Chapin 1949 Industrial Sprayer – 3.5-Gallon Heavy-Duty Steel Sprayer
The Chapin 1949 is a professional-grade industrial sprayer designed for high-performance applications, including deck stains, sealers, concrete sealers, and wood restoration products. Built for durability and efficiency, this sprayer is trusted by contractors, painters, and wood restoration professionals for its superior chemical resistance and even application.
🔹 Key Features of the Chapin 1949 Sprayer
✔ Heavy-Duty 3.5-Gallon Tri-Poxy Steel Tank – Resists corrosion, dents, and rust for long-lasting use.
✔ Brass Spray Wand & Nozzle – Durable components ensure consistent performance and precise application.
✔ 4-Inch Wide Funnel Opening – Easy to fill and clean without spills.
✔ Compatible with Most Wood & Concrete Sealers – Ideal for deck stains, penetrating sealers, and other professional coatings.
✔ 40-60 PSI Operating Pressure – Delivers consistent spraying power.
✔ Ergonomic Handle with Lock-On Feature – Reduces fatigue during large applications.
✔ Chemical-Resistant Seals & Gaskets – Compatible with a variety of oil-based and water-based stains and sealers.
Chapin Clean & Stain Sprayer
