R-A-D™ PaintStrip Paint & Solid Stain Stripping Gel – 1 Gallon
Fast-Acting, Eco-Friendly Formula for Tough Paint & Solid Stain Removal
R-A-D™ PaintStrip is a professional-strength, fast-acting stripping gel designed to remove multiple layers of paint, solid stains, and coatings from a variety of surfaces. This eco-friendly, non-toxic formula works on wood, concrete, brick, metal, stone, and more, providing superior stripping power without harsh fumes or hazardous chemicals.
- RAD PaintStrip removes up to 15 layers; begins working quickly, removing up to five layers in 30 to 45 minutes.
- RAD PaintStrip stays wet 24+ hours, clings to vertical and horizontal surfaces, apply with brush, roller, or sprayer.
- RAD PaintStrip not recommended for transparent or most semi-transparent stains; use Restore-A-Deck Stain Stripper instead.
- RAD PaintStrip contains no methylene chloride or NMP; wear safety goggles and gloves, wash after use.
- RAD PaintStrip covers about 50 to 100 sq ft per gallon; scrape or pressure wash at an angle, dispose waste per local regulations.
🔹 Why Choose R-A-D™ PaintStrip?
✅ Removes Up to 15 Layers of Coatings – Strips paint, varnish, lacquer, and solid stains in a single application.
✅ Fast-Acting Formula – Begins working within 5 minutes, removing up to 5 layers in 30-45 minutes.
✅ Stays Wet for 24+ Hours – Allows for extended stripping time on difficult coatings.
✅ Clings to Vertical & Horizontal Surfaces – Ideal for railings, siding, doors, and deck floors.
✅ Eco-Friendly & Safe to Use – No methylene chloride, NMP, or harsh fumes.
✅ Non-Flammable & Non-Combustible – Safe for indoor and outdoor projects.
✅ No Neutralization Required – Does not need Restore-A-Deck Wood Brightener after stripping.
📌 Note: R-A-D™ PaintStrip is not required for transparent, semi-transparent, or most semi-solid deck stains. For those, use Restore-A-Deck Stain Stripper instead.
🔹 Where to Use R-A-D™ PaintStrip?
✔ Solid Color Wood Stains & Paints
✔ Excessively Over-Applied Semi-Transparent & Semi-Solid Coatings
✔ Acrylic & Latex-Based Wood Stains (Behr, Thompson’s, Olympic, SuperDeck, Valspar, Benjamin Moore ArborCoat, etc.)
✔ Varnish, Lacquers, and Other Coatings
✔ Wood, Brick, Concrete, Stone, Plaster, Metal, and Fiberglass
📌 DO NOT use on drywall, rubber, plastic, or vinyl surfaces.
🔹 Coverage & Application Instructions
✔ Coverage: 50-100 sq. ft. per gallon
✔ Application: Apply with a brush, roller, or sprayer for best results.
✔ Dwell Time: Works in as little as 30-45 minutes but can stay active for up to 24 hours.
✔ Removal: Scrape away softened coating and rinse with water.
📌 Pro Tip: For extra-thick coatings, cover the applied area with plastic wrap to prevent drying and maximize stripping power.
✔ Remove Tough Paint & Stains with R-A-D™ PaintStrip!
✔ Eliminates multiple layers of stubborn coatings with ease!
✔ Safe for use on wood, concrete, metal, and more!
✔ Eco-friendly formula with no harsh chemicals or fumes!
🔹 Order R-A-D™ PaintStrip today and tackle even the toughest stripping projects with confidence!
Directions and Technical Info
Test Patch:
Before general use, test on a small area to determine compatibility, required dwell time, and coverage for desired results. For an estimated 5 or less coats, scrape a section of the area with a stripping tool after one hour of dwell time. If not easily down to wood after one hour, leave on longer and test again hourly. For 10 – 15 coats of paint, cover with plastic and wait 24 hours to test. For best results, cover the stripper with plastic and do not allow to dry.
DIRECTIONS:
- Shake well before use. Protect all areas not being stripped with plastic sheeting. Rubber gloves
and safety glasses are recommended for eye and skin protection. - Pour into a container and apply with a brush, roller (best applied with a 1 1/4” nap roller), or airless sprayer. Apply liberally – the stripper should cover the color of the stain. For best results and extended dwell times, cover stripper with plastic. Cover if needed to keep from drying out, do not mist with water, as that can deactivate the stripper. Test stripping a small area to ensure you are down to the substrate. If not, leave R-A-D™ PaintStrip on and let it do its job. R-A-D™ PaintStrip may or may not bubble. This will depend on the type of paint or sealer being removed. One gallon covers approximately 50-100 sq. ft. Best results are achieved when R-A-D PaintStrip is applied at temperatures between 60F and 80F.
- For best results, agitate with a stiff bristle brush and then remove by either scraping or pressure
washing. Always pressure wash at an angle so that the water jet acts as a chisel. - Let surface dry completely before refinishing. Clean all tools with soap and water.
- Dispose of paint or sealer waste in accordance with local, State, and Federal regulations.
COVERAGE:
R-A-D™ PaintStrip covers approximately 50-100 square feet per gallon of product. Coverage will vary on application method and substrate.
Contains benzyl alcohol, monoethanolamine and surfactants. Prevent eye contact. Avoid contact with skin and clothing. Wear safety goggles and gloves during use. Wash with soap and water after use. Keep container closed when not in use. FIRST AID: EYES: Immediately flush with water for at least 20 minutes. If wearing contact lenses, remove and continue flushing with water. Seek immediate medical attention. SKIN: Rinse with soap and water. Remove contaminated clothing and launder before reuse. If irritation develops, seek medical attention. SWALLOWED: If swallowed, rinse mouth out with water and give 1 glass of water if person is alert. Do not induce vomiting. Immediately contact a poison control center, physician, or hospital emergency room for instructions.
KEEP OUT OF REACH OF CHILDREN. Max: voe g/L; Max Vapor Pressure of voe: 28.5 mm Hg. Non-photochemically Reactive. Less than 50% VOC. No Methylene Chloride or NMP I Eco-Friendly
RAD Paint & Solid Stain Stripper - Sample Size
