TWP® 1500 Series Stain – 1 Gallon
Premium Oil-Based, Semi-Transparent Wood Stain & Preservative
TWP® 1500 Series is a high-performance, EPA-registered wood preservative that enhances and protects exterior wood surfaces while allowing the natural beauty of the wood grain to show through. This low-VOC, oil-based stain is compliant in all 50 states and outperforms the previous TWP® 500 series formula by offering improved penetration, faster drying time, and increased durability.
🔹 Key Benefits of TWP® 1500 Series Stain
✔ Preserves Natural Wood Color – Protects against graying and fading
✔ Deep Penetration for Long-Lasting Protection – Conditions and strengthens wood fibers
✔ Water-Repellent – Reduces warping, cracking, and splitting
✔ EPA-Registered Wood Preservative – Prevents structural damage and wood decay
✔ Mildew & Mold Resistant – Keeps wood fresh and clean
✔ Superior UV Absorption – Prevents sun damage and discoloration
✔ Easy Application & Maintenance – Clean and recoat as needed
✔ Low 250 VOC Formula – Safe for use in all 50 states
🔹 Where to Use TWP® 1500 Series Stain?
✔ Wood Decking & Railings
✔ Fences & Gates
✔ Log Homes & Wood Siding
✔ Hardwoods & Softwoods
✔ Outdoor Furniture & Gazebos
✔ Roofing & Shingles
📌 Ideal for all above-ground exterior wood applications!
🔹 Why Choose TWP® 1500 Series?
✅ Penetrating Semi-Transparent Formula – Enhances wood’s natural beauty while providing unmatched protection.
✅ Resistant to Water & Freeze Damage – Prevents water absorption that leads to warping and cracking.
✅ Prevents Mold & Mildew Growth – Keeps surfaces clean and free from organic staining.
✅ Complies with All VOC Regulations – Low 250 VOC formula for safe use in all 50 states.
✅ No Peeling or Flaking – Allows wood to breathe naturally, reducing surface film buildup.
🔹 Application & Coverage
✔ Prep the Surface – Clean and brighten wood before staining for best absorption.
✔ Apply with Brush, Roller, or Sprayer – Work stain into the wood grain.
✔ Back-Brush for Even Penetration – Avoid puddling for a smooth, even finish.
✔ Allow Proper Dry Time – Typically 24-48 hours before foot traffic.
📌 Coverage: 100-300 sq. ft. per gallon, depending on wood porosity and surface texture.
Technical Specifications – TWP 1500 Wood Stain
Coverage: 100–300 sq. ft. per gallon, per coat.
Recommended Coats: 2 Coats (Wet-on-Wet Application). *1 coat for new wood less than 12 months.
Application Methods: Stain Pad, Sprayer, Brush
Dry Time: 4 to 24 Hours
✔ Protect & Beautify Your Exterior Wood with TWP® 1500 Series!
🔹 Available in 1-Gallon & 5-Gallon Sizes
🔹 Professional-Grade Stain for Homeowners & Contractors
🔹 Enhance & Preserve Your Investment for Years to Come!
✔ Order TWP® 1500 Series Today and Keep Your Wood Looking Its Best!
TWP Natural Effect Top Coat 5 Gallon - Step 2
