DEFY Composite Deck Waterproofing Sealer – Long-Lasting Protection for Composite & Natural Wood Decks
Crystal Clear, Zinc Nano-Technology Formula for Maximum UV & Moisture Resistance
DEFY Composite Deck Waterproofing Sealer is an extremely durable, water-based clear finish designed to protect composite and natural wood decks from UV radiation, moisture damage, and fungal growth. This VOC-compliant formula is fortified with zinc nano-particles, providing unmatched protection against black algae stains, fading, and discoloration.
By reflecting harmful UV rays and resisting mold and mildew, DEFY Composite Deck Sealer helps retain the original color of your deck while preventing premature graying and staining.
🔹 Why Choose DEFY Composite Deck Waterproofing Sealer?
✅ Advanced Zinc Nano-Technology – Over 30 trillion nano-particles per square inch block UV rays, preventing fading & discoloration.
✅ Prevents Black Algae Stains – Fortified with natural fungal inhibitors to resist mold, mildew, and algae growth.
✅ Crystal Clear Finish – Enhances and preserves the natural look of composite and wood decking.
✅ Water-Based & VOC-Compliant – Eco-friendly, easy cleanup with soap & water.
✅ Works on All Composite & Natural Wood Surfaces – Designed for use on Trex, TimberTech, Azek, Fiberon, Evergrain, ChoiceDek, and more.
✅ Prevents Water Damage – Helps repel moisture, reducing warping, cracking, and rot.
🔹 Where to Use DEFY Composite Deck Waterproofing Sealer?
✔ Composite & Natural Wood Decking
✔ Porches & Patios
✔ Pool Decks & Docks
✔ Fences & Pergolas
🔹 Application & Coverage
✔ Coverage Rate: 200 sq. ft. per gallon
✔ Available in 1-Gallon Containers – Ideal for deck maintenance and full applications
✔ Recoat When Graying Appears – Ensures continuous protection & color retention
📌 Preparation Tip: Before applying, clean the deck with DEFY Composite Deck Cleaner to restore the surface and maximize stain adhesion.
✔ Keep Your Composite Deck Looking Like New with DEFY Composite Deck Sealer!
✔ Blocks UV rays to prevent fading and discoloration!
✔ Resists black algae, mold, and mildew stains!
✔ Provides long-lasting moisture protection for composite decks!
🔹 Order DEFY Composite Deck Waterproofing Sealer today and protect your deck with cutting-edge nano-technology!
Defy Exterior Wood Stripper
