Deck Stripping – How to Remove an Old Deck Stain 4.8/5 (100)
Hi, I am Scott Paul, an exterior wood restoration contractor and business owner with over 30 years of experience in stripping and removing exterior wood and deck stains. My Deck Stripping tips are based on my history as a wood restoration contractor and actual hands-on testing. See here for more info about me.
  1. Deck Stripping Materials
  2. Choose Proper Deck Stain Stripper
  3. Steps to Stripping a Deck
  4. Brighten the Wood
  5. Ask Me Deck Stripping Questions
  • Proper Deck Stain Stripper
  • Gas-powered pressure washer
  • Pump sprayer for applying
  • Scrub brush to agitate
  • Protective Equipment: Gloves and eyewear
  • Plastic sheeting to protect plants and home
  • Wood Brightener to neutralize when done
Scott’s Pro Tip: See here if you need to remove a Difficult to Remove Deck or Wood Stain.
Solid Color Stain Stripping
Deck Stain Stripping: Deck Stain Stripper Reviews
*Ships Free.
Makes 5-Liquid Gallons.
*Ships Free.
Removes Solid Stains.
Failing Deck Stain
Failing Wood Deck Stain
See below for my steps when we are stripping a customer’s deck
  1. Protect the house and any surrounding plants with plastic or poly tarps.
  2. Remove any patio furniture from the deck and surrounding areas.
  3. Prewet deck with water.
  4. Mix the stripper, if needed, in a bucket and transfer it to the pump sprayer if applicable.
  5. Apply the stripper to all flooring first. If a large deck, break it up into sections.
  6. Wait 5-45 minutes for the deck stripper to activate. You will know when it is working by using your scrub brush to agitate it, and the stain becomes loose from the wood. Keep the stripper from drying during this process.
  7. Pressure wash all deck flooring using a pendulum motion and about 8-12 inches from the wood. Rinse well when done.
  8. Repeat Steps 5-7 with vertical wood.
  9. Apply wood brightener when done. Rinse well with water 20 minutes after.
  • Always use a deck stain stripper. These products do 90% of the cleaning work. The power washer should only be used to rinse off the loosened grime—not as the main cleaning method.
  • Treat the power washer like a rinse tool, not a scrub brush. Use it to gently wash away the cleaner or stripper, not to grind dirt off the surface.
  • Use a sweeping, pendulum-style motion. Work with the grain of the wood and never pause or reverse direction without lifting the wand. Failing to maintain a smooth motion can leave permanent “stop marks” in the wood.
  • Keep pressure between 1200–2000 PSI. Even if you’re using a 3000 PSI machine, distance matters. Washing from 8–12 inches away will reduce the effective pressure to a safer level for wood surfaces.
  • Exercise caution. If you’re unsure about your technique or have never used a power washer on wood before, it’s best to hire a professional. Incorrect use can permanently damage your deck.
Quick Expert Recommendations and Insights
Here are some tips we recommend you follow to make deck stain removal a swift, painless process:
  1. Use a deck stripper if you are working with wood that has previously been stained. If you are working with a new wood surface or there is no stain on the deck, use a deck cleaner. If you are unsure about what to do, you can ask questions below.
  2. Remove all furniture from the area
  3. Wear protective clothing, gloves, and eyewear before going near the product. Mix or use the deck stain stripper according to the directions on the label. Test a small section of your deck before applying it to the whole area, as deck stain strippers vary in effectiveness. You may need a stronger formula if it doesn’t work on the tested area. See here if you need to remove a Difficult to Remove Deck or Wood Stain.
  4. Apply the deck stain stripper with a pump-up sprayer in sections of 100-300 square feet at a time. Saturate all the wood with one coat then wait 10-20 minutes. If the surface is slippery, that means the stain stripper is working to break the bonds effectively. If the surface is not slippery, apply another coat of the stain stripper and wait longer.
  5. Using either a brush or pressure washer, remove the old stain from the deck. Take precautions to wash with the grain wood whenever possible.
  6. Repeat this process until all of the old deck stain has been removed from the deck. Spot strip any sections where the stain didn’t come off the first time.
  7. Thoroughly rinse all wood and surrounding areas
  8. Apply a wood brightener to restore the pH balance before staining.
FAQs
How to remove deck stain without chemicals?
The best way to remove deck stain without chemicals is to sand the deck. Where semi-transparent deck stains have faded power washing the deck and spot sanding areas of thicker stain is typically sufficient. When removing a semi-solid or solid deck stain the entire deck may require sanding, but be careful not to over-sand. Over-sanding the wood compromises its integrity and can lead to early deck failure.
Will deck stain come off concrete?
Applying a deck stain can be messy and sometimes you can spill or drip on your concrete or brick pavers that are under or around your deck. Once this happens, it is not easy to remove. We have found that using a deck stain stripper and pressure washing will remove much of the spilled stain but not always as concrete can be very porous. Another option is using a graffiti remover cleaner. You can find these at your local paint store. Popular brands at Goof Off or Mostenbocker’s Lift Off.
Subscribe
Notify of
719 Comments
LEE
LEE
3 months ago
Apologies for piece-meal query. Here are a few pictures of the remnants of stain. I’m betting, though, that the whole thing should be stripped? Also, when I had the old stain pressure washed off, it was then treated by a company called ‘Elite Seal’ with a silicate based concrete and wood sealer he marketed as creating a ‘liquid glass’ barrier to moisture about 1/8″ below surface of wood that would prevent deterioration. I can find nothing on the company now, and what I can find about using concrete sealers on wood is not advisable, so I’m not happy. It was great at first but then the wood began to mildew and I’ve been washing it since.
IMG_1635
IMG_1636
IMG_1637
Sally B DeVore
Sally B DeVore
3 months ago
I have ordered the products. The young contractor I hope to help me isn’t available until end of October. I live near Cincinnati, OH. Is this too late in the fall to start this project?
LEE
LEE
3 months ago
Note: I tried just today sanding off bits of the old stain. It is too big a job for me (74, female) and occurred to me stripper would be required.
LEE
LEE
3 months ago
in 2017 we stained my deck and railings with Defy water based stain. The new lumber had been aged over 9 months. But it started flaking off in 3. In 2018 I had it pressure washed which removed 90% of the stain, but little bits remain between boards and rails, and in corners and on porch headers. Now we want to stain it with TWP 1500. What is the right stripper to use, and how long will this take? Total of 280 sq ft which includes all verticals.
Carl
Carl
7 months ago
Scott, I have a large deck (1,700+ sq. ft.) about ten years old that I will re-stain in about 10-12 days (weather permitting). I will be using TWP’s 1500 Series semi-transparent stain (Cedar color).
For context, here is the prep I have completed:
  • 2 weeks ago, using top quality PW pine, I replaced a number of deck boards, as well as some balusters, a bottom railing, and 2 stair treads.
  • Next, I pressure-washed all surfaces, including the steps, posts, balusters and railings, to remove layers of dirt, grime, algae, mold and any layers of stain that I could remove
  • Then I treated the same with Restore-a-Deck (RAD) Cleaner, to give the deck an additional cleaning treatment
  • Finally, I applied Restore-a-Deck Brightener and thoroughly rinsed off of this product per instructions
At this point, I still noticed a few small areas needing cleaning and that have retained a considerable amount of the previous stain (which I believe was a semi-transparent water-based Cabot product in a “Cedar” tone).
Here are my 2 questions: (1) Should I use the RAD Stain Stripper I have on these areas (note I have not used it anywhere else on the deck) and then Brighten, or would you recommend an alternative effort (i.e., sanding/cleaning) to get a result of “uniformity” so there will be a consistent color across my deck after I apply the new stain? (2) I’m certain the new wood I installed is too moist to accept the new stain. That said, would you NOT apply the stain on these pieces until they have sufficiently dried? My thinking is, in a few months time, I could individually apply the stain to these pieces. Thoughts?
Many thanks! – Carl
(Note: Photos attached)
IMG_1284
IMG_1287
IMG_1288
IMG_1289
Jeff
Jeff
9 months ago
I want to remove my Cabot gold stain off my deck. Is there an easier way besides sanding it all off? What stripper would you use? Also what kind of stain would you recommend for matching my old deck with my addition I put on? Thanks
Jeff
Jeff
9 months ago
Reply to  Jeff
It’s the stain that advertises the look of hardwood floors outside
20250407_164049
20250407_164028
20250407_164012
Jeff
Jeff
9 months ago
That’s what I thought. Thanks for your help.
Becke Hudecek
Becke Hudecek
10 months ago
We have raw cedar beams and railings that we stained with Behr last year that seem to be turning yellow/orange to me. I would like to start over and use a high quality stain. Is this possible without ruining my raw cedar beams and railing?
House
Stain
Eleanore Higgins
Eleanore Higgins
We have a brand new cedar deck. We put Behr Waterproof cedar naturaltone on it and it turned orange. Need to get it off but dont want to damage new wood. Stripper or industrial sander?
Advise please
Eleanore Higgins
Eleanore Higgins
Pics attached
17286691748204060704226399012300
20241010_194510
Eleanore Higgins
Eleanore Higgins
Perhaps we should just sand it then? Forget the stripping and cleaning steps?
Eleanore Higgins
Eleanore Higgins
After we get all the stain off, could you recommend a clear coat waterproofing product for use in Canada? We would like the white cedar to remain as natual looking as possible. Thompson water sealant any good?
Jane
Jane
Hi
I have a 19 y.o tigerwood deck. In the early years I cleaned and stained yearly. Life got busy and now it has been at least 5 years since last treatment. My questions for you are
1. I am planning on sanding rather than chemical stripping. What order of activity do you recommend. Sand/clean/brighten/ rinse/ dry/ stain or clean/ brighten/ sand/stain?
2. Grit recommendation and sander type for tigerwood
3. What is the best stain product and color to return the wood back to its original beautiful state. Thank you!
20240918_163212
Beckie
Beckie
I had my entire deck replaced in Aug. 2023, used yella wood. It was stained with gray color stain in April 2024. I live in NW Florida where it gets very hot in the summer. Pitch began showing up as soon as summer hit. In all the years I’ve had a deck and have had boards replaced, etc., I have never had this happen. What is the best way to remove the pitch and is there any way to do it without harming the stain. Also, should I wait until cooler weather. Thanks!
IMG_6240
Beckie Campbell
Beckie Campbell
Fun, fun, lol Thanks Scott!
Pat
Pat
I plan on applying the deck stripper with a brush to better control the application. I recall reading that certain types of brushes are not recommended for the application of caustic strippers. I have ordered RAD stripper, booster and brightener.
Why is a water based acrylic sealer harder to remove and re-apply vs an oil based semi transparent or transparent? I thought a water based would be easier to simply pressure wash off every year and then re apply. I’m looking for the least maintenance possible. My deck wraps around my pool, so the least amount of stripping and sanding possible is what I’m looking for to reduce contaminants. And getting on my hands and knees to strip every thing every year is not my cup of tea.
When you say “filming”, what do you mean? And in my case, with all these spots and blotches, do you think I can just take it up with my pressure washer before applying a new sealer, or do I really need to strip? If so, what stripper for a water based clear sealer?
Martha
Martha
We just stained our deck with TWP 1500 series and it is blotchy. Some areas look dry and some not. We applied with a large deck brush and followuped with back brushing. The first coat seemed to look dry before we began a second coat. It was longer than the recommended 10 to 60 minutes when we applied the second coat as we wanted to get a first coat on. It has been 24 hrs and it is tacky. Will it eventually dry? I tried wiping with a rag of mineral spirits but it made it a mess, pulling the stain off like a peeling sunburn.
This is a new deck. We waited a year and it was cleaned twice and had minimal 80 grit sanding 2 months prior to staining. I thought I carefully read your instructions when applying. I think one coat would have been sufficient as it seemed to quickly dry. It is very hard to judge from the instructions what the stain should look like when applying to judge what it should look like. I saw that one is supposed to wipe off any pooled areas but perhaps after 10 minutes the whole board should be wiped off? Personally I am not sure I would recommend this product as I don’t think the results are acceptable for ease of use. One coat would have yielded an acceptable outcome.
Now what? Will it dry or will it continue to be sticky and what do I do so we can use our deck?
Kathy
Kathy
How can I remove peeling RESTORE Deck stain ? The type that had law suits because it peeled. Thank you.
Jodi
Jodi
I have a large deck that is painted with a solid color stain (previous owners didn’t take care of this house). You can see there are two colors going on here. What do you recommend for removing absolutely all color? There are also a lot of areas with wood rot that need to be replaced. I want to get our deck back to a beautiful brown wood stained color.
Konni Barich
Konni Barich
I have a large deck built with treated wood. It is partially stained with a stain that was too red. I want to remove this stain and apply a different stain, one with more brown tones. How can I prep the whole deck (stained and pressure treated) so it takes the stain equally?
Konni
Konni
Hopefully you can see this picture
MARJORIE C WOOTEN
MARJORIE C WOOTEN
Age of porch with bloody dog footprints in recent comment – 25 years
MARJORIE C WOOTEN
MARJORIE C WOOTEN
Removal of dog blood from porch,several bloody dog footprints from an injury; porch never been stained or painted, advise removal of the blood,
Yvonne
Yvonne
Good Evening, I have a 20-year-old Cedar deck that I need to re-stain as so as possible. I believe after reading so many posts I should try the Restore A Deck. I’ve been trying to see if it kills grass and flowers. Any advice will be greatly appreciated.
Rich J.
Rich J.
it’s great you’re providing this resource! The deck I am working on is a hardwood deck that has been stained with an oil semi transparent stain every year for the last 15 years. Some of the decking was black before I started this project. So far, I have used a stain remover, followed by a wood brightener. I have not achieved my desired appearance yet. Can you please provide advice on how to proceed? I have attached photos.
Rich J.
Rich J.
Just following up to say that it’s looking much better. I used the floor buffer with 60-grit mesh sandpaper and a scrubbing pad as backer on the entire deck which really helped to bring back the wood grain appearance I’m looking for. Is it ready for stain, or should I do something else before that? The look is a little inconsistent, but the stain will probably blend everything and make the inconsistency disappear.
Kathy R
Kathy R
I had a new deck installed 3 years ago. I treated all the wood with Penofin (clear) blue label at that time. It, of course (now reading your reviews), turned to a dark gray. I used a product called Sun Frog Deck Cleaner to prep the deck for re-treatment. I was unhappy with the Penofin because water seemed to just soak into my deck and I live in Oregon and we have a lot of rain. I then saw that Penofin made a product that was a Stain and Sealer so decided I would try that. They didn’t make it in clear, so I chose the Cedar finish (it is a cedar deck). I should have stopped immediately, but with the rainy season fast approaching, I figured I just needed to get something on the wood. Now, however, I just can’t stand how dark it has made my deck. I need your advice – I have thought about just completing the deck in this Penofin so that when I attempt to strip it next year at least it will have a similar look everywhere. That is, unless there is a product that can completely remove all this freshly applied Penofin. The staining is about 1/3 completed. So, is there a product that will completely remove this fresh stain? Please tell me all the products I should use (it sounds like a brightener is another important step, that I have never used). The TWP 100 series is rated the best on your site so I will use that next time (should I get clear or cedar to get the look that you have on your banner above?). Thank you so much for your help!!
1 4 5 6
719
