This post was updated on March 17, 2026
Hi, I am Scott Paul, a leading exterior restoration contractor and business owner with over 30 years of experience in exterior wood decking. My Best Deck Stain reviews and help tips are based on my history as a wood restoration contractor and actual hands-on testing, all designed to present you with the top deck stain choices. See here for more info about me.
Elevate Your Deck with the Best Wood Stains & Sealers
Whether preparing for a DIY deck-staining project or looking for the perfect stain to share with your contractor, I’ve got you covered. I have rounded up the eight best deck stains available in 2026, including oil-based stains, water-based stains, and semi-transparent and solid options.
Scott’s Expert Guide to Choosing the Best Deck Stains
Questions About Which Deck Stain or Sealer to Use?
Want personalized help? Post your questions below in the comments, and I’ll gladly guide you toward the best deck stain and sealer. Please include any pictures you may have and a brief history of the deck.
Over 30,000 Q&A Comments Below on this article. Ask Below, I Love to Help!
My Recommended Best Deck Stains and Sealers at a Glance
Click on the link and jump straight to the review:
- Top-Rated Deck Stain: TWP 100 Pro Series Stain Review — This deep-penetrating, long-lasting, semi-transparent stain is oil-based, easy to apply, and withstands the elements for up to 3 years.
- Recommended Semi-Transparent: Restore-A-Deck Semi-Transparent Wood Stain Review — Restore-A-Deck’s UV-resistant, semi-transparent stain can be applied to damp wood, which means we can prep your deck and apply the stain in one day.
- Leading Semi-Solid: TWP® Semi-Solid Pro-Series
- Oil-Based: TWP 100 Pro Series Semi-Transparent
- Best Water-Based: Restore-A-Deck semi-transparent deck stain
- Recommended Solid Color: Restore-A-Deck Solid Color Wood & Deck Stain
- Best-Applying: Armstrong-Clark Wood Stain — This long-time favorite is a hard-working, deep-penetrating option that goes on easily and allows for simple maintenance.
- Excellent Semi-Solid Wood: TWP Pro Series Semi-Solid Stain — TWP’s semi-solid stain goes on quickly, holds color well, and offers maximum UV protection and a variety of color palettes to choose from.
- Outstanding Wood Preservative Deck Stain: TWP 1500 Series Semi-Transparent Stain — TWP’s 1500 Series consistently ranks as one of my top options for deck stains, thanks to its deep-penetrating formula, UV- and mold-resistant properties, and long-lasting color.
- Recommended for Mildew: Defy Extreme Semi-Transparent Wood Stain — Defy’s water-based Extreme Wood Stain offers rich, penetrating color and an infusion of zinc oxide Nano-particles that prevent damage from UV rays, mold, and mildew.
- Best Deck-Resurface Coating: Gulf Synthetics Deck Revive
Steps to Picking the Perfect Deck Stain for Your Needs
Is There a #1 Rated Best Deck Stain or Sealer?
Transparent Stains
As the name suggests, transparent stains are clear or very lightly tinted stains that help seal and protect wooden decks while still allowing the wood grain to show through.
Semi-Transparent Stains
Solid (opaque) Stains
2. Long-Term Durability
3. Deck Condition
4. Climate Concerns
Common Deck Staining Mistakes and How to Avoid Them
- Not preparing your deck: Failing to clean your deck or remove old, flaking, or peeling stain from your boards can prevent a fresh coat of stain from adhering properly.
- Over-applying stain: You may think more stain equals more protection from moisture, mildew, and sun damage, but that’s not always the case. Too much stain can prevent the product from penetrating your deck boards. As a result, it may form a film on top of the wood that peels or flakes off over time.
From: $41.99 | From: $47.99* | From: $65.99* | From: $69.95* |
*Free Shipping Included
- Ease of application
- Wear and tear after 2 years
1. TWP 100 Series
2. Armstrong Clark Wood Stain
3. TWP 1500 Series
4. TWP Pro-Series Semi-Solid
5. Ready Seal Wood Stain
3. Defy Extreme Stain
- Scott’s Pro Tip: My most used deck stain in the past 30 years! We have used the TWP 100 Series on many 1000s of decks.
My Test Deck Stats
Deck Square Footage: 2100
Consumer Star Ratings:
- Scott’s Pro Tip: My favorite deck stain to save time and money. We prep and stain on the same day.
My Test Deck Stats
UV Exposure: 50% Full Sun
- Scott’s Pro Tip: Regarding ease of application and performance, the Armstrong Clark stain is one of my top stains. We love their semi-solid colors and performance.
My Test Deck Stats
Deck Square Footage: 600
- Scott’s Pro Tip: My favorite penetrating semi-solid wood and deck stain soaks into the wood and provides excellent UV protection.
My Test Deck Stats
When Tested: August 2020
Deck Square Footage: 800
UV Exposure: Deck in full sun
- Scott’s Pro Tip: My favorite current penetrating semi-transparent oil-based stain is the TWP 1500 Series. Michigan switched to low-VOC, so I now use it on the majority of decks that I restore.
My Test Deck Stats
Deck Wood Type: Cedar
Deck Square Footage: 400
- Scott’s Pro Tip: My new favorite IPE and Hardwood Deck stain is the first stain I have ever seen last more than one year on exotic hardwoods.
My Test Deck Stats
Stain Color Used: Chesnut
- Scott’s Pro Tip: The Defy Extremes is one of my top choices when using a water-based semi-transparent wood stain.
My Test Deck Stats
Stain Color Used: Cedartone
- Scott’s Pro Tip: Ready Seal Stain is not my favorite since it requires annual recoating, but I do like that it applies easily. Ready Seal does not cure fully and can rub off the wood on clothing.
My Test Deck Stats
Scott’s Pro Tips: Although CUTEK® Extreme is more expensive than many penetrating oils, the performance was very solid. There was no peeling or significant wear, and the coating should be easy to maintain, as it fades naturally and can be refreshed without stripping.
My Test Deck Stats
Deck Square Footage: 1000
How Many Years Tested: 1 Year
Stain Color Used: Walnut
Semi-Solid Deck Stain Review
- Consumer Star Ratings:
Deck Stain Facts: Frequently Sought Answers
When helping people choose the best deck stain and sealer, I often hear many of the same questions. Here are some facts and words of advice about exterior wood stain that can help answer these questions:
What is a deck stain?
Deck stain is a type of finish applied to the wooden boards of your deck. Generally speaking, deck stains come in three types —transparent, semi-transparent, and opaque —and are available in a wide range of colors to suit your taste.
Answer: The deck stain must be tinted to protect it from UV graying. I prefer semi-transparent stains, as they do not mask or cover the wood but highlight the grain while providing UV protection.
Answer: My favorite deck stains have been penetrating semi-transparent and semi-solid stains. These stain types allow the wood grain to show, and if they truly soak into the wood grain, reapplying is easier down the road.
What deck stain types can be cleaned and recoated as needed?
Answer: Penetrating deck stains are not prone to peeling, and we can clean and reapply them as needed. Deck stains that dry or film on top of the wood are much harder to maintain and prep when reapplying.
Answer: Absolutely! Deck stains are wood stains and work very well for wood fences, vertical wood siding, and log cabins. They last even 2-3 times longer on vertical wood.
The waiting period before staining a new deck can depend on the material used to build it. Take a closer look at our recommended time frames based on deck material:
- New, smooth wood decks: Wait at least 3 months before applying stain.
- Rough-hewn wood decks: No wait time is needed; you can apply stain as soon as the wood is clean and dry.
- Kiln-dried or KDAT wood decks: Wait 1-2 months before applying stain.
For more information, check out this guide on how long to wait before applying stain to your deck.
The most popular deck stain colors of 2026 include:
- Cedar tones
- Brown tones
- Honey tones
- Redwood tones
The best way to apply a deck stain can vary based on the product used, but my personal favorite applicators include flooring brushes and stain pads. Learn more in this guide to the best deck stain applicators.
What’s the difference between a deck stain and deck paint?
Deck stain and deck paint are similar in that they add color to a wooden deck. However, deck stain typically penetrates into the fibers of wooden deck boards and often results in a more natural final product. On the other hand, deck paint is typically thicker and creates an opaque layer of color over the wood.
What’s the difference between water- and oil-based deck stain?
Both water- and oil-based deck stains can provide rich color and long-lasting protection against moisture and UV damage. However, there are some differences between the two stains.
For instance, oil-based stains may offer advanced protection against warping or cracking and last longer than water-based stains. However, water-based stains are generally more environmentally friendly and easier to apply and clean up. Many water-based stains also feature additives to prevent fungal damage or wood rot. Learn more in this guide to the differences between water—and oil-based stains.
The 3 best deck stain brands for decks in full sun are TWP, Restore-A-Deck, and Armstrong Clark. The TWP 100 Pro Series semi-transparent penetrating deck stains in darker tints are best for most decks. TWP also has a semi-solid penetrating deck stain that works well in full sun. Restore-A-Deck has semi-transparent and solid deck stains for full sun. Armstrong Clark is a high-quality oil based deck stain.
Additional Deck Stain Rating Questions
If you have questions on this review of deck stains, please ask me below in the comments.
Want My Help Finding a Deck Stain?
- Deck Location: Michigan
- Wood Type: Cedar
- Mold/Mildew?No
- TWP 1500 Series
- Armstrong-Clark Deck and Wood Stain
- Restore-A-Deck Wood Stain
- Defy Extreme Wood Stain
I am here to help you find the best wood deck stain for your situation! Just post a comment below with answers to these questions.
Do you know a product that can remove factory inkstamp marks on pressure- treated pine deck boards and discoloration mark from small area rug? The deck has not been stained and is one year old
https://www.deckstainhelp.com/how-to-remove-the-ink-stamps-from-new-decking/
Hi, we live in Nova Scotia, Canada about 1,000 yards from the ocean. Winters are cold, summers are hot, all seasons are windy. Our deck is south facing so we get a lot of sun. The deck was here when we bought the house so, I am guessing it was made of pressure treated pine but really don’t know. I don’t think the deck has ever been treated so there are some cracks developing. What would you recommend for a semi transparent stain to restore and preserve the deck?
Clean and brighten the wood for prep. Use TWP 200 Series or Armstrong Clark Stains for Canada.
Located in Colorado mtns. New pine railings and cedar gazebo. Transparent or semitransparen? I want to see some grain. Oil or Water base? Could I get a couple of recommendations?
See this for new wood and the best options: https://www.deckstainhelp.com/how-long-should-you-wait-to-stain-a-new-deck/
Thanks, Scott. The Woodscapes Acrylic product they propose, for which I don’t find any reviews, is water-based, and my previous Cabot SPF24 was also water-based. They plan to hand sand or power spray the planks before application. Do I need to stick to a water-based product or am I better off getting an oil-based product that would give better penetration? Thanks.
You can only switch to an oil-based if you fully remove the current SPF24. Also, no one makes oil-based solid stains anymore.
Hello Scott
Great site based on real world experience.
We are building a new home in Western Washington state with Doug Fir Timbers and vertical Cedar channel siding.
1) What is your recommendation for first treatment? TWP 100 Pro Series or something else? We have had good luck with TWP on log rail fences in the past.
2) If TWP how long should we wait to apply it?
3) How does TWP100 compare to Outlast Q8 Log Oil?
1. TWP would be an excellent option.
2. See this for new wood. It will apply to siding as well: https://www.deckstainhelp.com/how-long-should-you-wait-to-stain-a-new-deck/
3. We have never used the Outlast so not sure.
Student Painters came around and gave me a quote on re-staining my rough cut pine barn that I last stained myself at age 60 when it was new 15 years ago, using Cabot SPF 24, a blond UV protecting deck and fence stain. The students say they only use Sherwin Williams and recommend Woodscapes Exterior Acrylic Solid Siding Stain. I estimate the paint cost to be $4-600 and the labor to be $4000 so I want the best product. Is this a good stain for UV protection and prevention of flaking, etc? Thanks
SW does not know how to make deck stains very well. See here for their solid stain review: https://www.deckstainhelp.com/sherwin-williams-superdeck-solid-color-stain-review/
Woodscapes was replaced with the Super Deck label.
As for a quality solid stain, see here:
I live in North Carolina and am looking to do a 2 toned deck protection. Natural to light brown transparent to semi transparent on the surface and solid white for the rails. The deck is 3 years old and has never been protected. It receives morning full sun and it is humid here so there is a small bit of mold/algae. I do not know what type of wood the deck is made of/new builder special guessing pine? I would like a product that is penetrating. Thank you for your help!
Read here for tips: https://www.deckstainhelp.com/why-have-a-two-toned-deck/
I used defy semi transparent stain on my deck floor. We are in Oregon, and our deck gets a few hours of sun a day, otherwise is fairly shady. Some areas get very wet during the rainy season.
Last year I applied the defy, but it was towards the end of the year, it got cold, and it got rainy. I think I was at the end of required temperature for application, and it rained within 2 days off applying. The stain peeled and is wearing away in heavy rain spots. Do you think that I applied it to thick? or do you think the stain didn’t have time to adhere very well d/t the weather? or both?
I am trying again with better weather this spring. My question is do I have to strip and brighten again before re-application since it is peeling in some spots?
Also, I am noticing our nails are turning the deck black around the nail site. My other question is, obviously a solid stain would cover that, but I am hesitant to stain my deck solid since we get so much inclement weather. Advice appreciated 🙂
I still have plenty of semi transparent stain left over, but I would be willing to explore new options. Do you think the defy is good for the type of weather I live in? or would an oil based be better?
Hard to say what went wrong as it could be many things. Improper prep, over-applying, etc. You will need to remove all to fix. How to remove varies on which Defy you sued and the condition it is in now. Pics would help.
Nails turning back is rust. The builder probably used the wrong nail type.
Hello! Last summer I removed the solid stain, cleaned and brightened with RAD then stained with Armstrong/Clark semi transparent oil. After going through the winter some of the higher traffic areas seems to have worn off. Do I clean/brighten then stain again this year? Are both steps necessary? I will be using the same stain. Thank you!
Yes, use both steps. You could do it this year or next year.
Hi, I have a batu hardwood. I have tried ipe oil as well as penofin hardwood stain for the wood and the stain barely lasts a year and fades horribly especially on the horizontal surfaces (decks). My yard has a ton of the batu wood (fencing, decks, etc…). One of the decks is also a pool deck. I’m looking for a new type for this hardwood as the penofin isnt’ working great. I really want that Brazilian hardwood color to stay and it fades pretty badly. Any suggestions would be greatly appreciated.
Your wood type requires annual recoating, but other brands will last longer than Penogin and Ipe Oil. See here: https://www.deckstainhelp.com/ipe-exotic-hardwood-stain-review/
Is there a truly penetrating semi transparent white stain that you recommend? Don’t want flaking in a few years. We have a small horizontal privacy wall that extends above our deck benches that I would prefer be a distinctly different color from the rest of the deck which will be a more natural wood color. (Really don’t want gray.) It’s new pressure treated pine that has finished curing. Location: Texas
No, there are not any “white” color penetrating semi-transparent stains. You would need a solid color or semi-solid if you want white.
Just finishing a large wrap around pressure treated pine deck using lumber from Lowes. This deck is located in Virginia.Worked slowly by myself since November of last year. This deck receives alot of sun and it’s very windy most of the year. Trying to determine when this deck should be stained and looking for the best available stain in our local area. Suggestions would be much appreciated. Thank you
Please read this about new wood: https://www.deckstainhelp.com/how-long-should-you-wait-to-stain-a-new-deck/
This is a covered boat dock on fresh water.
In which state is your deck located? Arkansas
How much sun/shade does your deck get? Lots of sun from 12 to 7 pm, Jun to Oct
What type of wood is your deck made of? pressure-treated lumber, aged 9 months
Do you have mold or mildew issues? some mildew on walkway closest to shore
Why/how did the previous stain fail? tried light pressure wash to remove pollen stains (huge problem here in the spring) and took all the stain off
What type of stain did you use last time? professional painter sprayed low-VOC penetrating semi-transparent stain…not sure which brand. (new painter will brush; not spray)
Try the Restore A Deck Wood stains or the TWP Semi-solid stains for the best UV protection.
Hello, we built a brand new pavilion out of wood that we had made from Ash. It has dried over a year and we sanded it. We want to do a semi transparent cedar color. We live in hot sunny SC. It gets sun all day. What’s the best kind for full sun that has less fading, resistant to mildew?
Restore A Deck Stain in Cedar color or TWP 1501 Cedartone.
I’d like your suggestions for a 25 by 40 deck with 15 8 foot wide steps that is 5 years old. Never stained. Faces the South and has full sun all year. Do I power wash, use some type of cleaner, stain. You have a lot of advice but would like to get your suggestions for my situation for prep and stain…Restore A Deck maybe?
Restore A Deck Cleaner and Brightener for prep while pressure washing. For the stain, try the Restore A Deck Stains or the TWP Stains.
Trying to figure out best semi-transparent stain to use on new screen porch. Posts are cedar, the inside of roof will be tongue and groove pine. I think the screen panels will be pressure treated wood. Deck is Trex but want good quality products for the porch.
Is this all brand new wood? If so, see this: https://www.deckstainhelp.com/how-long-should-you-wait-to-stain-a-new-deck/
Try the Restore A Deck Semi-Transparent after wait and prep.
I used behr deck over on my deck and it peeled badly, should I sand the deck and what can I stain it with after
To fix you will need to power sand it all off. Once fully removed, you can use any of the brands on the list above.
I could use some sealer help. I live in Kansas. The deck is partially covered. The uncovered portion has some morning early afternoon sun. This is a hardwood deck. I don’t remember the wood, perhaps acacia? I don’t think it has mold mildew. At least once per year I usually sand the outside portion down and reseal. I use penofin for hardwood. As you can see from pictures it has a lot of dark on the outside portion. Last year it did not even look good just after sealed. Inside portion holds up relatively well and looks fairly good but fades near outside portion. I typically only treat covered portionevery couple years. Thanks for your insight.
You will need to strip and brighten for prep. Use the Restore A Deck Stripper/Brightener kits. After, stain with a hardwood stain. See here for what to use: https://www.deckstainhelp.com/ipe-exotic-hardwood-stain-review/
I am making 4 fairly intricate gates with a Chinese chippendale pattern. They are made from Western Red Cedar and are still raw, freshly milled format. I live in Montana so they will get -20° and snow as well as 98° blazing sun. Looking for a natural toned finish that isn’t crazy on maintenance.
Need help to fix.
We are in Western New York State
Sun most of day in the summer
Pool deck was raw Fur or Spruce when we moved here in 2018
Mildicide was used by company hired to do the work in 2020
Product they used in 2020 was Sikkens Prolux Cedar color.
Flat surfaces peeled up after one winter.
How can we fix this?
Need pictures for prep advice and help. Post in comments.
Well, deck has a lot of snow on it right now. I’ll take photos come Spring.
Okay, just let us know so we can help.
Some snow melted off pool deck today. All the flat surfaces have peeling.
All of the old stain does need to come off and that will require both stripping and sanding to get it all off. Use the Restore A Deck Stripper with both additives to remove as much as possible.
Sand the rest off. Brighen all when done. Stain with a penetrating stain after:
Stain/sealer suggestion would be much appreciated!
Charleston, South Carolina
Lots of Sun (think that’s why the last stain faded (greyed)
Pine fence
Have washed off mold/mildew, planning to apply a brightener prior to staining
No prior stain used
Kindly,
-wk
Try Restore A Deck Stain in semi-transparent or TWP Semi-Solid Stain colors.
Thank you for the speedy reply and helpful information!
I live in Birmingham, Alabama and have a newly installed wooden fence. Fence is made of pressure treated pine. Treated fence with a mildewcide as recommended by fence contractor. I would like to stain and seal the fence with a water base transparent stain and sealer combination. Fence has been installed less than a month and was treated with mildewcide about 2 weeks ago. What product do you suggest.
Look at the Restore A Deck Wood stains for this.
Best stain recommendtion for Cedar Backyard Fence, Phoenix, AZ full sun and heat with partial shade. No mold or mildew some water lines from prior irrigation. Fail – fading, peeling and shows previous water line – Thompsons Water Seal Color Acorn. I would also like to use my newely purchased Wagner Spray gun to complete. Do all stains requiring prepping or sanding on existing fence and if not which would you recommend? Thank you
You will need to remove the old stain first. Reply back with pics for prep help. Once prepped, try Restore A Deck Stains or Armstrong Clark Wood Stains.
We are building a new cabin with a deck. This cabin will be near water, but in the woods. What would be the best stain for protection and maintenance. It will be situated in Oklahoma and it will be built with the deck facing North East. It will be built with pressure treated pine wood. What stain will you recommend?
See here for new wood tips: https://www.deckstainhelp.com/wp-admin/post.php?post=15465&action=edit
do you have a phone number I can call? Do you ship to hawaii or have a dealer here in hawaii?
This website does not ship products.
Scott have you ever used a ceiling drywall sander to sand decks?
If just some splinters you are removing, then yes it will work.
have you every used deck restoration penetrating stain. how does it compare to restore a deck penetrating stain?
Not sure what you mean. Most of the stains we use for deck restoration are penetrating stains.
Can you email me why you removed my added comments? are you paid by the brands you review and write about?
Your review was not approved as it strongly sounded like a paid endorsement or a direct-from-manufacture review. We do not allow these.
As for who we are, that is explained on the very first page and the very first article. We are not paid by anyone.
Im in florida with a deck wide open to the elements, lots of rain and sun. New deck built about 4-5 mo ago. Ive been told water-based is the way to go by a deck stain company. Any reccomendations on which product to use?
Id you want a water-based stain, then you would want Restore A Deck Stains or Defy Stains. Make sure to prep with a deck cleaner and a wood brightener.
Im trying to hire someone to do this work. I will have them use one of these products. A couple companies insist they should sand the wood to get best results and longevity. Another one says they wouldn’t sand. Is sanding OK, good idea, bad idea?
https://www.deckstainhelp.com/why-sanding-a-deck-can-be-an-issue/
I live in central Florida. The dock is on the lake which receives direct sunlight during the day. I previously used Sherwin Williams semi transparent deck stain, water based. The wood is yella treated wood. The wood chipped and was mildew. I applied this stain app. 2 years ago. I’m looking for a better stain.
Post some pics for prep help. Once the old stain is removed, try the Restore A Deck Stains or TWP 100 Series.
I live in Houston and I’m looking for the best product to seal new cedar posts that I just installed for my outdoor patio. I’d like to start with something as transparent as possible to preserve the natural look of the cedar. I’m considering pure tung oil as a starting point. Thoughts? I saw
Tung oil is useless as it will not give any UV protection from graying or mildew. Need a tinted stain: https://www.deckstainhelp.com/will-a-clear-sealer-prevent-graying-on-deck/
Hi Love this website! I’m switching from Penofin to Restore a Deck for a wood door on a covered porch. I plan to use a cleaner and brightener before the Restore a Deck application. I have Penofin brand cleaner and brightener on hand already– would it be ok to use them and then apply Restore a Deck, or is there some reason I would need to get Restore a Deck brand cleaner and brightener before using their stain?
You need to fully remove the Penofin first so that may require a stripper. Please post a picture.
Two pctures of door
Yes, you definitely have to use a stripper and then a brightener. Use the RAD prep products.
Hi – looking to stain new cedar tongue and groove siding in a black or charcoal. The house is in east Tennessee. Thinking the TWP charcoal, but what about the seal-once products? Thanks!
We tried Seal Once a couple of years ago and did not like it at all. Does not apply well and it did not last very long. Peeled.
Hi, looking for a stain recommendation.
I’m in Pennsylvania (but within very easy driving distance of West Virginia if there’s something I can buy there but not here).
I have a covered porch that gets some sun, maybe half of sun up hours, but not much direct sun.
The floor is locust t&g that I had custom cut. Has been installed for about 6 months.
This flooring is new, as it replaced a rough painted porch. As such, I don’t really have a good history, but I definitely want to avoid mildew. I also want to avoid solid, and dark colors and maintain a natural look. Definitely want to stay translucent or semi.
I have run samples of Permachink Deck Defense (too orange even for their lightest deck formula), PPG proluxe natural (very strong brown color for a “natural”, I kind of wonder about their Rye color but no current access to it or anything lighter at all), and Cabot timber oil natural (liked this color by far the best, but didn’t like the iffy reviews on that product here on your site).
So if I don’t sound entirely too picky, hit me with a suggestion!! Thanks.
Nathan
You need a hardwood stain: https://www.deckstainhelp.com/ipe-exotic-hardwood-stain-review/
Best to test some samples from respective brands on above link.
I have a Mahogany porch outside covered porch floor that faces due south I used Mesma stain on before and I have removed it all and I need of a new preservative stain
i love the beauty of the Mahogany natural what would yourrecommend. I live in Massachusetts with cold winters and it gets a lot of wind across it that dries it out quickly too. I would appreciate any help you could recommend.
Loo at Armstrong Clark or Restore A Deck Stains.
Didn’t even notice there was a separate forum! Whoops. Ordered samples of RAD. Hopefully I like their natural. Thanks.
Natural would like a clean wet look.
Hi, I have a 30-year-old wooden swing I’d like to preserve and coat with a semi-transparent stain. Full Florida sun. I know I need to strip it and brighten.
1. Would a AC semi-transparent darker stain, like redwood or darker, or the TWP 1500 series semi-transparent like dark oak, cause color transfer on clothing? I have been happy with AC on my 20-year old deck, but I am leaning towards TWP because it is a wood preservative.
2. What stain would you recommend?
Less chance of the stain rubbing off on clothes with the TWP Stains. Use that.
Hi, Scott! Your website is so helpful. We just bought this home. It has a pressure-treated pine deck that is 1 1/2 years old and has never been stained or sealed. It is covered by the roof, but exposed on three sides. It is located in Georgia, facing south, with 7-9 hours of direct sun. Some of the rails and horizontal surfaces have started graying and there is some spotty mildew. My husband is replacing some of the cap rails bc they were warping. He thinks semi-transparent, oil-based stain is the most protective and long-lasting. He wants to apply it with his paint sprayer. What do you recommend? Thank you so much!
For prep, use a deck cleaner and then a wood brightener. For the stain, try TWP 100 Series or Armstrong Clark Stains. No need to spray as this will be messy being it is up in the air, etc.
Thank you so much for that great advice. We will buy those products. Our neighbor suggested adding a pesticide like NBS 30 or CPF-2D to an oil-based stain before applying it to kill/deter carpenter bees from eating the deck. We have a ton of those pesky creatures in Georgia. What do you think about this? Thank you so much for saving the decks of the world!
It does not hurt to add them. We have used the NBS 30 and Bug Juice additives in the past.
I have a 3-year-old deck made of pressure treated pine. I sealed it once just over a year ago with Thompson’s water seal. I need to re-seal or stain it and provide some UV protection.
For prep, remove the Thompsons with the Restore A Deck Stripper/Brightener Kit. Stain with the Restore A Deck Stain or the TWP 100 Series.
I have a new western Cedar 3 rail fence i would love to keep its red color and keep it from graying. i but have seen some stains that look painted not natural
Use a semi-transparent stain like TWP 1500 Series or Restore A Deck Wood Stains. They will enhance the grain of the wood but it will not look painted.
Hi Scott. Really appreciate the informative website you’ve created.
I have a new pressure treated pine fence that was installed 2 months ago. It’s 6′ x 300′ so total of 3,600 sq ft. I initially was looking at PPG Proluxe SRD due to word of mouth reputation but it seems like the formula was changed a few years ago and it’s not as good of a product anymore.
Other options I’m considering are based on your website: Defy Extreme, RAD stain, and TWP 100. Looking for semi-transparent in all brands. I live in NC and a good portion of the fence receives 4-6 hours of shade a day.
My primary criteria are: ease of application, color durability/length of time between maintenance coats, mildew resistance, and price. Do you recommend any of these three options over another? Are there other brands I should consider?
Thanks in advance.
Where are you located?
I’m in central North Carolina
Try Restore A Deck if you want water-based or TWP 100 Series if you prefer oil-based.
Thank you, Scott. Any performance advantages to oil vs water based?
Not really as they are both excellent but read this for tips: https://www.deckstainhelp.com/water-based-vs-oil-based-deck-stains/
Could either of these products be applied now (2 month old fence) or does the wood need to age a few more months?
Smooth wood or rough cut? If smooth, wait until Spring to prep and stain: https://www.deckstainhelp.com/how-long-should-you-wait-to-stain-a-new-deck/
I just bought a house with a 17 year old deck which was stained at some point with a semi solid but wasn’t maintained. After reading reviews I wanted to buy TWP semi solid, but unfortunately I can’t afford it as their deck stain calculator indicates that I’d need 15 gallons since my deck surface alone is 1200 sq feet! A local guy who does deck restoration swears by Shark Skin semi solid by Cloverdale which is sold by Redda here in Oregon. It’s primarily sold in Canada and the western US (OR, WA, CA, MT, ID, & AK) so you might not have heard of it, but I wanted to ask your opinion…
Thanks in advance!
Sorry but never used it or heard of it. You do have to remove the old semi-solid coating before using the TWP or any other brand of stain.
I have a 6 month old redwood fence in Sacramento, CA. I’m looking for a dark gray or black color that will still show some natural wood grains
Try Black Walnut in the TWP 1500 Series from TWPstain.com
Just moved to North Carolina from Colorado and wanted to know the best light gray transparent stain for a high humid environment?
Try TWP Semi-solid stain or Armstrong Clark in Driftwood gray.
Just put clear sealant on my deck in Michigan. It rained 18hrs later, was not suppose to. Unfortunately deck did not bead up what do I do now. This has not happen before.
Rain will not wash away a sealer after 18 hours so there is most likely something wrong with the sealer you used or how it was applied. BTW, clear sealers are essentially useless. You need a semi-transparent stain.
I’ve got a brand new pine deck and the most important thing to me is choosing a sealant that will make the wood last as long as possible. I am not as interested in a stain or color. What product penetrates the wood the best? Thank you.
Clear = zero UV protection from graying: https://www.deckstainhelp.com/will-a-clear-sealer-prevent-graying-on-deck/
Also, see here about new wood as you cannot stain or seal it yet: https://www.deckstainhelp.com/how-long-should-you-wait-to-stain-a-new-deck/
Thank you for the quick response. Ok, yeah, I will use at least a semi-transparent deck stain. That being said, what product penetrates the deepest?
Look at the TWP Stains or Armstrong Clark Stains.
I want to stain my cedar mailbox post. It’s a year old.. it has begun to weather, but not too much. I bought TWP total wood protectant TWP pro-series cedar tone. I sanded my post lightly in a few areas. How many coats should I use, and how much time do I wait between coats?
Make sure to clean and brighten for prep. Apply 2 coats wet on wet.
Hi! We have a new pressure treated pine outdoor shower in St. Petersburg FL we are looking to stain. Any ideas on what we should use would be appreciated!
Use Restore A Deck Stains or TWP 100 Series after proper weathering and prep. See here about new wood: https://www.deckstainhelp.com/how-long-should-you-wait-to-stain-a-new-deck/
thank you!!
Hi, just finished half of my deck, done in cedar. (see attached pic) Its been done in stages but the majority has been done for over a month. I live near Chicago and want to clean and stain before the winter hits. Would like to keep the color close to its natural cedar state. Suggestions? Size is 18 x 12 feet at its widest
Stain and prep in the Spring. See here: https://www.deckstainhelp.com/how-long-should-you-wait-to-stain-a-new-deck/
You cannot do it now.
My connection dropped before I could post a picture, and now I can’t find the post. Sorry for the trouble. Awaiting the email and then I will post a picture.
Live in North Carolina and have a deck that was previously coated with Olympic Maximum. I have pressure washed and replaced some of the boards in the deck. Looking for suggestion about what to put on now. Was planning to use a big box store resurfacer until I saw your reviews. Your expertise would be greatly appreciated.
You have a solid stain on there no so you will need a solid stain again: https://www.deckstainhelp.com/what-are-the-best-solid-color-deck-stains/
See this for prep: https://www.deckstainhelp.com/how-to-reapply-a-solid-color-deck-stain/
