If you want your deck, fence, or exterior wood to look its best and take stain evenly, proper brightening after cleaning or stripping is essential. Buy Restore-A-Deck Brightener Only to restore the wood’s natural color and balance its pH, creating an ideal surface for stain penetration and long-lasting results.
This biodegradable wood brightener works as a powerful neutralizer and color booster after prep, removing tannin stains and helping wood regain its natural beauty without harsh chemicals. Use it after cleaning or stripping to unlock better stain performance and more even, vibrant color on decks, siding, and outdoor wood surfaces
Restore-A-Deck Wood Brightener – The Best Deck Brightener & Neutralizer
Restores, Neutralizes & Prepares Wood for Staining
Restore-A-Deck Wood Brightener is a biodegradable, eco-friendly powdered concentrate designed to brighten, restore, and neutralize exterior wood surfaces after cleaning or stripping. This Step 2 product in the Restore-A-Deck system enhances wood color, removes rust and tannin stains, and prepares wood for optimal stain absorption.
🌱 Eco-Safe & Biodegradable – Will not harm plants, pets, or landscaping
💰 Cost-Effective – 1 container makes 5 gallons, costing less than $6 per gallon
🏆 Restores Natural Wood Beauty – Neutralizes wood cleaners & strippers, preventing over-drying
🔹 Why Choose Restore-A-Deck Wood Brightener?
✅ Neutralizes Wood Cleaners & Strippers – Restores wood to its ideal pH balance before staining.
✅ Brightens & Enhances Natural Wood Grain – Eliminates darkened tones, improving stain absorption.
✅ Removes Tannin & Rust Stains – Gets rid of leaf stains, watermarks, and metallic rust stains.
✅ Works on All Exterior Wood Surfaces – Ideal for decks, fences, siding, furniture, pergolas, and more.
✅ Easy-to-Use Powdered Formula – Mixes with water to make 5 gallons, covering 750-1,000 sq. ft.
✅ Improves Wood Stain Performance – Prepares the surface for better adhesion & longer-lasting stain protection.
📌 Note: Restore-A-Deck Wood Brightener is not a cleaner. It does not remove dirt, mildew, or grayed wood fibers. For cleaning, use Restore-A-Deck Wood Cleaner or Restore-A-Deck Stain Stripper before applying the brightener.
🔹 Where to Use Restore-A-Deck Wood Brightener?
✔ Wood Decks & Railings
✔ Fences & Outdoor Furniture
✔ Siding, Gazebos, & Playsets
✔ Redwood, Pine, Cedar, and All Exterior Wood Species
📌 Best used after:
✔ Restore-A-Deck Wood Cleaner (Step 1 – Cleaning Process)
✔ Restore-A-Deck Stain Stripper (Step 1 – Stripping Process)
📌 Not required for: RAD Paint & Solid Stain Stripper Gel applications.
🔹 How to Use Restore-A-Deck Wood Brightener
1️⃣ Mix Solution: Add one container to 5 gallons of water.
2️⃣ Apply to Surface: Use a pump sprayer, brush, or mop to saturate the wood.
3️⃣ Let Sit for 10-15 Minutes: The brightener neutralizes chemicals and brightens wood.
4️⃣ Rinse Thoroughly: Use a garden hose or pressure washer to remove all residue.
5️⃣ Allow to Dry Before Staining – Wood should fully dry before applying stain.
📌 Pro Tip: Brightening your wood improves stain absorption and longevity.
✔ Restore & Brighten Your Deck with Restore-A-Deck Wood Brightener!
✔ Neutralizes wood cleaners & strippers for balanced wood pH
✔ Brightens and restores wood color before staining
✔ Removes tannin & rust stains for a clean, natural finish
🔹 Order Restore-A-Deck Wood Brightener today and prepare your deck for the best stain results!
Expert Help When You Need It
FAQs About Restore-A-Deck Brightener Only
Why should I buy a wood brightener before staining?
After cleaning or stripping, wood is often left darkened and chemically unbalanced. Restore-A-Deck® Brightener neutralizes the surface, restores natural color, and creates the proper pH so stain can absorb evenly and last longer.
When should I use Restore-A-Deck Brightener?
Use it after cleaning or stripping and before staining. Brightening is a critical prep step that removes residue, eliminates tannin bleed, and opens the wood pores for better stain penetration.
Can I use Restore-A-Deck Brightener on my type of wood?
Yes. This brightener is safe for common exterior woods, including pressure-treated pine, cedar, redwood, and many hardwoods. It is also commonly used on decks, fences, siding, pergolas, and other outdoor wood surfaces.
Do I need a brightener if the wood already looks clean?
Yes. Even clean-looking wood can still have an unbalanced pH after stripping or cleaning. Skipping the brightening step can lead to uneven color, reduced absorption, and shorter stain life.
What happens if I skip the brightening step?
Without brightening, the stain may sit on the surface rather than soak in properly. This often causes blotchy color, poor adhesion, and premature stain failure. Using a brightener helps ensure consistent color and long-term performance.
Ready to prep your wood for the best stain results?
Buy Restore-A-Deck® Brightener Only today to restore natural wood color, improve stain penetration, and set your deck or exterior wood up for a longer-lasting finish.
We had a soft wash done professionally. They did not apply brighter. We cant do this for several days. Is it effective after the cleaned deck dries? This was never stained wood that had grayed. Our painter will be staining afterwards.
Yes, it is.
Hello, Do i need the Brightener if i power sand the deck?
