If you’re ready to buy a deck stain stripper that delivers real results, this category offers proven solutions for removing old stain, sealers, and stubborn coatings. Restore-A-Deck® wood stain strippers are designed to quickly and effectively break down failing finishes, helping you avoid uneven absorption and premature stain failure. This is the critical prep step for consistent color and long-lasting performance in your next stain application.
Whether you need a complete stripper and brightener kit, a high-strength stripper, or an additive to boost performance on tough coatings, you can shop this collection to find the right product for your project. These solutions are ideal for decks, fences, siding, and other exterior wood surfaces where proper stain removal is essential before re-staining.
Buy Restore-A-Deck Wood Stain Strippers & Additives – The Ultimate Solution for Stain Removal
Effectively Remove Old Stains, Sealers & Coatings for a Fresh Start
The Restore-A-Deck (RAD) Wood Stain Stripping System is designed to make removing old stains, sealers, and coatings easier and more effective. Whether you’re dealing with semi-transparent stains, over-applied coatings, or stubborn finishes, RAD Strippers and Additives will help break down and remove unwanted coatings, restoring your wood to its natural state before re-staining.
🔹 Restore-A-Deck Stain Stripper – Removes Old & Worn-Out Stains
✔ Breaks down and removes semi-transparent and semi-solid oil-based and water-based stains.
✔ Eliminates the need for sanding before re-staining.
✔ Prepares wood for proper stain adhesion by stripping away unwanted layers.
✔ Works on decks, fences, log homes, and other exterior wood surfaces.
🔹 Best For: Removing semi-transparent stains, worn-out sealers, and coatings before re-staining.
🔹 Restore-A-Deck Stain Stripper Thickening Gel – Clings to Vertical Surfaces
✔ Enhances the effectiveness of RAD Stain Stripper by extending dwell time up to 1 hour.
✔ Prevents runoff on vertical and horizontal surfaces, making stripping easier.
✔ Perfect for wood railings, fences, and wood-sided homes.
✔ Mixes with 5-gallon premixed Restore-A-Deck Stain Stripper for best results.
🔹 Best For: Vertical surfaces such as railings, fences, log homes, and siding where runoff can be an issue.
🔹 Restore-A-Deck Stain Stripper Booster – Boosts Stripping Power by 300%
✔ Strengthens the stain stripper’s ability to break down hard-to-remove coatings.
✔ Deeply penetrates the wood grain to dissolve stubborn finishes.
✔ Improves performance on both oil-based and water-based stains.
✔ Simply mix into 5-gallon premixed Restore-A-Deck Stain Stripper.
🔹 Best For: Difficult-to-remove wood stain finishes that require extra stripping power.
🔹 RAD Paint & Solid Stain Stripper – Removes Heavy Coatings & Paint
✔ Specifically designed to remove solid color wood stains, paints, and varnishes.
✔ Works on thick or excessively over-applied acrylic semi-transparent and semi-solid coatings.
✔ Penetrates deep to break down stubborn film-forming finishes.
🔹 Best For: Removing solid color stains, paint, and thick acrylic coatings that RAD Stain Stripper cannot fully remove.
✔ Get Professional-Grade Stripping Power with Restore-A-Deck!
For the best results, use RAD Stain Stripper with Thickening Gel and Stripper Booster for maximum effectiveness on tough stains. If you’re dealing with solid color stains, paints, or heavy coatings, opt for the RAD Paint & Solid Stain Stripper instead.
✔ Easily strip away old stains for a fresh new start!
✔ Restore your deck, fence, or siding with minimal effort!
✔ Ensure better stain adhesion and long-lasting results!
🔹 Order your Restore-A-Deck Stain Strippers & Additives today for a cleaner, fresher wood surface!
Once you add all your products to the cart, you can review the total cost and ensure everything ships together.Â
Expert Help When You Need It
FAQs About Restore-A-Deck Wood Stain Strippers & Additives
How do I know which deck stain stripper to buy?
The right stripper depends on what you are removing. Most homeowners start with a standard Restore-A-Deck® wood stain stripper for old or failing stains and sealers. If you are dealing with heavy buildup, solid stains, or paint, adding a booster or thickening gel can significantly improve stripping power and dwell time.
Can I use Restore-A-Deck strippers on my type of wood?
Yes. Restore-A-Deck wood stain strippers are designed for common exterior woods, including pressure-treated pine, cedar, redwood, and many hardwoods. Always review the product label and instructions before use, especially on exotic hardwoods or previously coated surfaces, to ensure proper application and results.
What surfaces can I use these strippers and additives on?
These products are ideal for removing stains and coatings from decks, fences, railings, siding, pergolas, and other exterior wood surfaces. Additives such as boosters and thickening gels help tackle vertical areas and stubborn finishes where standard stripping alone may not be sufficient.
Do I need additives, or is the stripper sufficient on its own?
For many projects, the stripper alone is sufficient. Additives are recommended when removing thick, solid, or multiple layers of old stain or paint. Booster additives increase stripping strength, while thickening gels help the stripper cling longer to vertical or difficult surfaces for more effective removal.
Why is proper stain removal so important before re-staining?
If the old stain is not fully removed, the new stain cannot penetrate evenly, leading to blotchy color, poor adhesion, and premature failure. Using a quality stripper and the right additives ensures the wood is properly prepped, allowing your new stain to perform and last as intended.
Ready to strip and restore your wood the right way?
Buy Restore-A-Deck® wood stain strippers and additives today to prep your deck, fence, or other exterior wood surfaces for a long-lasting, professional-quality finish.
Restore-A-Deck Package 600
