This post was updated on March 17, 2026
Hi, I am Scott Paul, a leading exterior restoration contractor and business owner with over 30 years of experience in exterior wood decking. My Best Deck Stain reviews and help tips are based on my history as a wood restoration contractor and actual hands-on testing, all designed to present you with the top deck stain choices. See here for more info about me.
Elevate Your Deck with the Best Wood Stains & Sealers
Whether preparing for a DIY deck-staining project or looking for the perfect stain to share with your contractor, I’ve got you covered. I have rounded up the eight best deck stains available in 2026, including oil-based stains, water-based stains, and semi-transparent and solid options.
Scott’s Expert Guide to Choosing the Best Deck Stains
Questions About Which Deck Stain or Sealer to Use?
Want personalized help? Post your questions below in the comments, and I’ll gladly guide you toward the best deck stain and sealer. Please include any pictures you may have and a brief history of the deck.
Over 30,000 Q&A Comments Below on this article. Ask Below, I Love to Help!
My Recommended Best Deck Stains and Sealers at a Glance
Click on the link and jump straight to the review:
- Top-Rated Deck Stain: TWP 100 Pro Series Stain Review — This deep-penetrating, long-lasting, semi-transparent stain is oil-based, easy to apply, and withstands the elements for up to 3 years.
- Recommended Semi-Transparent: Restore-A-Deck Semi-Transparent Wood Stain Review — Restore-A-Deck’s UV-resistant, semi-transparent stain can be applied to damp wood, which means we can prep your deck and apply the stain in one day.
- Leading Semi-Solid: TWP® Semi-Solid Pro-Series
- Oil-Based: TWP 100 Pro Series Semi-Transparent
- Best Water-Based: Restore-A-Deck semi-transparent deck stain
- Recommended Solid Color: Restore-A-Deck Solid Color Wood & Deck Stain
- Best-Applying: Armstrong-Clark Wood Stain — This long-time favorite is a hard-working, deep-penetrating option that goes on easily and allows for simple maintenance.
- Excellent Semi-Solid Wood: TWP Pro Series Semi-Solid Stain — TWP’s semi-solid stain goes on quickly, holds color well, and offers maximum UV protection and a variety of color palettes to choose from.
- Outstanding Wood Preservative Deck Stain: TWP 1500 Series Semi-Transparent Stain — TWP’s 1500 Series consistently ranks as one of my top options for deck stains, thanks to its deep-penetrating formula, UV- and mold-resistant properties, and long-lasting color.
- Recommended for Mildew: Defy Extreme Semi-Transparent Wood Stain — Defy’s water-based Extreme Wood Stain offers rich, penetrating color and an infusion of zinc oxide Nano-particles that prevent damage from UV rays, mold, and mildew.
- Best Deck-Resurface Coating: Gulf Synthetics Deck Revive
Steps to Picking the Perfect Deck Stain for Your Needs
Is There a #1 Rated Best Deck Stain or Sealer?
Transparent Stains
As the name suggests, transparent stains are clear or very lightly tinted stains that help seal and protect wooden decks while still allowing the wood grain to show through.
Semi-Transparent Stains
Solid (opaque) Stains
2. Long-Term Durability
3. Deck Condition
4. Climate Concerns
Common Deck Staining Mistakes and How to Avoid Them
- Not preparing your deck: Failing to clean your deck or remove old, flaking, or peeling stain from your boards can prevent a fresh coat of stain from adhering properly.
- Over-applying stain: You may think more stain equals more protection from moisture, mildew, and sun damage, but that’s not always the case. Too much stain can prevent the product from penetrating your deck boards. As a result, it may form a film on top of the wood that peels or flakes off over time.
From: $41.99 | From: $47.99* | From: $65.99* | From: $69.95* |
*Free Shipping Included
- Ease of application
- Wear and tear after 2 years
1. TWP 100 Series
2. Armstrong Clark Wood Stain
3. TWP 1500 Series
4. TWP Pro-Series Semi-Solid
5. Ready Seal Wood Stain
3. Defy Extreme Stain
- Scott’s Pro Tip: My most used deck stain in the past 30 years! We have used the TWP 100 Series on many 1000s of decks.
My Test Deck Stats
Deck Square Footage: 2100
Consumer Star Ratings:
- Scott’s Pro Tip: My favorite deck stain to save time and money. We prep and stain on the same day.
My Test Deck Stats
UV Exposure: 50% Full Sun
- Scott’s Pro Tip: Regarding ease of application and performance, the Armstrong Clark stain is one of my top stains. We love their semi-solid colors and performance.
My Test Deck Stats
Deck Square Footage: 600
- Scott’s Pro Tip: My favorite penetrating semi-solid wood and deck stain soaks into the wood and provides excellent UV protection.
My Test Deck Stats
When Tested: August 2020
Deck Square Footage: 800
UV Exposure: Deck in full sun
- Scott’s Pro Tip: My favorite current penetrating semi-transparent oil-based stain is the TWP 1500 Series. Michigan switched to low-VOC, so I now use it on the majority of decks that I restore.
My Test Deck Stats
Deck Wood Type: Cedar
Deck Square Footage: 400
- Scott’s Pro Tip: My new favorite IPE and Hardwood Deck stain is the first stain I have ever seen last more than one year on exotic hardwoods.
My Test Deck Stats
Stain Color Used: Chesnut
- Scott’s Pro Tip: The Defy Extremes is one of my top choices when using a water-based semi-transparent wood stain.
My Test Deck Stats
Stain Color Used: Cedartone
- Scott’s Pro Tip: Ready Seal Stain is not my favorite since it requires annual recoating, but I do like that it applies easily. Ready Seal does not cure fully and can rub off the wood on clothing.
My Test Deck Stats
Scott’s Pro Tips: Although CUTEK® Extreme is more expensive than many penetrating oils, the performance was very solid. There was no peeling or significant wear, and the coating should be easy to maintain, as it fades naturally and can be refreshed without stripping.
My Test Deck Stats
Deck Square Footage: 1000
How Many Years Tested: 1 Year
Stain Color Used: Walnut
Semi-Solid Deck Stain Review
- Consumer Star Ratings:
Deck Stain Facts: Frequently Sought Answers
When helping people choose the best deck stain and sealer, I often hear many of the same questions. Here are some facts and words of advice about exterior wood stain that can help answer these questions:
What is a deck stain?
Deck stain is a type of finish applied to the wooden boards of your deck. Generally speaking, deck stains come in three types —transparent, semi-transparent, and opaque —and are available in a wide range of colors to suit your taste.
Answer: The deck stain must be tinted to protect it from UV graying. I prefer semi-transparent stains, as they do not mask or cover the wood but highlight the grain while providing UV protection.
Answer: My favorite deck stains have been penetrating semi-transparent and semi-solid stains. These stain types allow the wood grain to show, and if they truly soak into the wood grain, reapplying is easier down the road.
What deck stain types can be cleaned and recoated as needed?
Answer: Penetrating deck stains are not prone to peeling, and we can clean and reapply them as needed. Deck stains that dry or film on top of the wood are much harder to maintain and prep when reapplying.
Answer: Absolutely! Deck stains are wood stains and work very well for wood fences, vertical wood siding, and log cabins. They last even 2-3 times longer on vertical wood.
The waiting period before staining a new deck can depend on the material used to build it. Take a closer look at our recommended time frames based on deck material:
- New, smooth wood decks: Wait at least 3 months before applying stain.
- Rough-hewn wood decks: No wait time is needed; you can apply stain as soon as the wood is clean and dry.
- Kiln-dried or KDAT wood decks: Wait 1-2 months before applying stain.
For more information, check out this guide on how long to wait before applying stain to your deck.
The most popular deck stain colors of 2026 include:
- Cedar tones
- Brown tones
- Honey tones
- Redwood tones
The best way to apply a deck stain can vary based on the product used, but my personal favorite applicators include flooring brushes and stain pads. Learn more in this guide to the best deck stain applicators.
What’s the difference between a deck stain and deck paint?
Deck stain and deck paint are similar in that they add color to a wooden deck. However, deck stain typically penetrates into the fibers of wooden deck boards and often results in a more natural final product. On the other hand, deck paint is typically thicker and creates an opaque layer of color over the wood.
What’s the difference between water- and oil-based deck stain?
Both water- and oil-based deck stains can provide rich color and long-lasting protection against moisture and UV damage. However, there are some differences between the two stains.
For instance, oil-based stains may offer advanced protection against warping or cracking and last longer than water-based stains. However, water-based stains are generally more environmentally friendly and easier to apply and clean up. Many water-based stains also feature additives to prevent fungal damage or wood rot. Learn more in this guide to the differences between water—and oil-based stains.
The 3 best deck stain brands for decks in full sun are TWP, Restore-A-Deck, and Armstrong Clark. The TWP 100 Pro Series semi-transparent penetrating deck stains in darker tints are best for most decks. TWP also has a semi-solid penetrating deck stain that works well in full sun. Restore-A-Deck has semi-transparent and solid deck stains for full sun. Armstrong Clark is a high-quality oil based deck stain.
Additional Deck Stain Rating Questions
If you have questions on this review of deck stains, please ask me below in the comments.
Want My Help Finding a Deck Stain?
- Deck Location: Michigan
- Wood Type: Cedar
- Mold/Mildew?No
- TWP 1500 Series
- Armstrong-Clark Deck and Wood Stain
- Restore-A-Deck Wood Stain
- Defy Extreme Wood Stain
I am here to help you find the best wood deck stain for your situation! Just post a comment below with answers to these questions.
Seattle, wooded neighborhood
Partial shade
2 year old cedar deck
Yes mold
Stained two years ago with an oil based and have now cleaned and brightened for maintenance
Fiona, since you sued oil before it would be a good idea to stick with another oil. Armstrong Clark or TWP 1500 would be a good idea.
SE Wisconsin
Full sun
New construction pergola
virgin lumber, cedar
want slight brown tint, great seal.
Steve O, I would look at Armstrong Clark in the Rustic Brown color.
Minnesota
full sun
Cedar
no mold/mildew issues
Deck is about 7 years old have tried cabot, behr, and flood stains. All started to peel or lift off after one winter summer season cycle. Could you please recommend a stripper, and a stain that will survive minnesota weather. Thank you.
Dan L, try a stain stripper such as Restore A Deck or HD80. For this deck you would want a deep penetrating stain such as Armstrong Clark or TWP.
Philly
Full sun
Pressure treated pine
New wood
Dave, for new wood you should try Armstrong Clark or TimberOil
1.Deck Location State:Washington
2.Full Sun in afternoon
3.Wood Type: Pressure Treated cedar
4.Mold or Mildew Issues: no
5.Reason for Previous Stain Failure: last stain 5 years ago. Railings peeling, exposing bare wood
Jacque, make sure to prep the wood properly by removing the old stain. You may need a stain stripper for this. I would look at TWP or Defy Extreme for this deck in WA.
Washington
partial shade
Cedar
mold,mildew – yes
This deck is under a huge big leaf maple tree and cedar tree area. We have three dogs that utilize it for a passage into the house. We used timbertech stain last time ( the deck is only 5 years old) It wore down, became slick to walk on because of the moss like film that formed on it.
haelp – we are in the window of redue.
Patty, I would look at TWP 1500.
1. Seattle, Washington
2. Half of deck: Full sun; Half of Deck: Partial shade.
3. I believe older pressure treated pine, but maybe cedar.
4. Yes, in that previous owners let it get very moldy. But it has been pressure washed and cleaned. Sections that don't get as much sun though may be prone to having it return.
5. It's just very dry and bare now. I want to go with something semi-transparent.
Hania, for this very dry deck I would consider and oil based stain the replenish the lost oils. Armstrong Clark would be a good choice.
Seattle WA area
6 year old deck railing, pressure treated pine I think
partial sun
some mold and mildew
existing stain had completely faded and peeled
cleaned, sanded and brightened
Pete S, TWP 1500 or Defy Extreme
elgin il near chicago
full sun
10 year old deck
no mold on deck but minor on railing
stained 7 years ago tomsons water seal worn out due to age
preeasure treated pine
Rick, I would use Defy Extreme for this PTP deck in full sun.
My deck is 30 by 12 feet, built with pressure treated pine 1 1/4" thick boards. ?1: Canton, MA, ?2: Full Sun, ?3: Pressure Treated Pine, ?4: Some and ?5: brokedown wore out, pealed in places and cracked speeding further breakdown.
George, make sure to remove the old stain by cleaning and or stripping. I would look at Armstrong Clark or TWP 1500.
Wisconsin, Madison (4 full seasons)
Full sun until afternoon, then shaded by trees
No mold
Used Cabot Stain & primer lasted only 2 years, now peeling
Original coat unknown origin, solid color
Prepping difficult, need to invest in RAD I think. Tried StainBrite stain remover with pressure washer, now trying to sand, not getting to wood very easily.
Much thanks for your guidance, terrific site!
Annie, Deck stain strippers will not remove solid color deck stains. You would need to sand.
Ohio
Full sun
20 year old pressure treated
No mold
Stain does not penetrate wood so it peels and does not adhere
Mary Ann, make sure the wood is free of all previous coatings then use a deep penetrating stain such as Armstrong Clark or Timber Oil. Ready Seal would work as well.
Deck Location State: Illinois
Full Sun, Partial Shade, Full Shade: Full Sun, around above ground pool and a lower deck area
Mold or Mildew Issues: No
Reason for Previous Stain Failure: Poor results from last years application (used SW and Ben Moore previous coats)
Tom N, remove all of the previous coatings then look at TWP or Defy Extreme.
Arkansas
Partial Shade, More Shade Than Sun
Yes
New Deck
Connie, new wood is not ready to be stained. Let dry for a least 4 weeks then prep with a cleaner and a brightener. For new decks we suggest a deeper penetrating stain such as Armstrong Clark or TimberOil brand.
Minnesota
Full Sun and snow
7 year old cedar deck
Completely sanded off old stain and down to bere wood
Joel, prep the sanded wood with a deck cleaner and brightener to better open the pores of the wood. I would use TWP.
Reason for Previous Stain Failure: May not have been properly prepped. Stains previously used: Sherwim Williams, Benjamin Moore
Tom, Might want to look at the Defy Extreme Stain or TWP for this IL deck. Make sure to prep properly this time by removing the previous coatings and brightening the wood.
California – Lake Tahoe
Sun & shade (no humidity in the summer) & snow (in the winter)
Cedar (1959) will be stripped back to bare (in good condition & beautiful in color)
No mold or mildew
Thinking of using "Ready Seal" natural cedar
Linda, Ready Seal will need to be applied every year or sooner. If you are okay with that then it will work for you. For a longer lasting stain I would suggest TWP 1500 or Armstrong Clark.
Seattle WA area
partial sun
6 year old deck railing (Trex decking)
original stain almost completely gone, faded
Pete S, I would look at TWP or Defy products for the railings.
Deck Location State: Southern Quebec
Full Sun, Partial Shade, Full Shade: Partial shade
Wood Type: Spruce
Mold or Mildew Issues: Yes
Reason for Previous Stain Failure: Thompson Water Seal… useless.
Need not be shipped to Canada: have a Vt mailing address. Deck is about 500 sq.ft. 7 yrs old and poorly treated before I bought the house 2 yrs ago. Trying to keep it alive as long as possible. Have heavy snow and cold weather issues as well as humid summers.
Margo, Might want to look at TWP 1500 Series. I agree with your comment on the Thompson\’s 🙂
1. Northern California
2. Full Sun
3. Redwood
4. No
5. Faded color after 1 year
Clay, TWP 1500 or Armstrong Clark are great stains for redwood.
Ontario
full sun to full shade in afternoon
yes to mildew
has been deck washed/cleaned but was "painted" 2 yrs ago with Benjamin Moore's exterior stain for deck and siding in alkyd semi solid
Question: do I have to use another alkyd product or can I use one of the ones mentioned on this site and also can I get it in Ontario?
thanks!
Nancie, you cannot put a different brand on top of the semi-solid Benjamin Moore. You would most likely need to remove it if you want to switch or stay with the same brand and type.
On a prevous post, you suggested TWP 1515 for my new pressure treated pine deck in the Midlands of SC. When reading other posts, I noticed that on many occasions you recommended Timber Oil as the initial choice for a new deck because of the parrafin-oil base and its penetration into new wood. Just wondering why the TWP or Defy recommendations on this occasion instead of Timber Oil?
Charles, might not have caught the \”new\” part on your previous question. For new wood we really like paraffin oil based stains such as Timber Oil or a hybrid stain like Armstrong. They absorb into new wood much better.
Bellingham, Washington
Full sun (well, Washington sun that is!) ; also is directly exposed to heavy rain
15-year-old cedar deck
Stained 2 years ago with Behr, but deck is now very dried out and grey. What cleaner and stain do you recommend?
Peggy, I would remove the Behr with a stain stripper followed by a wood brightener. Restore-A-Deck is very good and economical brand. For the stain I would look at TWP 1500 or 100 Series.
Taos, NM
Full sun, very dry climate
Not sure but isn't cedar, red wood, or pine. Maybe Douglas fir.
No mold or mildew
Cabot stain did not penetrate and started to peel immediately. It''s now 4 years later. Wood is very dry.
Ruth, Clean and brighten then I would look at Armstrong Clark stains to rejuvenate very dry wood.
Neww York
Full sun
mohagony
No
Turned gray in color used cabot australian timber stain
Frank, for your mahogany deck I would suggest the Armstrong Clark Stain in the Mahogany color.
I am looking for a stain recommendation for our cedar deck in Vermont. We built it two years ago and applied Wood Toned Deck & Siding Stain (natural color), and by the end of the fall and all the following spring/summer it continued to peel. It also showed some mold dots/splotches. I called Cabot and they recommended using a cleaner (said exterior bleach at a particular concentration, that I can't remember anymore, was fine). So I did this and left it, as Cabot could not offer any explanations and we were not sure what to do. Now, a year later, we are thinking of re-staining it. Much of the previous stain is peeled off and the deck is now grey with some light brown mottling where the stain thinly remains.
Based on these circumstances, what you recommend for cleaner and for stain;
1. Central Vermont
2. Full sun, southern exposure
3. Cedar
4. 2 years old
5. Looking for stain that will protect the wood but look natural. We like the reddish tone of cedar (which is now gone) but also the greyed weather look (thought of a natural grey stain or just allowing the deck to weather). Does cleaning it really bring back the cedar color? Should we try the same stain again? Could there have been too much moisture in the wood when we applied it?
Deina, might want to use a deck stain stripper followed by a wood brightener to remove the remnants of stain and restore the cedar color. As for a stain suggestion, I would look at TWP 1500 in the Honeytone or Armstrong Clark in the Amber if you want a light colored tint.
Oakville, Ontario. We get about 2 months of summer season. heavy snow in winters
Full sun
2 years old never stained or treated because we had repairs that needed made after 1 yr
Deck floor is cedar( never treated and I love the silver look ) the railing is pressure treated pine and the bench areas, and panelling on benches are combination pressure pine and outdoor MDF.
Some moulding on MDF , greying on cedar floor of deck
Do I need to stain/seal cedar floor because I love the silver look?
I wanted to paint uppers and bench only because of the combination of woods used and heard of Flood. Any recommendations for solid paint ?
Patricia, not sure on the solid stain but Flood doe make a decent one. As for the gray, you might want to use a clear sealer to protect but not change the color.
Full Sun much of the day
New pressure treated pine deck
No mold and never been stained
Would like best compromise of seeing as much of the wood grain as possible and getting the best UV protection
Charles,I would look at TWP 1515 Honeytone or Defy Extreme in Natural Pine
Kansas City, MO (planting zone 6)
Partial sun (actually the floor of a covered porch, but gets sun)
100-year-old quartersawn tongue and groove fir (or maybe pine)
Probably no mold
Planed to raw wood
Would like to preserve beauty of wood, but concerned about high maintenance (might paint)
Kim, I would use Armstrong Clark for this very old fir. It is easy to re coat every 2-3 years.
What would be the best brand & type of stain for our deck.
Sun/shade: two story deck w/ upper part in sun majority of the time & lower section shaded
Type of wood: Pressure treated pine
Mold/Mildew: not really a problem
Reason for failure: Not taken care of properly.
The other issue w/ our deck is the shaded part is at least 13 yrs old, one section (by the back door) was replaced last year & the entire upper deck was replaced this week.
I have been told to use a solid stain instead of a semi-transparent due the different age of the wood. I'm having trouble w/ the stain looking anything like the color swatches. So far I have tried Olympic Maximum solid stain.
Barb, we have yet to rate the solid stains yet. If you are going that route then you should be able to get it in any color as it is basically a paint.
I have a large covered porch In NY with thin hardwood tightly spaced. It has a transparent stain on it currently but rain is taking its toll on it. What should I put on it?
Mike, Defy Hardwood Stain would be a good choice or possibly IpeOil.
What is the best stain for:
1.Colorado at 9200ft
2.Mostly full sun
3.Pressure treated pine
4.Mold and mildew is not a problem
5.Previous stain has peeled. Parts of the project is new, unstained PT pine
James Shafer
James, I would look at TWP 1500.
Full Sun area
Brand new pressure treated Pine (never stained)
Mold on Railings
Old deck stain faded
D. Winnegge, For new wood we suggest Timber Oil Brand or Armstrong Clark.
Vacaville, CA
Full Sun (am shade)
8-10 year old redwood I think
No mold
Very old stain but mostly bare from weather
Wood appears in good condition.
Was about to buy Behr but saw this site. I have some behr cleaner and stripper. Was thinking of sanding to remove old stain rather than chemical. Wanna start with as clean and new appearing surface as possible prior to stain.
Saw Armstrong recommendation…..Anything further/?
Thanks!!
Matt, the cleaner and brightener may be enough to prep since the stain is so old and deteriorated. Armstrong is an excellent stain and would work well for this older dried out deck.
Connecticut
Full sun
1 year old deck
Lots of mold
Deck stain showing a lot of wear and did not guard at all against mold. It's been cleaned to get ready to re-stain. Two questions:
– Do we need to strip the existing stain? If it's uneven will the new stain look uneven on top?
– What stain do you recommend? Though we get full sun, we've had a lot of mold on our deck and teak furniture.
Thanks!!
Tracy,
I would strip the existing stain to ensure an even application and proper adhesion. As for the stain, since you have a lot of mold my first choice would be Defy Extreme then TWP 1500.
Oak Brook, IL suberb of Chicago
Partial Shade
Cedar
Some Mold
Has not been stained or cleaned in three years.
Fairly large deck so want to get it right so I dont have to do it again next year
Kevin, clean and brighten the wood then use TWP 1500 for 2-3 years of protection.
SE Michigan
Full Sun/Evening Shade
North, East & Southern exposure
No trees
Minor Mold
All Cedar
Most of prior stain is worn off
Needs to be prepped and sealed.
Belinda, I would use the Restore-A-Deck Cleaners and either TWP or Armstrong Stain for a Michigan deck.
northern ontario canada
full sun on most part shad on 1/4
just built
no mold
Brandi, I would look at Defy Extreme Stain
1) Chicago 2) full sun 3) pressured treated cedar? 4) some algae? 5) probably used inexpensive stain purchased at big box store. Last year I cleaned with oxy cleaner, used brightner and sanded grayed decked after 7 years. After one year most color has dulled and worn out. Deck looks untreated and blah. Please recommened stain., water or oil? Also, do I need to strip off old stain? Do I need to re clean with oxy and rebrighten or can I just wash deck and stain over exsiting color? Would you recommend both a cleaner and brightner if necessary. High traffic area, 4 seaons lots of snow, ice and water. Thank you for your time.
Renate, I would clean and brighten again an go with an oil based stain such as TWP or Armstrong Clark.
Deck Location: Northern Wisconsin
Full Sun, Partial Shade, Full Shade: Mostly Shade
Wood Type: New Cumaru
Mold or Mildew Issues: Likely over time
Reason for Previous Stain Failure: New Deck
I'm building a new 400sf deck with Cumaru. It's in the woods in N. Wisconsin, so has to endure snow and cold in the winter. What do you recommend for stain (I was thinking Messmer's UV+ for Hardwood) and prep of new wood?
Ken, I would look at the Messmers for Hardwoods or Defy Stain for Hardwoods. To prep you should use a cleaning kit such as the Restore-A-Deck or Messmers makes some good products to clean.
Per your thoughts, I called a distributor to buy the Armstrong product, but in discussing my situation – being a single handed newbie who will be working on this project only a few hours at a time for the next several weeks and having several ages and situations of decking and fencing, the distributor is guiding me to Ready Seal. Do you think I would be making a mistake in Morgantown, WV, with never yet stained or treated, pressure treated, 8 month, 1 month, 3 year old wood, some sunny some deeply shaded components? I am leaning toward the darkest mahogany because your review says it lightens quickly.
Also, I have purchased and intend to use RAD kits on everything in preparation for the stain. Is that a good idea?
Joan, Ready Seal is easier to apply then Armstrong but Armstrong has better color retention and spread rate. I would use the Armstrong. RAD Kits will prep the wood properly for either stains.
Illinois
partial shade
cedar
yes
long time between applications
prepped it with deck cleaner and pressure washer
Ed, I would use TWP 1500 or Armstrong Clark
Deck Location State: Central California
Full Sun, Partial Shade, Full Shade: Almost Full Sun
Wood Type: Cedar or Redwood – can't remember which
Reason for Previous Stain Failure: Mostly it just doesn't seal out water anymore, but there are a few small areas where the coating is totally removed.
The deck is 2 years old and I have used a clear sealer both seasons – can't remember the brand but it was given to me with the deck by the builder and probably something he bought at Lowe's or Home Depot. What is the best stain, and the best product to prep? Preferably something I can get locally rather than order online. Will prepping with a pressure washer be enough or do I need to use a stripper?
Kristine, sealing out water like a car wax is not good. You want the wood to be able to \”breathe\”. This is a common myth form the TV commercials from Thompson\’s. I would use a stain stripper with the pressure washer if you still have an old coating. I am not sure what you can get locally for the stain. Maybe Armstrong Clark as they are based out of California.
MN
partly shaded
no mold,mildew
5 yrs. old, never stained
Requel, clean and brighten the wood to remove the dirt and graying. I would use an oil based stains such as TWP or Armstrong for this dried out deck.
Myrtle Beach, SC
Full sun
Pressure treated Pine
Some mold issues,salt water and sun damage
7 yr old deck, just bought house-no history
Glen, I would use Defy Extreme Stain.
Central Virginia of Blue Ridge Parkway at 3,600' elevation.
Normally, 80 degrees or less during summer; hard winters.
Filtered sunshade throughout summer on back deck. Constant breexes.
Pressure treated pine 2×6 construction, build last summer and not yet treated or stained (this will be first)
Currently fairly clean but we will lightly pressure wash/clean before application
Preference is to use clear/lightly tinted stain to maintain natural pine grain.
Quality and longevity more important than cost.
Frank, lighter stain colors will always fade/fail faster then darker/richer color. I would look at TWP 1500 Honeytone of Armstrong Clark in Amber color.
1. Mississippi
2. Full sun
3. Pressure Treated Pine
4. Yes to mold (in some parts)
5 Turned dark gray
6. Deck is 9 years old
Robert, clean and brighten to prep then stain with Defy Extreme or TWP.
1. Southern Connecticut
2. Full Sun (Southeast facing)
4. No significant mold/mildew problems
5. Bought the house 1 year ago, don't know how/if it was protected or maintained previously. Appears as if the owner attempted to stain a very small section of the railing and gave up quickly.
The deck (horizontal surfaces at least) is mostly grey and absorbs water easily. After looking through this site I was planning on using Restore-a-Deck cleaner & brightener, then using Defy Extreme Cedartone stain. Is this a reasonable plan? Should I strip the small section of the deck that was stained (it looks like it's anywhere from 1-3 years old)? Some of the floor and railings are a bit rough, should I spot sand after cleaning/brightening if it's still rough?
Also, will a single kit of Restore-a-Deck be enough for 400 sq. ft. plus railings? I have lattice all around underneath deck between 1st floor height and ground (about 4 ft).
Evan, I would think the a single kit of the RAD products should be enough to prep your deck. You may need a stripper or sanding to remove the small stained section. The stain would be a good choice. I personally would not sand unless needed. Make that decision after the cleaning. When wood is severely gray, cleaning sometimes can create \”fuzzies\” as you are removing a lot of dried wood cells.
Partial Shade depending on time of day
Severe moisture problems
My father built me a 20’x14′ deck in 2008 of treated pine. It sits low to the ground, with the support 4×4’s glued to regularly spaced and leveled 16″x8x4″ concrete blocks (as opposed to being sunk in the ground). My yard has about a 1.5′ slope from one end of the deck to another, such that the one end is a couple inches off the ground, and the other is about 8″ off.
Dad got creative and layed out the deck boards in a herringbone design, and constructed piggie-backed perpendicular 2″x6″ supports in order to allow more room down the horizontal and vertical center lines to screw in the boards. We sealed the deck once in 2010, although I don’t remmber the type of sealer.
MY PROBLEM: Deck has worn horribly and now looks about 25yrs old, instead of 4. A section of the piggy-backed horizontal center supports started to rot, and my dad realized his deck design was severly flawed, in that it allows moisture to become trapped between the 2×6″ center supports. He’s removed all the top decking and replaced the perpendicular center supports, this time with vinyl flashing between them. He is replacing about 25% of the deck boards and reusing the rest that are not rotting (but still very aged). I know this is probably a doomed structure, but can you please reccomend a sealer that will help with future moisture problems??
Any info you can provide will be SO APPRECIATED!!!! Thanks, – Catherine
Catherine, you would want a breathable semi-transparent stain that controls mold and mildew well. TWP 1500 or Defy Extreme.
New Jersey
Full sun
No mold
Approximately 20 years old
Previously stained & sealed every 2-3 yrs w/CWF
Hasn't been sealed in about 4 yrs
Based on what I've read here we're considering Armstrong Clark or Defy Extreme. Which would be better & if you recommend the Armsrong Clark, semi-transparent or semi-solid?
Mary Ann, Will you be removing the CWF? It does matter.
If you suggest we remove it we will. What do you suggest?
Mary Ann, powdered strippers such as Restore-A-Deck or HD80 are the most cost effective and work very well.
