Messmer’s Wood and Deck Brightener (Part B) – Maximum Strength Powder Concentrate
Messmer’s Wood and Deck Brightener (Part B) is an eco-friendly, high-performance brightening solution designed to enhance the natural beauty of exterior wood. It works by neutralizing cleaners, removing tannin stains, rust stains, and discoloration, and prepping wood for staining.
- Messmer's Wood and Deck Brightener (Part B) neutralizes cleaners, removes tannin stains, rust stains, and discoloration to prep wood for staining.
- The formula is biodegradable and non-toxic, making it safe for wood fibers while still delivering professional-grade brightening performance.
- Each 16 oz. jar makes 5 gallons of solution and covers up to 600 square feet, offering strong value for larger projects.
- Mix the powder fresh on-site with warm water, apply with a pump sprayer or brush, and let sit for 10 to 15 minutes.
- Works on all wood types including cedar, redwood, IPE, pressure-treated lumber, and log homes, making it highly versatile.
- For best results, use Messmer's Part A Cleaner first to remove dirt and mildew before applying Part B Brightener to neutralize and prep.
🔹 Why Choose Messmer’s Wood and Deck Brightener?
✔ Restores & Brightens Exterior Wood – Ideal for decks, fences, log homes, and outdoor furniture.
✔ Essential for Staining Prep – Neutralizes cleaners and improves stain penetration & longevity.
✔ Powerful but Safe Formula – Biodegradable, non-toxic, and will not harm wood fibers.
✔ Perfect for Tannin & Rust Stains – Works exceptionally well on cedar, redwood, and iron-stained wood.
✔ Mix Fresh for Maximum Strength – Comes in 16 oz. jars, each making 5 gallons of brightener solution.
🔹 How to Use
✔ Mix On-Site for Best Results – Dissolve powder in warm water and stir well.
✔ Apply with Pump Sprayer, Mop, or Brush – Let sit for 10-15 minutes.
✔ Rinse Thoroughly with Water – Use a garden hose or pressure washer for best results.
✔ Use After Wood Cleaning or Stripping – Works best following Messmer’s Wood & Deck Cleaner (Part A).
🔹 Coverage & Compatibility
✔ Covers up to 600 sq. ft. per jar
✔ Safe for all wood types, including:
- Cedar & Redwood (removes tannin stains)
- IPE & Exotic Hardwoods
- Pine & Pressure-Treated Lumber
- Log Homes & Outdoor Furniture
🔹 Why Use Part A First?
For best results, clean your wood with Messmer’s Wood & Deck Cleaner (Part A) before brightening. Part A removes dirt, grime, and mildew, while Part B neutralizes and brightens wood, ensuring a smooth, even stain application.
Messmer’s Wood & Deck Brightener (Part B) is the ideal solution for prepping wood for staining and restoring its natural color. Order today for professional-grade results!
