TWP 1500 Series Stain & Gemini Restore-A-Deck Kit – Complete Wood Restoration Solution
Clean, Brighten & Stain for Maximum Protection & Longevity
The TWP 1500 Series Stain & Gemini Restore-A-Deck Kit provides everything you need to prep, clean, brighten, and stain your wood deck, fence, siding, or log home in one convenient package. This eco-friendly, two-part system ensures your wood is properly prepared before staining, leading to longer-lasting protection and enhanced wood beauty.
✔ (1) TWP 1500 Series 5-Gallon Pail – Premium Semi-Transparent Oil-Based Stain & Sealer
✔ (1) Gemini Restore-A-Deck Kit – Includes Cleaner & Brightener for Maximum Prep
🏆 #1 Rated Wood Restoration System – Trusted by professionals & homeowners
🌿 Eco-Safe, Low VOC, & Easy to Apply – Ensures a hassle-free wood restoration process
🛡 Deep Penetrating Protection Against Water & UV Damage – Extends the life of your wood
🔹 Why Choose the TWP 1500 Stain & Restore-A-Deck Combo Kit?
✅ Cleans & Prepares Wood Before Staining – Removes dirt, mold, algae, & graying
✅ Restores Natural Wood Color – Neutralizes and brightens for better stain absorption
✅ Deep Penetrating Semi-Transparent Oil-Based Stain – Protects against water, UV damage, & mold
✅ Superior Weather Resistance – Prevents warping, cracking, & fading
✅ Works on All Exterior Wood Surfaces – Decks, fences, siding, log homes, outdoor furniture
✅ Easy Application & Maintenance – Professional results with minimal effort
📌 TWP 1500 Series is VOC-compliant in all 50 states.
🔹 What’s Included in the TWP 1500 Stain & Gemini Restore-A-Deck Kit?
(5 Gallons) TWP 1500 Series Stain – Deep Penetrating, Long-Lasting Protection
✔ Premium oil-based stain & sealer for superior longevity
✔ Preserves natural wood color while preventing graying
✔ Repels water & resists mildew and mold growth
✔ Prevents cracking, splitting, & freeze damage in colder climates
✔ Enhances wood tones & protects against UV exposure
📏 Coverage: 150-250 sq. ft. per gallon (varies by wood porosity).
Technical Specifications – TWP 1500 Wood Stain
Coverage: 100–300 sq. ft. per gallon, per coat.
Recommended Coats: 2 Coats (Wet-on-Wet Application). *1 coat for new wood less than 12 months.
Application Methods: Stain Pad, Sprayer, Brush
Dry Time: 4 to 24 Hours
Available in 9 Stunning Colors:
🎨 1501 Cedartone – Classic natural cedar finish
🎨 1502 Redwood – Rich, warm redwood tone
🎨 1503 Dark Oak – Deep, timeless wood stain
🎨 1504 Black Walnut – Bold & modern dark finish
🎨 1505 Honeytone – Light golden hue
🎨 1506 Rustic – Medium brown with warm tones
🎨 1507 Natural – Transparent with minimal tint
🎨 1508 Pecan – Reddish-brown hue with warm undertones
🎨 1511 California Redwood – Vibrant redwood color
Step 1: Gemini Restore-A-Deck Wood Cleaner
✔ Removes dirt, grime, mold, mildew, & weathered graying
✔ Eco-safe, biodegradable formula – safe for plants & pets
✔ Prepares wood for better stain penetration & adhesion
✔ Works on both oil-based & water-based stains
📏 Coverage: 750-1,000 sq. ft. per container.
🚫 Not designed to remove solid color stains or thick coatings.
✔ For those coatings, use the Restore-A-Deck Paint & Solid Stain Stripper.
Step 2: Gemini Restore-A-Deck Wood Brightener
✔ Neutralizes the wood cleaner & restores natural wood color
✔ Removes rust stains & tannin stains from fallen leaves
✔ Improves stain adhesion & enhances stain longevity
✔ Eco-safe & easy to apply
🔹 Where to Use the TWP 1500 Stain & Gemini Restore-A-Deck Kit?
✔ Wood Decks & Railings
✔ Fences & Pergolas
✔ Siding & Log Homes
✔ Outdoor Furniture & Playsets
📌 Perfect for any exterior wood that needs to be properly prepped before applying a fresh finish.
🔹 How to Use the TWP 1500 Stain & Prep Combo Kit
Step 1: Clean the Wood with Gemini Restore-A-Deck Cleaner
1️⃣ Mix the Cleaner: Each container makes 5 gallons.
2️⃣ Apply Using a Pump Sprayer or Brush: Fully saturate the wood surface.
3️⃣ Let Sit for 15-20 Minutes: Cleaner will break down dirt, mold, & old coatings.
4️⃣ Scrub or Pressure Wash Off: Rinse thoroughly with a garden hose or pressure washer.
Step 2: Brighten the Wood with Gemini Restore-A-Deck Brightener
5️⃣ Mix the Brightener: Each container makes 5 gallons.
6️⃣ Apply Using a Pump Sprayer or Brush: Fully saturate the surface.
7️⃣ Let Sit for 10-15 Minutes: Neutralizes the cleaner and restores wood pH balance.
Step 3: Apply TWP 1500 Series Stain
9️⃣ Ensure Surface is Ready: Wood must be completely dry before staining (24-48 hours after cleaning).
🔟 Apply Stain Using Brush, Roller, or Pump Sprayer: Work wet-on-wet for even absorption.
1️⃣1️⃣ Back-Brush or Use a Stain Pad: Ensures even penetration & smooth finish.
1️⃣2️⃣ Let Dry Completely: Allow 24-48 hours before heavy foot traffic.
📌 For best results, apply TWP stain when temperatures are between 50°F-90°F.
✔ Get Professional-Quality Results with the TWP 1500 Stain & Prep Kit!
✔ Clean, brighten, and stain your wood for long-lasting protection!
✔ Removes dirt, mildew, algae, and prepares wood for superior stain adhesion!
✔ Eco-friendly, easy to use, and works on multiple wood surfaces!
🔹 Order the TWP 1500 Series Stain & Gemini Restore-A-Deck Kit today and keep your deck or exterior wood looking beautiful for years!
TWP Natural Effect Top Coat 1 Gallon - Step 2
