TWP 100 Pro-Series Stain & Restore-A-Deck Stripper & Brightener Combo – Strip, Brighten & Stain in One Kit!
Complete Wood Restoration & Protection System
The TWP 100 Pro-Series Stain & Restore-A-Deck Stripper & Brightener Combo is the ultimate solution for removing old coatings, restoring wood color, and applying a long-lasting protective stain. This all-in-one system allows you to deep clean and strip away previous finishes before brightening and staining your wood deck, fence, or siding.
✔ (1) TWP 100 Series 5-Gallon Pail – Premium Oil-Based Stain & Sealer
✔ (1) Restore-A-Deck Stain Stripper – Powerful Coating Remover
✔ (1) Restore-A-Deck Wood Brightener – Neutralizes & Restores Natural Wood Color
🏆 #1 Rated Deck Stain & Prep System – Trusted by professionals & homeowners
🛡 Removes Old Stains & Seals Against UV & Water Damage – Extends the life of your wood
🔹 Why Choose the TWP 100 Pro-Series Stain & Restore-A-Deck Stripper & Brightener Kit?
✅ Removes Old & Worn Coatings – Strips away previous stains, varnishes, and sealers
✅ Neutralizes & Brightens Wood – Restores natural wood tone & improves stain adhesion
✅ Deep Penetrating Oil-Based Stain – Enhances wood grain while protecting against moisture
✅ Superior UV & Water Resistance – Prevents graying, cracking, warping, & mold growth
✅ Works on All Exterior Wood Surfaces – Decks, fences, siding, log homes, & outdoor furniture
✅ Easy Application & Maintenance – Cost-effective professional results
📌 Note: TWP 100 Series is not compliant in all states. Check VOC restrictions before purchasing.
🔹 What’s Included in the TWP 100 Stain & Prep Kit?
(5 Gallons) TWP 100 Pro-Series Stain – Deep Penetrating Protection
✔ Premium oil-based stain & sealer for lasting protection
✔ Preserves wood’s natural beauty & prevents graying
✔ Repels water & resists mold and mildew
✔ Prevents cracking, splitting, and freeze damage in colder climates
✔ Enhances wood tones & protects against UV exposure
📏 Coverage: 150-250 sq. ft. per gallon (varies by wood porosity).
Available in 8 Stunning Colors:
🎨 101 Natural – Clear with minimal tint for a natural look
🎨 102 Redwood – Rich, warm redwood tone
🎨 103 Dark Oak – Deep, classic wood stain
🎨 105 Cape Cod Gray – Near semi-solid gray appearance
🎨 106 Prairie Gray – Light gray with a subtle wood tone
🎨 115 Honeytone – Light golden-brown hue
🎨 116 Rustic – Medium brown with warm undertones
🎨 120 Pecan – Rich brown with a slight red tint
📌 TWP 105 Cape Cod Gray & 106 Prairie Gray have a near semi-solid finish.
Step 1: Restore-A-Deck Stain Stripper
✔ Removes most clear, transparent, semi-transparent, & semi-solid stains
✔ Eliminates dirt, mold, mildew, and old sealers
✔ Eco-safe & biodegradable – safe for plants, pets, and grass
✔ Works on both oil-based & water-based stains
📏 Coverage: 500-1,000 sq. ft. per container.
🚫 Not designed to remove solid color stains, paints, varnishes, or thick acrylic coatings.
✔ For those coatings, use the Restore-A-Deck Paint & Solid Stain Stripper.
Step 2: Restore-A-Deck Wood Brightener
✔ Neutralizes the stain stripper & restores wood’s natural color
✔ Removes rust stains & tannin stains from fallen leaves
✔ Improves stain adhesion & enhances stain longevity
✔ Eco-safe & easy to apply
📏 Coverage: 750-1,000 sq. ft. per container.
🔹 Where to Use the TWP 100 Stain & Restore-A-Deck Stripper & Brightener Kit?
✔ Wood Decks & Railings
✔ Fences & Pergolas
✔ Siding & Log Homes
✔ Outdoor Furniture & Playsets
📌 Perfect for any exterior wood that needs previous coatings removed before applying a fresh finish.
🔹 How to Use the TWP 100 Stain & Prep Combo Kit
Step 1: Strip the Wood with Restore-A-Deck Stain Stripper
1️⃣ Mix the Stripper: Each container makes 5 gallons.
2️⃣ Apply Using a Pump Sprayer or Brush: Fully saturate the wood surface.
3️⃣ Let Sit for 15-20 Minutes: Stripper will begin breaking down old coatings.
4️⃣ Scrub or Pressure Wash Off: Rinse thoroughly with a garden hose or pressure washer.
Step 2: Brighten the Wood with Restore-A-Deck Brightener
5️⃣ Mix the Brightener: Each container makes 5 gallons.
6️⃣ Apply Using a Pump Sprayer or Brush: Fully saturate the surface.
7️⃣ Let Sit for 10-15 Minutes: Neutralizes the stripper and restores wood pH balance.
Step 3: Apply TWP 100 Pro-Series Stain
9️⃣ Ensure Surface is Ready: Wood must be completely dry before staining (24-48 hours after cleaning).
🔟 Apply Stain Using Brush, Roller, or Pump Sprayer: Work wet-on-wet for even absorption.
1️⃣1️⃣ Back-Brush or Use a Stain Pad: Ensures even penetration & smooth finish.
1️⃣2️⃣ Let Dry Completely: Allow 24-48 hours before heavy foot traffic.
📌 For best results, apply TWP stain when temperatures are between 50°F-90°F.
✔ Get Professional-Quality Results with the TWP 100 Stain & Prep Kit!
✔ Strip, brighten, & stain your wood for maximum protection!
✔ Removes old coatings & penetrates deep into wood fibers for long-lasting results!
✔ Eco-friendly, easy to use, and works on multiple wood surfaces!
🔹 Order the TWP 100 Pro-Series Stain & Restore-A-Deck Stripper & Brightener Kit today and keep your deck or exterior wood looking beautiful for years!
Technical Specifications – TWP 100 Wood Stain
Coverage: 150–250 sq. ft. per gallon, per coat.
Recommended Coats: 2 Coats (Wet-on-Wet Application)
Dry Time: 4 to 24 Hours
This kit saved my deck! The Stripper was easy to mix and worked fast — it removed my old, failing stain without too much scrubbing. It really loosened everything up, and with a quick pressure wash, the wood was clean again.
The Brightener was the perfect follow-up. It neutralized the stripper and really brought the wood back to life, making it look fresh and ready for staining.
Overall — super easy, very effective, and a must-have if you’re removing old coatings. Prepped my deck perfectly for a new TWP stain!
