Black Deck Stain: The Best Black and Dark Stain Colors for Decks 5/5 (1)
Hi, I’m Scott Paul, a licensed exterior restoration contractor with over 30 years of experience and 10,000+ deck restorations. This review of black deck stain colors is based on my own hands-on field testing, not manufacturer claims. See my full credentials and testing stats here.
Black deck stain is one of the most requested colors I hear about, and one of the most misunderstood. Most stains sold as “black” are actually a very dark brown, and the only way to get a true black finish is a solid color stain. This guide covers the black and near black stain colors I recommend, how dark stains behave in sun and heat, and which one fits your deck, fence, or railing.
In this guide:
  1. Is There a True Black Deck Stain?
  2. The Best Black and Dark Deck Stain Colors
  3. Black Deck Stain Comparison Table
  4. Black Deck Stain and Sealer in One
  5. How Dark Stains Behave in Sun and Heat
  6. Where Black Stain Works Best
  7. Prepping a Deck for Black Stain
  8. Black Stain vs. Black Marks on a Deck
  9. Black Deck Stain FAQ
Black deck stain comes in two forms, and knowing the difference saves a lot of disappointment. Semi transparent and semi solid stains let some of the wood grain and natural tone show through, so even the darkest colors read as a deep brown or charcoal up close. A solid color stain covers the grain completely, and that is the only type that gives a true, flat black.
If you want the look of black while still seeing the wood, choose a dark semi transparent or semi solid color. If you want a true black with no wood tone at all, choose a solid stain and expect more maintenance on deck floors, which I cover below.
Black deck stain colors I recommend fall into three groups: dark semi transparent, dark semi solid, and solid black. These are the five colors I trust, from the most grain showing to the least.
Armstrong Clark Semi Transparent Black Walnut
Armstrong Clark Black Walnut is the darkest semi transparent color in the Armstrong Clark line, a deep brown that looks nearly black from a distance while keeping the grain visible. Armstrong Clark is a penetrating oil stain that wears away gradually instead of peeling, so recoats are simple. At 50 VOC, it is compliant in all 50 states and Canada. See Armstrong Clark Black Walnut.
TWP 1500 Series 1504 Black Walnut
TWP 1504 Black Walnut is the darkest color in the TWP 1500 Series and very close in tone to the Armstrong Clark Black Walnut. TWP 1500 is EPA registered with strong mildew resistance, which makes it a good fit for shaded or humid decks. It is compliant in all 50 states but is not sold in Canada. See TWP 1500 Series 1504 Black Walnut.
Armstrong Clark Semi Solid Espresso
Armstrong Clark Espresso is a semi solid color with more pigment than Black Walnut, so it hides more of the grain and gives a richer, darker brown. It is the right pick when you want a near black look on an older deck with uneven color, since the extra pigment evens out blotchy boards. See Armstrong Clark Espresso.
TWP Semi Solid Charcoal
TWP Semi Solid Charcoal is the closest thing to black in a stain that still shows a hint of grain. It is a cool gray black rather than a brown, which suits modern homes with black trim, black window frames, or gray siding. See TWP Semi Solid Charcoal.
Restore A Deck Solid Stain in Classic Black
Restore A Deck Solid Stain in Classic Black is the true black option. Solid stain covers the grain completely for a uniform black finish, which works especially well on fences, railings, and siding. Restore A Deck Solid Stain is now available in Classic Black. See Restore A Deck Solid Stain Classic Black.
Color Opacity Tone Grain Visible Best For
Armstrong Clark Black Walnut Semi transparent Very dark brown Yes Deck floors, all 50 states and Canada
TWP 1504 Black Walnut Semi transparent Very dark brown Yes Shaded or humid decks
Armstrong Clark Espresso Semi solid Deep brown black Partly Older decks with uneven color
TWP Semi Solid Charcoal Semi solid Gray black Partly Modern homes, gray or black trim
Restore A Deck Classic Black Solid True black No Fences, railings, siding (coming soon)
Black deck stain and sealer in one is exactly what these products are. Armstrong Clark, TWP, and Restore A Deck stains seal and protect the wood as they color it, so there is no separate sealer step. In fact, putting a clear sealer over a penetrating stain usually causes peeling, because the second coat has nothing to soak into. Apply the stain alone, and treat it as both the color and the protection.
Dark stains in full sun come with two tradeoffs worth knowing before you buy. First, a black or near black deck floor absorbs more heat than a lighter color and can be uncomfortable barefoot on a hot afternoon. Second, wear in high traffic areas like stairs and doorways shows more clearly against a dark color.
The good news is that dark colors carry more pigment, and pigment is what blocks UV. A dark semi transparent stain generally holds its color longer than a light one. On a sunny deck, a common approach is a dark color on railings, posts, and fascia with a slightly lighter color on the floor boards.
  • Fences: Vertical, no foot traffic, and no heat concern. Black and charcoal fences are one of the strongest uses for dark stain, and they typically last 3 to 5 years between coats.
  • Railings, posts, and fascia: A dark frame around a lighter floor is a popular look and keeps the walking surface cooler.
  • Siding and trim: Solid black works well on vertical surfaces where peeling is less of a risk than on a deck floor.
  • Deck floors: Use a dark semi transparent or semi solid stain rather than a solid color. Solid stain on horizontal boards is more likely to peel and harder to maintain.
Prepping a deck for black stain is the same as for any color, though dark stains are more forgiving of uneven wood. Clean the deck with a deck cleaner, apply a wood brightener, and let it dry for 48 hours. If the deck has an old stain that is peeling, strip it first. My deck cleaner reviews cover the products I use for prep. To figure out how many gallons you need, use the deck stain calculator.
Going darker over a lighter stain of the same type is usually straightforward after a cleaning. Going from a dark stain back to a light one is not, because the old pigment has to be stripped out first. Test your color on a hidden board before committing to the whole deck.
If you came here because your deck has black spots or a stain that has darkened on its own, that is a different problem. Black marks on a deck are usually mold, mildew, or a reaction between the wood and metal fasteners, and they need to be cleaned out, not stained over. My guide on why a deck stain turned black explains the causes and how to fix them.
Is there a true black deck stain?
Yes, but only in a solid color stain. Semi transparent stains labeled Black Walnut are a very dark brown that lets the grain show through. If you want a true black with no wood tone, use a solid color stain such as the Restore A Deck Solid Stain in Classic Black.
What is the darkest semi transparent deck stain?
Black Walnut is the darkest semi transparent color in the stains I recommend. Armstrong Clark Black Walnut and TWP 1500 Series 1504 Black Walnut both give a deep brown that reads close to black from a distance while still showing the grain.
Does black deck stain make a deck hotter?
Yes. Dark stains absorb more sunlight, and a black or near black deck floor in full afternoon sun can be uncomfortable barefoot. On a sunny deck, consider a dark color on railings and posts with a slightly lighter color on the floor.
Does black deck stain fade?
All deck stains fade, but dark stains carry more pigment, so they hold up better against UV than light colors. The tradeoff is that wear shows more clearly in high traffic areas, so plan on a light maintenance coat on the floor every 2 to 3 years.
Can I put black stain over a lighter deck stain?
Usually yes. Going darker is easy as long as the old stain is the same type and has worn evenly. Clean and brighten the wood, let it dry, and apply the darker color. Going from dark back to light requires stripping the old stain first.
Do I need a sealer over black deck stain?
No. Armstrong Clark, TWP, and Restore A Deck stains are stain and sealer in one, so the stain is the sealer. Adding a separate clear sealer over them can cause peeling and is not recommended.
Is black stain a good choice for a fence?
Yes. Fences are vertical, shed water, and take no foot traffic, so dark stains last longer on a fence than on a deck floor and heat is not a concern. Black and charcoal are popular modern fence colors.
Thinking about a black or dark stain for your deck? Ask in the comments below and include a photo if you can. I answer most questions within a day.
0 Comments
