore-A-Deck Stain Stripper. The Restore-A-Deck Stripper Booster will raise the effectiveness of the stain stripper up to 300% by helping break down the surface tension of difficult-to-remove wood stain finishes.
Restore-A-Deck Stain Stripper Thickening Gel is a special blend that is added to premixed 5-gallons of the Restore-A-Deck Stain Stripper. With a longer dwell time, Restore-A-Deck Stripper Thickening Gel will increase the effectiveness of stain stripping by adding the ability to cling to vertical and horizontal surfaces for up to 1 hour. It works especially well in improving the stripping performance on vertical wood, such as wood railings, wood fences, and wood-sided homes.
Manufacturer: Restore-A-Deck
Product Type: Deck Stain Stripper Additives to boost overall effectiveness.
Available Sizes: 16oz. Add these into 5 Liquid Gallons of RAD Stain Stripper.
Consumer Star Ratings:
My DeckStainHelp.com Review (On a Scale of 1-10): 9.8
See My Review Article Here: Restore-A-Deck Booster & Gel Additives Review
#2 Restore-A-Deck Stripper Rating
Note: This rating is without the Booster and Thickening Gel Additives
- My everyday wood deck stain stripper. We used this on 100s of decks annually.
Restore-A-Deck Wood Stain Stripper is a biodegradable, powdered concentrate that quickly removes worn finishes to restore wood surfaces. It removes transparent, semi-transparent, and most semi-solid stains with collected dirt, mold, mildew, and mill glaze.
My DeckStainHelp.com Review (On a Scale of 1-10): 9.4
See My Review Article Here: Restore-A-Deck Stripper Review
#3 RAD PaintStrip Stripping Gel Rating
Note: This product is designed to remove solid color deck stains and paints. While it will remove all other stain types, it is not always needed.
- This is what I use to remove solid-color deck stains.
R-A-D™ PaintStrip is the right choice for almost any paint or sealer stripping project. R-A-D™ PaintStrip is eco-friendly, works fast (starts working within 5 minutes), and removes up to 5 layers of most paints in 30-45 minutes and up to 15 layers in 24 hours.
Product Type: Solid Color Deck Stain and Paint Stripping Gel
Available Sizes: 1 & 5-Gallons
DeckStainHelp.com Review (On a Scale of 1-10): 9.2
See My Review Article Here: RAD PaintStrip Review
#4 Defy Wood Stain Stripper Rating
Defy Exterior Wood and Deck Stripper is designed to remove transparent and semi-transparent exterior wood and decking stains. It is a biodegradable deck stain remover that restores the wood to a like-new appearance and will work on both water-based and oil-based stains.
Where To Buy: Select Stores and Purchase Here
Product Type: Liquid Wood Deck Stain Stripper
Available Sizes: 1 Gallon Pre-Mixed Liquid (Not Concentrate)
DeckStainHelp.com Review (On a Scale of 1-10): 8.25
See My Review Article Here: Defy Stain Stripper Review
6. Common Questions About Wood Deck Stain Strippers
Do You Have to Strip a Deck?
Before staining a wood deck, it is necessary to prep the wood properly for the best results. Removing all the dirt, mold, mildew, and graying will help the new deck stain penetrate better and last longer.
A simple wood cleaning is insufficient when dealing with an old, failing deck stain. In this case, a deck stain stripper must be used to emulsify and soften the old stain so it can be removed more easily. Wood stain strippers are more aggressive than a typical wood cleaner.
What are the Active Ingredients in a Deck Stain Stripper?
Some of the best deck stain strippers I have found contain a mixture of Sodium Hydroxide and other surfactants. They typically come in pre-mixed liquid formulas or a concentrated powder formula for cost savings. Once mixed with water, they can be applied using a pump sprayer.
Do I Have to Brighten After Using Deck Stain Strippers?
Following the stripping process with an application of a wood deck brightener will restore the pH and brighten the wood while neutralizing the deck stripper. This brightening process should not be skipped. It is crucial to get optimal results from the new deck stain and a more natural appearance.
Using a quality wood deck stain stripper will give you the best chance of removing the existing deck stain. Once the old stain is gone, the new deck stain can fully penetrate the wood for maximum protection and lasting results.
i have a customer with a deck that is in fairly good condition. The previous person applied Thompson Waterseal Penetrating Timber Oil Cedar transparent stain. It is flaking off in places and is bonded well in others. I do not plan to use this product again, so i want to remove it. Will Restore A Deck stripper remove the Thompsons? Please advise
It should but use both RAD Stripper additives as well.
Deck is about 12 years old. Have used Sherwin Williams stain products all this time. I think Original stain was oil base because the water based stain never lasted. Nephew power washed deck and now a big mess! Should I try a stripper and then try sanding???
Post some pics fr prep help.
Hi I have decking that needs the old ronseal stain removed as it’s started to peel. Could you recommend the best stripper and then what steps you would then follow. The decking is next to some artificial turf so I want something that isn’t going to affect that at all.
Post some pics for prep help.
Here you go
Use the RAD Stripper with both additives: https://www.deckstainhelp.com/restore-a-deck-stain-stripper-booster-thickening-gel-review/
Let dwell for 30+ minutes and then pressure wash off. RAD Brightener is last.
I found your site and I am thrilled! I hope you can help me. I stained my deck 2 years ago using Valspar semi transparent stain. I prepped the deck the same way I have for the last 20 years. Now it is peeling! Never happened before. The deck is right next to a pool so I have a problem with the location. 1. Do I sand or strip! 2. do you have any recommendations for me? 3. Once it is prepped, do you recommend I use a semi transparent stain again? I am a 69 year old woman. Is it time for me to hire this to be done by an expert? Thank you so much.
Strip off what you can and then sand the rest off. Brightener would be last. Once prepped, use a penetrating semi-transparent stain so this does not happen again.
Hi- I made a porch swing out of red oak. We put it into service May of 2021 (Original Photo). Photos Example 1,2 & 3 show the deterioration of the finish and mold spots that have developed. I used 1 coat of Cabot Semi-Transparent Deck Stain as the finish. The label on the product can recommended only a single coat. Because the finish dried a little rough, I then waxed the surface with a paste wax which smoothed the final finish.
I am hoping that you can give me some direction on what to do next.
There is nothing you can do next at this point. You cannot top coat as it will peel.
Hi I like the info on your website! Very helpful.
Can I use RAD on the siding of my home? I have a Pan Abode cedar home. I have areas where black spot mold has developed on the wood. I coated one side of my home in Sikkens SRD about 8 years ago, but I need to redo that side due to weather and spot mold areas. I would rather not sand it off, if RAD will work. Thanks in advance for your input.
Post some pictures for prep help.
Thanks for the response.
The wood is a combination of Pan Abode Cedar wood and then 6’x1.5″
I look forward to your input.
I’m thinking First-RAD Stripper/Brightener.
In addition both RAD additives for vertical siding, and to penetrate the mold and former oil base stain sheen coat from older reapplication coats.
I don’t see the using the cleaner if I’m just going to use Stripper on this removal. I’m thinking of going with a water base stain for the next round of stain. Suggestions?
This will not be an easy strip as removing a coating that has a shine, can be difficult. The RAD Stripper with both additives is your best option. It should dwell for 45-60 minutes before you pressure wash off. Brightener is last. No need for the cleaner. The RAD Semi-transparent stain would work very well after.
Thank You. So with the concept- difficulty of the shine, in mind would it be better if I did a reasonable pass with an orbital sander 60-80 grit to knock down the shine and then did the stripping? Or just longer dwell time and no sanding? Or will I have to scrub after I applying the Stripper to get into the mold? I do appreciate your input!
I do not think sanding first would help at all. The mold is not the issue, the shine is. The stripper needs to get through that to break the bond between the stain and the wood.
Good advice thanks! I ordered up on the RAD stripper, additives and stain. I’ll post my findings.
I have to spot treat with the RAD stripper. Some drip marks from a previous attempt to strip won’t come off with either cleaning or sanding. The areas needing treatment are vertical and really aren’t large enough to spray. Can I brush the product on? Thank you.
Post some pictures.
thanks
You can brush or spray it on. The brightener after stripping should help even this out as well.
An update….I ordered and received the RAD Stripper and Gel.
Wanting only to treat a small area, I mixed 1/2 cup of stripper into
1/2 gal of water and then 4 oz of gel. After two applications, and brushing,
my ‘drip’ stains remain. Can you offer any advice? I can send pictures once the wood dries. Thanks.
Did you try the brightener as the discoloration from the drips may be internal?
My boyfriend and I bought a house and don’t know what stain was used on our porch. Is it a solid stain? The elements have nearly gotten it off, and we would like to restain it to help us sell it. We’ve never done anything like this before and are not sure what product would work best to get the remainder of the old stain off with minimal sanding. Any advice??
Yes, it is a solid stain. You will need to apply another solid stain over it unless you want to power sand it all off.
We stained our deck 2 years ago and after reading all these comments realize that it probably looks as bad as it does because of improper prep. That being said…time to redo it. We originally used Cabots Australian Timber oil and are leaning towards using a solid stain this time. I started power washing and there’s still a lot of stain left behind..do I need to strip, use a cleaner, sand or just finish power washing and proceed with solid stain? Pictures sent..1st pic is pre power wash!
Strip off what you can, brighten and then cover the intact stain with a new solid stain is okay: https://www.deckstainhelp.com/what-are-the-best-solid-color-deck-stains/
Purchased a home with a HUGE wraparound deck ( 30×18, 10×21, 4×21) and would love to replace- but am hoping we can squeeze a few more years out of this one. Currently, the largest deck has multiple layers ( atleast 3) of badly cracking, Peeling, lifting Sun Proof Acrylic latex solid stain from previous owners. We have tried pressure washing, scraping using CitriStrip- and nothing will penetrate to bare wood. Unsure what to do. Suggestions?
Not much you can do but sand off the loose/peeling stain and then cover the rest with a new solid stain:
Will Restore-A-Deck stain stripper work on old film-firming stain and remove completely? Thank you.
Depends on the brand and type of stain? Pictures would help as well.
I am looking to strip and then stain my deck. I think it has an acrylic type stain on it now, not sure as we bought the house like this. What type of stripper should I use? I see the Restore-A-Deck does not work on acrylics. Once the stripper is done, then I will use a brightener correct? Lastly, what is the best stain to use going forward… do I need to stick with an acrylic since that is what was originally used?
Restore-A-Deck works on semi-transparent acrylics, but no deck stain will remove this solid stain effectively. You will have to sand it to get it all off. Once removed fully, you can use any brand you want: https://www.deckstainhelp.com/the-5-best-deck-stain-reviews-and-ratings/
What can safely remove flood cwf exterior stain off pine log home?
That would depend on which version you had of the CWF and how many coats have been applied? Pictures would help as well.
Yep Two coats flood cwf clear
Pictures of stain on home?
Two coats cwf clear
Looks very thick. Not sure you will be able to strip it all off. Try the Restore A Deck Stripper with both additives and RAD Brightener after. Sand if needed to get the rest off: https://www.deckstainhelp.com/restore-a-deck-stain-stripper-booster-thickening-gel-review/
Do you know where I can purchase Stripex L deck stripper, I have been told its very good
That was discontinued over 10 years ago. It was very good. Using the Restore-A-Deck Stripper with both additives would work better though.
Thanks, could you tell me exactly which products I need to strip old stain from my pine decking then please, thanks
We would need to see some pictures of the deck and know the type and brand of stain that is being removed.
Hi tried to attach pics but not sure it’s working, the product I used was ronseal decking stain
Picture size has to be below 3mb, and then they will upload.
Will the deck wood stripper barn vynal rails
It should not.
Hi there,
I am desperate. After reading so much and wanting to do a good job on my brand new 500sqft cedar deck, I hate the stain I applied. Daly’s DechStain clear with a golden oak tint. It is supposed to be transparent to semi-transparent and the color is awful.
Long story short, I want to start anew if possible. Would you recommend a deck stain stripper such as RAD? Anything to keep in mind as I go thru the process?
Yes, I prepped the seasoned (2 months) KLDA New wood with cleaner and brightener. The results look like a solid stain rather than a transparent (see pic). I LOVE the natural look of the wood and just wanted a slight tone for protection. I screwed up.
Thanks for any advice.
Silvia
You will need the RAD Stripper with both additives to remove this: https://www.deckstainhelp.com/restore-a-deck-stain-stripper-booster-thickening-gel-review/
Brightener after.
Thank you!!
Where in Holland, Mi can I buy Boosts deck stripper?
Strip with the RAD Stripper and both additives: https://www.deckstainhelp.com/restore-a-deck-stain-stripper-booster-thickening-gel-review/
Brightener after.
Where can I buy Boosts Rad Stripper in Holland, Mi or any where near?
No idea. Check with their website.
stained our deck with a semi-transparent stain and realized when we were practically done we forgot to wipe the stain off!!!! Looks almost like paint!! Can this be fixed? What should we do?
You would have to power sand this off to fix it.
I used behr stain on my new deck and it is niw turning grey in some sections
Pergola (12yr-old kit, ‘Sonoma Arched Wood Pergola Kit’) needs drastic attention: help! we don’t even know where to start with this project. I believe the wood species is Douglas Fir. Should we apply the stain stripper first? Multiple applications? Do we need to sand? If so, is there a recommended mechanical sander/sanding method/grit you might suggest? I have a 2400psi pressure washer at my disposal. Would sandblasting help? See pics. Thanks in advance
You probably will not be able to fully strip this as you have multiple layers. Strip what you can and then sand off the rest. Brightener last. Sanding tips: https://www.deckstainhelp.com/how-to-sand-your-wood-deck/
My deck is flaking bad and I need to remove what’s on there. Would a stripper work or do I need to sand? Let me know what approach is best! Thanks.
A stripper will not remove this fully. You can strip some off then it will make your sanding easier. Brighten the wood after.
Stained our deck with Sikkens Dek stain four years ago. This the result. Will strip and sand. What do you recommend to strip the deck and what stain would you recommend to finish? Also have a green treated rough plywood enclosure around the bottom of the deck. Would like to restain that also. What do you recommend to clean the deck enclosure?
No pictures.
Hi, I have a 12′ x 4′ ft bridge (built like a deck ) over a small creek that was previously stained with a Sashco product recommended by a builder. I now want to strip, sand, brighten and then re-stain the bridge with TWP or Armstrong. I’ve read that Restore a Deck Stipper/Gels/Additives and Brightener are all ECO friendly, but would you recommend anything special in the typical stripping and pressure washing process? (I can obviously use some plastic to provide some protection, but with pressure washing, etc, there’s a good probability that there will be some spillage). Thanks in advance.
I see no issue with some of it getting in the water during prep. Try to tarp when staining though. The AC and TWP are oil-based stains.
I plan to use RAD Deck Stripper, Brightener & semi-transparent stain to update cedar flooring (35 yr) of screened in porch. The current stain is Cabot semi-transparent applied 9yr ago.
1) Is my small power sprayer (pic) sufficient to power wash rinse after stripper?
2) What duration of dwell time do you recommend for the RAD Stripper (no additives)?
3) any recommendations on preventing discoloration of screens during this process?
1. It will work but will take you a while to get it all off with that smaller sized pressure washer.
2. 10-20 minutes.
3. Not much you can do outside of removing them first.
Hi, one more question to go with my previous post. Reading another of your answers to someone else , you said use brighter “after” sanding. On our new deck I have brightened before sanding. Am I supposed to brighten after Sanding too? New and old? Or just with old? Thanks again!
Brighten all after any sanding.
Hi! I have a year and one half old huge 2000 square foot redwood deck we need to stain now. Th tannins turned it very gray. We have pressure washed it and applied Preserva “Renewer & Cleaner” wood cleaner and brightener. It did bring back nice clean color. Next we will sand it and then stain. Also we have two much older redwood decks, but still ok, adjacent to the new one, that have been stained several times over the years with semitransparent stain, either Superdeck or Cabots. Questions: 1.) what is best stripper to use to try to get old decks looking like the new? (We plan to pressure wash, use Preserva Renewer and Cleaner, and sand the old ones too after the stripper). 2.) What type of sander is best, drum or orbital for the flooring part? We have to rent it. Included are pics of new cleaned, but not yet sanded deck next to the two old ones. Thanks!
1. Restore A Deck Stripper and Brightener Kits.
2. Use a floor buffer and sanding pads.
Can RAD stripper be applied to the remaining, original stain directly after a pressure wash (ie – while wood is still damp)?
Yes but you have to pressure wash off the stripper.
I have a treated wood deck. I waited 18-24 months for the new decking to “dry” then applied Sherwin Williams semi-transparent stain. After a couple of years, the deck stain is showing a lot of wear. I used a deck cleaner and power washer to prep it for new stain. I think I need to strip or sand it before I can reapply stain or clear coat. Which would you recommend? What type of stripper or sander?
Also can’t decide whether to use stain or just apply a clear coat finish. Any suggestions on this would be appreciated.
Yes, you need to remove. Strip what you can and then sand the rest. Brighten all when done. Use a tinted stain for best results: https://www.deckstainhelp.com/the-5-best-deck-stain-reviews-and-ratings/
Did this Sherwin Williams come off well with the stripper and power washing? Did it come off the verticals?
Hi there, I have a deck that I’ve sanded down with heavy grit sandpaper but is still showing some green. It was treated about 4 years ago with copper 2 green wood preservative. Will a stripper help remove the remaining green? Or Is there anything else I can use to remove this remaining green? Thanks!
No. That is internal and a stripper will not get it out internally. Nothing will get it out.
Yeah i figured as much, should I just give it another year or do you think I can put a solid stain over it?
Test some sample colors in the semi-transparent and see if it blends or hides the green tint. Look at TWP or Armstrong Clark.
I’ve sanded down my deck with a heavy gritt power sander but there’s still a lot of green from the previous owner using copper 2 green preservative to treat the deck several years ago. Will a stain stripper work to remove the remaining green? Is there any other way to remove this green copper 2?
I put a semi transparent stain on my deck and it is way to thick, looks more like a brown paint job because the grain of wood is not showing through. Is it possible to use a stripper to take some of the stain off and then maybe finish it with a transparent stain, depending on how much of the stain comes off? It the first time this wood has been stained. What kind of stripper would you recommend?
Post a picture.
I have used a diamabrush to remove a large amount of paint from my deck but still have spots with paint..what paint remover do you recommend? I am then planning on staining the deck, what steps do you recommend? Thanks Pete
Strippers will not remove paint. You will have to sand it off. Once removed, use a penetrating deck stain. Like TWP or Armstrong Clark.
I was told by sherwin williams that smartstrip pro should work, do you not think so?
Doubt it. If you try and it does, let us know.
Okay thanks..also heard possibly citristrip could be used? Have you heard anything about that? The spots that still have paint on them will be incredibly hard if not impossible to reach with a sander. Some are in between boards
We have never had any luck with any stripper removing a paint. Sorry.
This is what is currently on it
I have an older cedar deck. The pictures show it after pressure washing. The peeling boards are from replacement boards put on one year ago. The whole deck was then covered with Sikkins water based semi-solid stain. I want to remove the Sikkins and wondering if I can use a stripper first (will it damage the unfinished spots?) and then spot sand before using a brightener. Thanks
A stripper will not remove this. You will have to power sand to fix this. Sorry.
I have 10 year old pine soffit with a clear finish. I suspect it was sealed with Profin oil based sealer (but am not certain). The soffit has aged and there are a few mildew spots. It actually looks pretty good considering. The house has a lot of soffit and I’m not looking forward to sanding it all or stripping it. What would you recommend? I live in Bellingham, WA.
Thanks for your help
Happy 4th
You would have to strip and brighten for the prep as you cannot apply over the Penofin. Stain with Armstrong Clark or TWP 100 Series.
Use the Restore A Deck Stain Stripper.
Hi. We have an Ipe tongue and groove covered front porch which is usually treated with Cabot Australian Timber Oil every 1-2 years. It was scheduled to be done this year. We did a very light sanding to rough up the surface. Unfortunately we used Sikkens Cetol and I absolutely hate it… how can I remove it?!?! We looked into having it sanded but last time the floor guy took too much off so that is no longer an option. I contacted Sikkens but they were not very helpful – just said use a stripper for oil based stain. I did try Circa 1850 stripper and it appears to have lightened it a bit. Only left it on for a few minutes. Any assistance is greatly appreciated, just sick over it. It’s only been on there for 48 hours
Not easy to remove when just applied. Use the RAD Stain Stripper with these additives: https://www.deckstainhelp.com/restore-a-deck-stain-stripper-booster-thickening-gel-review/
Apply and let dwell for 30-60 minutes before pressure washing off.
We put Behr Semi-Transparent waterproofing stain and sealer on our deck 2 years ago. It is peeling off all of the flat surfaces, but on the vertical posts etc…We would like to remove it all and start over with a new stain. Will a wood stripper work or will we need to sand the areas that are not peeling?
Post a picture of the deck in its current condition.
Here are a few photos
Use the Restore A Deck Stripper with these additives: https://www.deckstainhelp.com/restore-a-deck-stain-stripper-booster-thickening-gel-review/
Great, should that remove all of the stain?
90-100%
I use spent my weekend washing, sanding, and staining two new porches (seasoned for a year) but I really don’t like the color (semi transparent but too dark) and did a poor job with the application (some lap marks). How do I fix this?
Depends on the brand and type of stain? Pictures would help.
I used Valspar one coat Exterior Stain and Sealer, semi-transparent. The overall color is much darker than the picture.
You will need to power sand to remove this.
Have a deck surrounding a pool with IPE wood that was finished with Penofin Hardwood Formula, usually used jomax deck stripper, then a brightener then re-oil it, of course waiting for it to dry in between each step. What can i use to replace the Jomax to strip the deck. none of the local stores carry it
How do I remove Behr Semi Solid stain (dark brown) applied 3 years ago? Will stripper take it off or will I have to sand? Made my deck too hot to use here in Atlanta. Thanks.
You will have to sand.
We used Flood CWF – UV (cedar) to finish our new deck 3 year ago. It now looks dull and has spots where the finish has come off. Should I strip it and re-finish? What product would work best to finish it. We would like to see some of the wood grain.
Use the Restore A Deck Stripper and Brightener for prep. Stain with TWP 100 or Armstrong Clark.
I am striping cwf Flood what should use
Which type of CWF? There are different versions and bases. Pictures would help.
We used Behr semi solid stain on our deck. The deck was properly washed and sanded prior to stain application. We woke up to a blotchy mess because we did not apply it correctly. How do we remove the stain? We want to rent an orbital sander but not sure if we need to strip or sand?
You will most likely need to sand this to remove since just applied.
Hello. If using a stripper is too harmful to the local environment, can pressure washing thoroughly then brightening suffice for prep?
If not, are there any eco friendly strippers? (I’m guessing that’s probably not a thing.)
No, pressure washing alone will not remove a stain. Stain strippers are used all the time and do not harm the environment.
Hello. We applied solid color paint for a deck and 2 years ago reapplied the paint. Since then it has been flaking off and looks bad. I hired someone professionally to do it. Costing me 2700 to remove the paint and replace a few boards and then have it restained. It took him forever and still is not completed. Come to find out, he fell through a small board and now is suing me. He told me that he applied 12 Strippers on my deck. He then came to the conclusion that I need to replace my deck that it is unsafe. I am out 1350 which is half of the job and never finished it and looks like crap still. He could not tell how bad my deck was until he fell through. Could that be the case. Could all that stripper weaken the boards and that why he fell through. Just trying to get another opinion on this. They only sanded one small area. Just need your opinion and expertise. Thanks for listening.
Strippers will not weaken a deck board. Only rot and decay.
Removing old layers of solid stain on deck bench’s need good solid stain removal do you have any recommendations. Thank you
You will need to sand off a solid stain.
can you recommend a stripping brand to remove old decking oil? I tried the ronseal stripper from woodies and used a power hose but that did not work. The oil is really deep in the decking and is about 3 yrs old. Thanks
What brand of stain are you removing? Pictures would help.
New deck using the usual 5/4×6 treated deck boards. Sanded using 220 grit paper. Rolled Superdeck semi-transparent oil. Many sticky patches weeks later. Any ideas how to fix this ?
You might need to strip it off and start over. You did a few things wrong. New wood needs to season and be prepped correctly to open the wood grain and remove the mill glaze: https://www.deckstainhelp.com/staining-a-new-deck/
Also sanding a deck is not a good idea, especially at 220 grit. This will reduce the stain’s ability to properly soak into the wood grain.
We used Superdeck too. It is the worst ever. We are on round one of stripping and it looks like we need another coat in most spots. The we will use a brightner. Can we use a non oil after we complete all of this?
You should let the wood weather and then prep again: https://www.deckstainhelp.com/staining-a-new-deck/
As for water-based stains, try the Defy Extreme or Restore A Deck Stains.
I had someone stain my porch but I don’t like the color, so I’m trying to figure out if I need to strip what he did or if I can stain over it. He used Cabot semi-solid deck stain extra pigmented oil stain. I want a darker color but semi-transparent because I don’t like the way the semi-solid looks. Thank you!
You will most likely have to sand this off as it is very difficult to strip off a newly applied semi-solid coating. You cannot stain over this to get the look you want.
I have a similar question/concern- we stained an area of cedar on our new porch/deck and it is Sherwin Williams Woodscapes Extra White Solid- I want a neutral cedar color and not sure if we can sand the white off, or try to use another solid darker stain over it?
You can cover this with another solid stain if you like.
HELP!!!! We have a 5 year old deck that I had used a Behr solid deck stain on after waiting a year for it to “dry”. I put 2 coats on but last year decided I wanted a darker color so I just stained over it with another Behr solid color stain. This spring, “surprise” it started peeling in some spots so I started the awful task of trying to remove the stain and start over. I power washed and made a mess of quite a few boards and it hardly made a dent in the removal process. Then I rented a vibrating plate sander to try to remove the remaining stain. Again, there was a great deal of stain left behind! Then, like an idiot, I thought I could just paint over it with another brand of solid stain and now I basically have a “leopard” deck with various finishes from where the original stain was left behind, to the bare boards. I understand now what I should have done in the first place, and that is SAND the entire deck again. My question for you is, which grit do I start with to remove the actual remaining solid stain and then how do I proceed as far as when and to what grits to I switch to in order to get my deck back to a state where I can actually use a semi-transparent stain on it. Any help you can give me would be greatly appreciated!
“moronic mom in MN”
Rent a drum sander. Start with 60 grit and stop at 80 grit.
