CUTEK® Quickclean is the perfect way to regularly keep all your wood clean, and it prepares wood to optimize the performance of maintenance coats of CUTEK® Extreme.
It will easily remove dirt, grease and grime from your outside surfaces as well as even out CUTEK® Colortone that has started to wear or erode unevenly on your wood.
CUTEK® Quickclean is a concentrate that should be diluted with water. The dilution will vary depending on the build-up of dirt/grease on the surface.
FEATURES OF CUTEK® QUICKCLEAN
Powerful Outdoor Cleaner
A versatile, general-purpose cleaner that removes dirt, grease, and grime from a wide range of outdoor surfaces.
Ideal for Routine Wood Maintenance
Perfect for regular cleaning and preparing wood surfaces for a maintenance coat of CUTEK® Extreme.
Easy Cleanup of CUTEK® Spills
Quickly and effectively cleans up accidental spills of CUTEK® Extreme.
Safe for All Hard Surfaces
Suitable for use on composite decking, plastic, PVC, tile, pavers, concrete, and glass.
Typical Uses
- Routine cleaning of outdoor wood surfaces to remove dirt, grease, and grime
- Preparing wood for a maintenance coat of CUTEK® Extreme
- Cleaning exterior hard surfaces such as composite decking, PVC, plastic, tile, pavers, concrete, and glass
Important Notes
CUTEK® Quickclean is designed for general cleaning and may not remove deep or stubborn stains. For restoring gray, weathered wood or removing tougher stains such as iron, water marks, tannins, resins, mold, or mildew, use CUTEK® Wood Reviver instead.
CUTEK® Quickclean will not remove paint or existing wood coatings. For stripping coatings, use CUTEK® Wood Stripper.
STEP 1: PREPARE
Before starting, determine if CUTEK® Quickclean is suitable for your specific application. Always test on a small area first, following the recommended dilution guidelines before mixing larger batches.
Because surfaces and conditions vary, testing will help you determine:
- The correct dilution ratio
- Working time
- Total product needed
- The most effective cleaning technique for your situation
Safety & Precautions
- Review all hazards and safety guidelines in the Safety Data Sheet (SDS) before use
- Wear proper protective equipment
- Be aware of wind drift when rinsing, especially near vehicles or pedestrian areas
- Pre-wet and rinse nearby areas (plants, concrete, asphalt, etc.) before and after application
How to Apply
Recommended Dilution & Coverage
| Purpose | Dilution | Coverage |
| Remove dirt, grease, and grime | 1:8 (1 part CUTEK® Quickclean to 8 parts water) | ~850 sq. ft. per 4.5 gallons (mixed solution) |
Important:
CUTEK® Quickclean is a concentrated cleaner and must be diluted. Actual coverage and dilution may vary depending on the surface type and severity of buildup. Always test first to confirm effectiveness.
Application Steps
- Dilute CUTEK® Quickclean with water as needed
- Test your solution on a small area
- Pre-wet the surface with water
- Apply generously using:
- Brush
- Roller
- Broom
- Low-pressure garden sprayer
- Allow the product to dwell for 5–15 minutes
Removal
- Rinse thoroughly with water after cleaning
- For best results, use a pressure washer (approx. 750 PSI / 50 bar) with a fan tip
Important Cautions:
- Avoid damaging wood fibers:
Best practice:
Alternative:
If pressure washing is not practical, rinse with clean water using a hose or bucket while lightly scrubbing with a stiff brush.
Clean-Up
- Dispose of wash water in accordance with local regulations
Gemini Restore-A-Deck Kit
