Deck Floor Staining Push Brush – Now Available in Two Sizes!
Stain 40% Faster with the New 14” Brush!
Make your deck staining faster, easier, and more efficient with the Deck Floor Staining Push Brush, now available in two sizes: 10″ and 14″. This brush is designed to break surface tension, forcing the stain deep into the wood pores for better absorption and a longer-lasting finish. Perfect for decks, fences, and wood siding, this professional-grade brush allows you to stain more boards at once, cutting down your work time significantly.
🔹 Why Choose the Deck Floor Staining Push Brush?
✅ Available in 10” & 14” Sizes – The new 14” brush stains 40% faster, covering more surface area with each pass.
✅ Deep Stain Penetration – Breaks surface tension, ensuring the stain absorbs fully into the wood pores.
✅ Saves Time & Effort – Cuts staining time in half, allowing for quick and even coverage.
✅ Reduces Strain on Your Back & Knees – Works with standard threaded extension poles to eliminate bending and kneeling.
✅ Durable 2 ¾” Soft Bristles – Provides smooth, streak-free application without missing spots.
✅ Compatible with Most Stains – Works with Transparent, Semi-Transparent, and most Semi-Solid Wood Stains.
📌 Note: This brush will not work with Solid Color Stains.
Wooster 5.5" Pro Stain Brush
Does this come with an extension pole?
No.
